Panasonic AY-DVM63PQ 63 Minute Mini DV Tape
#2
4.7
based on 135 reviews
Ratings Distribution
5 star
103
4 star
29
3 star
3
2 star
0
1 star
0
Category Average
4.7
Low Price:
$2.89 at B&H Photo Video
$3.99 at J&R Electronics
Find it at Amazon
$2.89 - $3.99
from 2 stores
More Images
Pros
  • Produces great video (104)
  • Easy to use (77)
  • Highly compatible (70)
  • Durable (67)
  • Good value (3)
  • High quality (3)
  • Reliable (3)
  • Reliable recording (3)
  • Adequate capacity (2)
  • Affordable (2)
See less See more
Cons
  • Flimsy design (2)
  • Cases difficult to open (1)
  • Covered in plastic wrap (1)
  • Dropouts would occur (1)
  • Dropped frames (1)
  • Flimsy case (1)
  • Frequent dropouts at head (1)
  • Hard to open packaging (1)
  • Limited compatibility (1)
Best Uses
  • Shooting outdoors (93)
  • Shooting indoors (87)
  • Documentaries (78)
  • Travel (65)
  • Home movies (60)
  • Movies (3)
  • Pro videographer (2)
  • Weddings (2)
  • All uses (1)
  • Archiving video (1)
Provided by B&H Photo Video
The Panasonic AY-DVM63PQ Mini DV Professional Quality Cassette is is a professional grade Mini DV tape. It uses Linear Plus Technology for higher power output deeper error rate and high linearity. Three minutes longer recording time used for professional applications.
Specification Description
Model AY-DVM63PQ, AYDVM63PQ
Format Mini-DV
Length (Minutes) 61 To 120 Minutes
Video Recording Format MiniDV
Panasonic AY-DVM63PQ 63 Minute Mini DV Tape Questions
Questions and Answers
Where to Buy
$2.89
No Tax Outside NY ends 09/09/15
BizRate Rating Outstanding 9.7
$3.99
Product Reviews
Last update: Nov 12, 2009
Panasonic AY-DVM63PQ 63 Minute Mini DV Tape Reviews
Most helpful positive review
Most helpful negative review
5.0
We don't use anything else
"We are professional videographers using Canon XH-A1 cameras. This is the tape we use for all our shoots. We've never had a tape that was faulty or had issues capturing. I love that the front of the tape has the space to write on. The current picture shows a blue MiniDV label which, in our most recent orders, has been a plain white label. We have received the tapes that have the blue label before but hopeful..." Read Full Review »
Nov 12, 2009 by Beautiful Day Films
See more positive Panasonic AY-DVM63PQ 63 Minute Mini DV Tape reviews
3.0
Cautiously optimistic
"We use large quantities of MiniDV tape here at our 3 channel local access television studio. The last batch of 100 Panasonics seemed to have an awful lot of bad tapes. I had never had that problem before, so I hope it was a fluke. But I definately am going to be cautious and test before important shoots...." Read Full Review »
May 29, 2008 by Kathgd
See more negative Panasonic AY-DVM63PQ 63 Minute Mini DV Tape reviews
Displaying 1 - 5 of 135 Reviews
Show
Sort by
5.0
    Pros
  • Durable Design
  • Easy To Use
  • Highly Compatible
  • Produces Great Video
    Cons
  • None
    Best Uses
  • Documentaries
  • Shooting Indoors
  • Shooting Outdoors
I love that the front of the tape has the space to write on. The current picture shows a blue MiniDV label which, in our most …"  Read Full Review »
Was this Camcorder Tape review on the Panasonic AY-DVM63PQ 63 Minute Mini DV Tape helpful to you?
Nov 12 2009
Beautiful Day Films
Chandler, AZ
I am:
  • Film Professional
  • Tech Savvy
Reviewed at:
Price: $2.89
[1 of 1 customers found this review helpful]
Worth the extra for quality tapes
5.0
    Pros
  • Durable Design
  • Easy To Use
  • Good Value for Money
  • Highly Compatible
  • More »
    Cons
  • None
    Best Uses
  • Archiving Video
  • Recording live VJ output
  • Shooting Indoors
  • Shooting Outdoors
  • Travel
"As VJs, we go through a lot of mini-DV tapes. Whenever we're forced to buy lesser quality tapes locally, the quality of the Panasonic Pro tapes really stands out. It never ceases to surprise me that people spend big $ on a camera and then use poor quality tapes - defeats the point of using a good ca …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Oct 28 2008
VJzoo
Perth, Australia
I am:
  • Film Professional
  • Tech Savvy
  • VJ
Reviewed at:
Price: $2.89
Solid Performance
5.0
    Pros
  • Durable Design
  • Easy To Use
  • Highly Compatible
    Cons
  • None
    Best Uses
  • Documentaries
  • Home Movies
  • Shooting Indoors
  • Shooting Outdoors
  • Travel
"I have been using Panasonic tapes for years, and would probably not use anything else. I work all over the world and in documentary work you only have ONE TAKE, so it is important not to "cheap out" on tape.
I have been using the 33 minutes tapes as well for domestic use, so I don't waste so much …"  Read Full Review »
Oct 20 2009
Sky's the Limit Productions
Eugene, Oregon
I am:
  • Film Professional
  • Tech Savvy
Reviewed at:
Price: $2.89
Perfect!
5.0
    Pros
  • Durable Design
  • Easy To Use
  • Excellent Choice For HDV
  • Highly Compatible
    Cons
  • none
    Best Uses
  • Documentaries
  • Home Movies
  • Shooting Indoors
  • Shooting Outdoors
  • Travel
"I have used these tapes for over 3 years now, and they are wonderful! No lubricant means nothing gumming up your heads, and they are perfect for HDV filming. I have used everything from Sony consumer HDV tapes to their ultra-high end Digital Masters that run[$] each, and there is ZERO difference in …"  Read Full Review »
Apr 18 2008
Knuckles
Twin Cities, MN
I am:
  • Aspiring Film Maker
  • Parent
  • Tech Savvy
Reviewed at:
Price: $2.89
The only tape I use now
5.0
    Pros
  • Durable Design
  • Easy To Use
    Cons
  • None
    Best Uses
  • Home Movies
  • Shooting Indoors
  • Shooting Outdoors
"I've used mini-DV tapes made by several different companies and varied levels of quality. I used one "master" level Panasonic one that cost much more and gummed up my heads constantly with no increase in video quality. This tape is consistently good quality with low cost, and I would highly recomme …"  Read Full Review »
Jun 6 2009
Amy H
Boston, MA
I am:
  • Film Professional
Reviewed at:
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
