Panasonic 50" VIERA 720p Plasma Flat Panel HDTV
4.7
based on 7 reviews
from
Ratings Distribution
5 star
5
4 star
2
3 star
0
2 star
0
1 star
0
Category Average
4.6
More Images
Pros
  • Attractive design (5)
  • Great picture quality (5)
  • Easy setup (3)
  • Great sound quality (3)
  • Simple / intuitive controls (3)
  • Durable (2)
  • Fast setup (1)
See less See more
Cons
  • Physical installation (1)
Best Uses
  • Large rooms (3)
  • Movies (3)
  • Bar (1)
  • Home (1)
Provided by B&H Photo Video
With the Panasonic TH-50PX600U 50 16x9 wide HDTV Plasma Monitor you can finally turn your living room into a home entertainment center. Take advantage of HDTV broadcasts coming in through local broadcasts and cable television. Ensure top quality with a high pixel resolution more than 29000000000 colors an extremely impressive 10000:1 contrast ratio and a 3D Y/C Filter. Not only does Panasonic provide you with all the technology you need to have a cinema theater in your own home they also give you convenient features to make your system both sleek and efficient. The HDMI cable transmits digital video and audio data in a single cable thereby cleaning up the cable mess at the back of your system. The CableCard slot eliminates the need for a bulky cable box while the (G-Link) IR Blaster allows you to control your VCR and DVD Recorder via the TV.
Specification Description
Model TH-50PX600U, TH50PX600U
UPC 037988241026
Aspect Ratio 10000:1
Contrast Ratio Yes 16:9
Resolution 1366 x 768
Screen Size 50"
Screen Size 50" to 60"
Select Plasma Units
Panasonic 50" VIERA 720p Plasma Flat Panel HDTV Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: 50" VIERA 720p Plasma Flat Panel HDTV
See all eBay results
  at eBay.com
Product Reviews
Last update: Mar 21, 2007
Panasonic 50" VIERA 720p Plasma Flat Panel HDTV Reviews
Displaying 1 - 5 of 7 Reviews
Show
Sort by
[5 of 5 customers found this review helpful]
Consumer Reports Best Pick
5.0
    Pros
  • Attractive Design
  • Clear Audio
  • Clear Picture
  • Easy Controls
  • Easy To Set Up
    Cons
  • None
    Best Uses
  • None
"Happy wih picture, quality and sound. Problem about 1 week after setup - I got a Poor Quality Signal message which prevented some Digital stations I got before from being viewed. I reran the Auto scan setup for the channels and the stations came back. Since the TV's channel setup has a meter whic …"  Read Full Review »
Was this Plasma TV review on the Panasonic 50" VIERA 720p Plasma Flat Panel HDTV helpful to you?
 Report Abuse  (5)  (0)  0 comments
Jul 28 2006
Tex
Mount Prospect, IL
Reviewed at:
[2 of 2 customers found this review helpful]
Great Plasma For The $
5.0
    Pros
  • Attractive Design
  • Clear Picture
  • Easy Controls
  • Easy To Set Up
    Cons
  • None
    Best Uses
  • Bars
  • Large Rooms
"I actually own the predecessor of this model (TH50PX500U) and it has been a great addition to my home. I have it wall mounted above a bar area and have DVD, HD Satellite and regular satellite hooked up to it. Everything looks good on it (but the HD picture really shines the best).
I can insert a …"  Read Full Review »
 Report Abuse  (2)  (0)  0 comments
Jul 31 2006
Jon
Wilmette, IL
Reviewed at:
[1 of 1 customers found this review helpful]
Beautiful Picture
4.0
    Pros
  • Attractive Design
  • Fast Setup
  • Great Picture
    Cons
  • Physical Installation
    Best Uses
  • Home
  • Movies
"The picture is beautiful - sharp, bright, and clear. Hooking up the HDMI & component video inputs and configuring the selections from the on-screen menus was very easy.
The hardest part was the physical installation of the TV on top of my fireplace mantel. The screw holes in the rear of the pedes …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Dec 27 2006
Jeff
Chicago, IL
Reviewed at:
You are the best
5.0
"i am from canada bought a Panasonic plasma th 50 PX 600u the people at your store were most helpful your great and you're honest and you care about your customer will deal again with you.
Problems Encountered: No Problems at all all is very excellent top store with top product cannot go wrong …"  Read Full Review »
Mar 17 2007
Maurice bert.......
Tillsonburg Ontario canada
Reviewed at:
great tv
5.0
    Pros
  • Attractive Design
  • Clear Audio
  • Clear Picture
  • Durable
    Cons
  • None
    Best Uses
  • Large Rooms
  • Movies
"best picture at this size,maybe the Pioneer is a little better,but save some money.HD cant be beat.50 is good but 58 if you have the space.[...] "
Feb 16 2007
Carlos
chicago,ill
Reviewed at:
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
