Panasonic DECT 6.0 Expandable Digital Cordless Phone System
#285
3.3
based on 45 reviews
from $59.00 - $86.41
Ratings Distribution
5 star
17
4 star
9
3 star
3
2 star
2
1 star
14
Category Average
3.8
More Images
Pros
  • Easy setup (12)
  • Nice features (11)
  • Comfortable handset (10)
  • Nice sound (10)
  • Strong signal (10)
  • Lightweight (9)
  • Good speakerphone (5)
  • Wide range (4)
  • Attractive design (3)
  • Great sound quality (3)
See less See more
Cons
  • Creates static (2)
  • Poor sound quality (2)
  • Short battery life (2)
  • Limited range (1)
  • Lousy troubleshooting (1)
  • Max hand set volume low (1)
  • Not durable (1)
  • Weak signal (1)
Best Uses
  • Everyday (9)
  • Home use (9)
  • Outdoors (4)
  • Office (2)
  • Small spaces (2)
  • Blends in (1)
  • High call volume (1)
  • Large buildings (1)
  • Long talks (1)
Provided by Buzzillions.com
The KX-TG9332T DECT 6.0 Expandable Cordless Phone assures greater protection against eavesdropping for all your calls. DECT 6.0 (Digital Enhanced Cordless Telecommunications) technology lets you move freely around your home with long range and amazingly clear sound. Operating in the 1.9GHz frequency range, your phone will not conflict with other wireless devices such as Computer routers, wireless keyboards, microwave ovens and other common household devices.
Now you can Program each handset to ring at your discretion. Before going to sleep, simply set the bedside handset to Night Mode so that it won't ring in your bedroom. In the meantime, the handset in the den will still ring when that important call comes in without disturbing the person who's sleeping. Now you don't have to be holding the phone to see who's calling. Using text-to-speech technology, the Caller ID2 information is announced between rings.
The KX-TG9332T also boast a talking alarm clock that will tell you when it's time for lunch, and a talking Battery alert that politely tells you when your battery is low with a Please Charge Phone reminder. Store the Caller ID info of any and all unwanted callers into your phone's Call Block list so that you can eliminate future pesky calls. After the information is stored, your unwanted callers will receive a busy signal when they call you again.
The Light-Up Indicator with Ringer Alert at the base of the antenna will Flash quickly to show that you have an incoming call, and it will flash slowly to let you know you have a new message.
Specification Description
Model KX-TG9332T, KXTG9332T, PANKXTG9332T
UPC 037988479474
Additional Functions Night mode, call block mode
Additional Handsets Qty 1 Handsets
Answering System Type All-digital
Audible Battery Alert Yes
Base Depth 4.69 inches
Base Height 2.48 inches
Base Weight 7.76 oz
Base Width 5.51 inches
Battery Type Product
Belt Clip Yes
Benefits DECT 6.0 technology ensures you always have crystal-clear soundNight mode lets you chose where the phone rings, or doesn't ring, at y
Call Waiting Yes
Caller ID Yes
Caller ID Memory 50 Names and Numbers
Caller ID on base Yes
Caller ID waiting Yes
Capacity UOM mAh
Chemistry Ni-MH
Connections RJ11 (1)Barrel input (1)Headset jack output (1)
Cordless Phone Standard DECT
Country Of Origin Malaysia
Depth 1.3 inches
Description Header The phone with it all.
Dialer Location Handset
Dialer Type Keypad
Digital Transmission Yes
Display Catalog Number 55033062
Display Form Factor 6
Display Languages English, Spanish
Display Location Handset
End Product Indicator Yes
Handset Locator Yes
Height 6.1 inches
Included in the Box Handsets (2)Base (1)Charger (1)User's guide
Intercom Yes
Manufacturer Labor Warranty 12
Manufacturer Part Number KX-TG9332T
Manufacturer Parts Warranty 12
MAP Price 0.0
Max Handsets Supported 6 Handsets
Model KX-TG9332T
Multiline Operation Capability Single-line
Operating Temperature UOM ° F
Power Device Charger, rechargeable battery
Product Disclaimer * Requires optional accessory handset sold separately. **Requires subscription to name-and-number Caller ID, call waiting and/or voice mail services o
Product Type DECT phones
Rechargeable Yes
Recording Capacity 64 Minutes
Ringer Control Yes
Size AAA
Speakerphone Yes
Supported Languages English
Transmission Band 1.9 GHz
Transmission Band UOM GHz
Type LCD
Voice Mail Capability Yes
Volume Control Yes
Weight 4.6 oz
Width 1.89 inches
Panasonic DECT 6.0 Expandable Digital Cordless Phone System Questions
Questions and Answers
Where to Buy
$64.88
$69.95
5% off orders at Abt.com
BizRate Rating Outstanding 9.4
$59.00
BizRate Rating Outstanding 9.1
Show all 15 stores
_
Product Reviews
Last update: Nov 15, 2009
Panasonic DECT 6.0 Expandable Digital Cordless Phone System Reviews
Most helpful positive review
[13 of 13 customers found this review helpful]
Most helpful negative review
[8 of 9 customers found this review helpful]
5.0
Best phone I've every owned!
"I love this phone! It has the power to punch through concrete block walls and still have a clear signal. The talking Caller ID feature is great! It reads the text from the Caller ID, so you can decide whether you want to answer the phone or not. It has a separate alarm available in each handset, and has a night mode feature that lets you silence a handset's ringer between the hours of your choosing. It also has ..." Read Full Review »
Jun 10, 2008 by DavidNH
See more positive Panasonic DECT 6.0 Expandable Digital Cordless Phone System reviews
1.0
Warning...IGNORE POSITIVE REVIEWS FOR THIS PHONE!!!!
"I just purchased this phone set eight days ago. The second day that we had it the phone would ring but it would not allow you to answer it. It became necessary to have both handsets nearby so that when one failed we would still be able to utilize the other. I researched cordless phones and was drawn in by the other reviews for this model. I wanted a phone that was at least DECT 6.0 so that it would not interfere..." Read Full Review »
Dec 27, 2008 by Disgruntled
See more negative Panasonic DECT 6.0 Expandable Digital Cordless Phone System reviews
Displaying 1 - 5 of 45 Reviews
Show
Sort by
5.0
"I love this phone! It has the power to punch through concrete block walls and still have a clear signal. The talking Caller ID feature is great! It reads the text from the Caller ID, so you can decide whether you want to answer the phone or not. It has a separate alarm available in each handset, and …"  Read Full Review »
Was this Cordless Telephone review on the Panasonic DECT 6.0 Expandable Digital Cordless Phone System helpful to you?
 Report Abuse  (13)  (0)  0 comments
Jun 10 2008
DavidNH
Stow, OH
Reviewed at:
Price: $69.99
1.0
"I just purchased this phone set eight days ago. The second day that we had it the phone would ring but it would not allow you to answer it. It became necessary to have both handsets nearby so that when one failed we would still be able to utilize the other. I researched cordless phones and was drawn …"  Read Full Review »
 Report Abuse  (8)  (1)  0 comments
Dec 27 2008
Disgruntled
St. Louis, MO, USA
Reviewed at:
Price: $69.99
[10 of 11 customers found this review helpful]
great phone with lots of features
5.0
"I bought this phone a couple of weeks ago after doing a lot of research to make sure that I got the best phone for my money. I am very pleased with it. I love the call block feature and the voice that announces who is calling. I had a hard time finding a phone that worked with voice mail and had a i …"  Read Full Review »
 Report Abuse  (10)  (1)  0 comments
Oct 22 2008
C. Self
Apex, NC
Reviewed at:
Price: $69.99
[2 of 2 customers found this review helpful]
Love this phone!
5.0
    Pros
  • Comfortable Handset
  • Compact design
  • Easy To Set Up
  • Good Sound
  • Good Speakerphone
  • More »
    Cons
  • None
    Best Uses
  • Everyday Use
  • Home Use
  • Outdoors
"I purchased this phone for Mother so she could use the speaker feature. I have this same phone in my home. It is also compact and has good sound.
She likes the phone but still doesn't use the speaker as much as I thought she would. Habit!
She also likes the built-in answering machine. It eli …"  Read Full Review »
 Report Abuse  (2)  (0)  0 comments
Jul 17 2009
She-shares-good-things
Omena, MI
I am:
  • Quality Oriented
Reviewed at:
Price: $79.99
One major flaw
1.0
    Pros
  • Easy To Set Up
  • Good Sound
  • Nice Features
    Cons
  • None
    Best Uses
  • None
"I purchased this phone because of the wide range of features and my past experience with Panasonic products has always been positive.
Some of the greatest features about this phone are:
-shared phonebook
-personal ring
-block calls
-night mode
-headset jack
-backlit display and keypad
Th …"  Read Full Review »
Jul 28 2009
HighTechGuy
Mooresville, NC
I am:
  • Quality Oriented
Reviewed at:
Price: $69.95
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
