Panasonic 32" VIERA G1 Series Black LCD Flat Panel HDTV
#298
5.0
based on 2 reviews
Ratings Distribution
5 star
2
4 star
0
3 star
0
2 star
0
1 star
0
Category Average
4.4
$519.95 - $679.99
from 14 stores
More Images
Pros
  • Attractive design (2)
  • Bright image (2)
  • Good connection options (2)
  • High resolution (2)
  • Simple controls (2)
  • Fast setup (1)
  • Reduced glare (1)
See less See more
Best Uses
  • Bedroom (2)
  • Wall mounting (2)
Provided by photoalley.com
Our new VIERA G1 Series LCDs HDTVs are ideal for sports and gaming, with crisp, focused images during fast-moving scenes.
Smooth, Sharp Motion During Fast-Moving Scenes
Fast on-screen action can challenge an HDTV to maintain smooth motion between frames of video. Our 120Hz Motion Picture Pro3 technology increases the frame count to 120 frames per second, for smooth, natural frame-to-frame transitions. You'll enjoy sharp, clear motion images with high resolution, during all fast sports and gaming action.
Beautiful, Clear Images from Virtually Any Angle
Our IPS Alpha Panel delivers a 178 wide viewing angle with bright, clear images when viewed from most any location in the room. Wherever you're sitting, you've got the best seat in the house.
Share Your Digital Photos on the Big Screen
VIERA Image Viewer provides a better way to share your digital photos. Just pop your SD memory card into the handy slot, and instantly display your digital photos for friends and family to enjoy.
  • 720p Full-HD Resolution
  • 120Hz Motion Picture Pro3
  • Contrast Ratio: 20,000:1
  • IPS Alpha Panel with 178 Wide Viewing Angle
  • Intelligent Scene Controller
  • VIERA Image Viewer
  • VIERA Link
  • PC Input
  • Game Mode
  • 3 HDMI Inputs
  • Swivel Base
  • Narrow Bezel Design
  • Specification Description
    Model TC-L32G1, TCL32G1
    UPC 037988108671
    16:9 Mode Yes
    Audio Controls Bass, treble, balance, sound surround, equalizer, auto volume level
    Battery Type Remote
    Benefits High-defintion 32" (diagonal) screen delivers 1366x768 native resolution for crisp, realistic imagesHDTV compatibility through three
    Capacity UOM mAh
    Channel Labeling Yes
    Chemistry Alkaline
    Closed Caption Capability Yes
    Color Depth 16.7 million colors
    Compliant Standards FCC, cULus,RoHS
    Connections HDMI A/V (3)S-videoComponent video (2)RCA analog audio (4)VGA (1)RCA composite video (1)
    Controls / Adjustments Contrast, Brightness, Sharpness, Color, Tint, Backlight, Default Setting
    Description Header Step up to high-definition.
    Display Catalog Number 55033592
    Display Languages English, Spanish, French
    Display Menu Language English, Spanish, French
    Display Size 31.5 inches
    Enclosure Color Black
    End Product Indicator Yes
    Expansion Slot(s) SD/SDHC
    Image Aspect Ratio 16:9
    Included in the Box Panasonic® VIERA® TC-L32G1 32" LCD HDTVRemote control"AA" batteries (2)Detachable standCleaning cl
    Manufacturer Labor Warranty 12
    Manufacturer Part Number TC-L32G1
    Manufacturer Parts Warranty 12
    MAP Price 0.0
    Max Operating Temperature 104 Fahrenheit
    Min Operating Temperature 32 Fahrenheit
    Model TC-L32G1
    Operating Temperature UOM ° F
    Output Power / Total 20 watts
    Parental controls Yes
    Pixel Response Time 8 ms
    Product Depth 8.6
    Product Dimensions UOM inches
    Product Height 21.3
    Product Type Flat-panel TVs
    Product Weight 29.8
    Product Weight UOM pounds
    Product Width 30.6
    Reception System NTSC/ATSC/QAM
    Screen Size Range 31-40"
    Secondary Audio Program (SAP) Yes
    Size AA
    Sound Output Mode Stereo
    Speaker(s) Built-in, 10W + 10W
    Speakers Included 2 Speakers
    Supported Languages English, Spanish, French
    Technology IR
    TV Diagonal Size 31.5 inches
    TV Image Contrast Ratio 20000:1
    TV Resolution 1366x768
    TV Technology LCD
    Type LCD
    V-Chip Control Yes
    Viewing Angle 178 Degrees
    Viewing Angle (Vertical) 178 Degrees
    Voltage 1.5
    Voltage Required Universal 100~240VAC, 50/60Hz
    Widescreen Modes 480i, 480p, 720p
    Panasonic 32" VIERA G1 Series Black LCD Flat Panel HDTV Questions
    Questions and Answers
    Where to Buy
    $549.88
    $619.00
    BizRate Rating Outstanding 9.4
    $519.95
    No Tax Outside NY
    BizRate Rating Outstanding 9.7
    Show all 14 stores
    Product Reviews
    Last update: May 20, 2009
    Panasonic 32" VIERA G1 Series Black LCD Flat Panel HDTV Reviews
    Displaying 1 - 2 of 2 Reviews
    Show
    Sort by
    [2 of 4 customers found this review helpful]
    Work of Art
    5.0
      Pros
    • Attractive Design
    • Bright Image
    • Good Connection Options
    • Good Resolution
    • Simple Controls
      Cons
    • None
      Best Uses
    • Bedroom
    • Wall Mounting
    "At this price point, this LCD is packed with features you would find on a more expensive unit. With 3 HDMI inputs, 120hz motion picture pro and PC input, this LCD is a bargain. "
    Was this LCD TV review on the Panasonic 32" VIERA G1 Series Black LCD Flat Panel HDTV helpful to you?
     Report Abuse  (2)  (2)  0 comments
    May 6 2009
    Martman
    New Jersey
    I am:
    • Enthusiast
    Reviewed at:
    Price: $549.88
    Excellent 32" LCD
    5.0
      Pros
    • Attractive Design
    • Bright Image
    • Fast Setup
    • Good Resolution
    • More »
      Cons
    • None
      Best Uses
    • Bedroom
    • Wall Mounting
    "This TV is in a bedroom and is a good size for the average b-room. "
    May 20 2009
    RodandApril
    Pasadena,Ca
    I am:
    • Power User
    Reviewed at:
    Price: $619.00
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
