Panasonic AY-DVM63AMQ Mini DV Videocassette
#6
4.7
based on 75 reviews
Ratings Distribution
5 star
57
4 star
16
3 star
1
2 star
0
1 star
1
Category Average
4.7
$6.99 at J&R Electronics
Find it at Amazon
Find it at Ebay
$6.99
from 1 store
More Images
Pros
  • Produces great video (58)
  • Durable (43)
  • Easy to use (39)
  • Highly compatible (32)
  • Best for your tape heads (1)
  • Economical (1)
  • Excellent price point (1)
  • Excellent video quality (1)
  • Good value (1)
  • Great customer service (1)
See less See more
Cons
  • Pricey (2)
  • Caused dirty heads (1)
  • Limited compatibility (1)
  • No dislikes (1)
  • Not as cheap as i'd like (1)
  • On the expensive side (1)
  • Poor video quality (1)
Best Uses
  • Documentaries (49)
  • Shooting outdoors (44)
  • Shooting indoors (43)
  • Travel (29)
  • Home movies (24)
  • Any minidv recording (1)
  • Anything important (1)
  • Movies (1)
  • Short film (1)
  • Short films (1)
Provided by J&R Electronics
Advance Master Quality Cassettes / 63 Minutes ( 42 Minutes DVCAM ) / Plastic Storage Case
Specification Description
Model AY-DVM63AMQ, AYDVM63AMQ
Format Mini-DV
Length (Minutes) 61 To 120 Minutes
Select Grade High Grade
Video Recording Format MiniDV
Panasonic AY-DVM63AMQ Mini DV Videocassette Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Oct 18, 2009
Panasonic AY-DVM63AMQ Mini DV Videocassette Reviews
Most helpful positive review
[1 of 1 customers found this review helpful]
Most helpful negative review
[0 of 2 customers found this review helpful]
5.0
The only tapes I use
"A few years ago I did some reasearch on the difference in all the different tapes on the market. I learned alot about lubricants and how mixing different brands of tapes in your cameras can decrease the life of your system by "gunking it up" when the different types of tape lubricants are mixed on your heads. I learned that Panasonic Master tapes use what is widely considered to be the best type of lubricant f..." Read Full Review »
Aug 20, 2008 by TeeRuddle
See more positive Panasonic AY-DVM63AMQ Mini DV Videocassette reviews
1.0
Very Disappointing
"If there was a "0" star rating, I'd give it to these mini-DV tapes. I bought a bunch and used them for several months thinking I needed to give them a chance, but finally I had had it (and only had one or two left that I'd be wasting). I have never had so many frame dropouts (those static-y hiccups in the movie) and my tape heads got gummed up constantly! I had to use my head cleaner more in two months than I..." Read Full Review »
Jun 02, 2008 by Amy
See more negative Panasonic AY-DVM63AMQ Mini DV Videocassette reviews
Displaying 1 - 5 of 75 Reviews
Show
Sort by
5.0
    Pros
  • Best For Your Tape Heads
  • Durable Design
  • Easy To Use
  • Highly Compatible
  • Produces Great Video
    Cons
  • Not As Cheap As I'd Like
    Best Uses
  • Anything IMPORTANT
  • Documentaries
  • Home Movies
  • Shooting Indoors
  • Shooting Outdoors
  • More »
"A few years ago I did some reasearch on the difference in all the different tapes on the market. I learned alot about lubricants and how mixing different brands of tapes in your cameras can decrease the life of your system by "gunking it up" when the different types of tape lubricants are mixed on …"  Read Full Review »
Was this Camcorder Tape review on the Panasonic AY-DVM63AMQ Mini DV Videocassette helpful to you?
 Report Abuse  (1)  (0)  0 comments
Aug 20 2008
TeeRuddle
Studio City, CA
I am:
  • Film Professional
  • Tech Savvy
Reviewed at:
Best HDV tape I've used
5.0
    Pros
  • Durable Design
  • Easy To Use
  • Highly Compatible
    Cons
  • None
    Best Uses
  • Documentaries
  • Home Movies
  • Shooting Indoors
  • Shooting Outdoors
  • Travel
"I use this tape with my Canon HV10 HDV cam. Haven't had a dropped series of frames yet. (knock on wood)Best part is that this tape if extremely reliable, while some might prefer the ease of tapeless AVCHD, you save archiving time in that your final archive is the tape itself, and it will outlast a …"  Read Full Review »
Apr 11 2008
Edwood
Los Angeles, CA
I am:
  • Tech Savvy
Reviewed at:
Worth the price
5.0
    Pros
  • Durable Design
  • Easy To Use
  • Highly Compatible
    Cons
  • None
    Best Uses
  • Documentaries
  • Shooting Indoors
  • Shooting Outdoors
  • Travel
"I have used this tapes for years now. I have used them for shooting a little of everything - weddings, concerts, skateboarding, biking, hunting, family videos. These are well worth the extra money. I have some older MQs that I reuse for non-important things. They are 4 years old and have been st …"  Read Full Review »
Jun 26 2008
tylot3
Wisconsin
I am:
  • Film Professional
  • Tech Savvy
Reviewed at:
Very good tapes
5.0
    Pros
  • Durable Design
  • Easy To Use
  • Great for the price
  • Highly Compatible
    Cons
  • None
    Best Uses
  • Shooting Indoors
  • Shooting Outdoors
"I've been using these tapes in my Panasonic DVX100 for two years and they are great. No dropouts or glitches. This is not the most expensive tape, but it has benefits that are better than some of the more expensive ones. I really like the shatter-proof cases. They are made of a hard, but flexibl …"  Read Full Review »
Jul 24 2008
Bownut
Lizella, GA
I am:
  • Aspiring Film Maker
Reviewed at:
Perfectly good tape
4.0
    Pros
  • Durable Design
  • Easy To Use
  • Highly Compatible
    Cons
  • None
    Best Uses
  • Documentaries
  • Shooting Indoors
  • Shooting Outdoors
  • Travel
"I've only had good experiences with this tape shooting on both a Panasonic DVX-100a (SD) and a Sony Z7U (HDV). No drop outs. No color loss.
I've used it in a wide range of weather conditions: super-humid, hot & dry, dusty, below freezing. No problems so far.
I haven't experienced problems with …"  Read Full Review »
Jul 23 2008
Documentary Filmmaker
Maplewood, NJ
I am:
  • Film Professional
Reviewed at:
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
