Panasonic 26" VIERA 720p LCD HDTV
4.6
based on 28 reviews
Ratings Distribution
5 star
17
4 star
10
3 star
1
2 star
0
1 star
0
Category Average
4.4
More Images
Pros
  • Attractive design (25)
  • High resolution (23)
  • Bright image (22)
  • Fast setup (21)
  • Reduced glare (18)
  • Simple controls (16)
  • Good connection options (15)
  • Clear picture (3)
  • Great sound quality (3)
  • Simple / intuitive controls (3)
See less See more
Cons
  • Difficult to use (2)
  • Aspect ratio off a little (1)
  • Confusing remote (1)
  • Difficult to set up (1)
  • Lousy remote (1)
  • No pc connectivity (1)
  • Poor connection options (1)
  • Remote control unfriendly (1)
Best Uses
  • Home (18)
  • Movies (13)
  • Video (11)
  • Bedroom (6)
  • Office (6)
  • Kitchen (2)
  • Small rooms (2)
  • Anywhere (1)
  • Bedrfoom tv chest (1)
  • Bedroom tv (1)
Provided by Beach Audio
HDTV and Progressive Scan Capable / Analog Component and HDMI Connectivity / ATSC and NTSC Tuning / 1366x768 Resolution
  • Panasonic TC26LX70 is an LCD widescreen TV that is HDTV capable and priced for your budget. With 170 degree viewing, this remarkable 26 inch widescreen TV delivers up to 1366x768 image Resolution and allows composite, component, and HDMI Connectivity for flexible use. Let's dig a little deeper to see why this set is so superior to anything else in its class. Panasonics Advanced LCD AI technology uses Active Light Control and Active Contrast / Gamma Control functions to produce greater brightness, deeper blacks and superior gradation. In conventional contour correction, Processing is applied at the Pixel level (one pixel is formed by 3 RGB dots). 500 cdm2 Brightness
  • 1366x768 native image resolution
  • HDMI allows fully Digital connectivity and also allows display capability with a compatible PC / Excellent cable management
  • 2 built-in speakers with 3D Virtual-Surround capability
  • Sleep and Off timers
  • Allows V-Chip parental control
  • Video Input labeling
  • On-screen menus in English, French and Spanish
  • Built-in closed-caption decoder
  • Includes Table Stand (wall mountable when used with an Optional wall bracket)
  • 14 millisecond screen response for rapid motion integrity
  • Display Capability: 480p/720p/1080i
  • Composite Video Inputs - 2 Rear / 1 Front
  • S-Video Inputs - 1 Rear / 1 Front
  • Audio Inputs (for Composite/S-Video) - 2 Rear / 1 Front
  • Component Video Input - 1
  • Audio Inputs (for Component Video) - 1
  • Audio Outputs - 1
  • Headphone Jack
  • Unit Dimensions (H x W x D) 18.6'' x 25.9'' x 4.6'' / 36.4 lbs
    Product SpecificationsType of Screen
    | LCDScreen Size (Inches/Diagonal)
    | 26Screen Format
    | 16 9 Widescreen TV ImagingHDTV Capable
    | HD Tuner is included
  • Specification Description
    Model TC-26LX70, TC26LX70
    UPC 037988108411
    Analog Audio Rear Input
    Analog Audio Rear Output
    Analog Audio / Video (3) Rear Input
    Analog Audio / Video Side Input
    Aspect Ratio 16:9
    Brightness 500 cd/m2
    Component Video Rear Input
    Composite Video Rear Output
    Contrast Ratio 3,000:1
    Contrast Ratio 5000:1
    Depth (Inches) 4.6
    Energy Star Compliant Yes
    HDMI (2) Rear Input
    HDTV HDTV Tuner Built In
    HDTV Native Resolution 720p
    Headphone Jack Rear Output
    Height (Inches) 18.6
    Integrated Speakers Yes
    Refresh Frequency 60 Hz
    Resolution 1366 x 768
    S-Video (2) Rear Input
    Screen Size 26"
    Screen Size (inches) 26
    Speakers 10 Watts x 2
    Stand Swivel
    Tuner ATSC
    Tuner NTSC
    Viewing Angle 178 degrees Horizontal
    Viewing Angle 178 degrees Vertical
    Weight (Pounds) 36.4
    Width (Inches) 25.9
    Panasonic 26" VIERA 720p LCD HDTV Questions
    Questions and Answers
    Where to Buy
    Amazon   at Amazon.com
    ebay
    eBay listings for: 26" VIERA 720p LCD HDTV
    See all eBay results
      at eBay.com
    Product Reviews
    Last update: Sep 7, 2008
    Panasonic 26" VIERA 720p LCD HDTV Reviews
    Most helpful positive review
    Most helpful negative review
    5.0
    Very satisfied, delivers as advertised.
    "Very easy installation. Hooked up the cable from the receiver box, plugged in the power, punched the ON button and had a beautiful picture right away. Followed the steps for set up in the manual and was finished in 10 minutes. The image is great, looks good wherever you want to put it, plenty of connection options, controls are logical and easy to use. Cons: the Aspect Ratio seems a little off at the outsid..." Read Full Review »
    Jan 28, 2008 by Chuck
    See more positive Panasonic 26" VIERA 720p LCD HDTV reviews
    3.0
    Costly in my opinion
    "My husband loves Panasonic. He purchases panasonic everything. Most of the things I enjoy also, and see the quality. This one however, I didn't like. It's nothing more than an lcdtv that supports HD resolution. It might sound fancy, but for the same price there are HD LCDtv's out there that are 11" bigger. He wouldn't return it though, and it's now a monitor on his desk. Oh, but what a beautiful monitor..." Read Full Review »
    Jun 09, 2008 by Zoe
    See more negative Panasonic 26" VIERA 720p LCD HDTV reviews
    Displaying 1 - 5 of 28 Reviews
    Show
    Sort by
    5.0
      Pros
    • Attractive Design
    • Bright Image
    • Fast Setup
    • Good Connection Options
    • Good Resolution
    • More »
      Cons
      Best Uses
    • Bedroom
    • Home
    • Movies
    • Office
    • Video
    "Very easy installation. Hooked up the cable from the receiver box, plugged in the power, punched the ON button and had a beautiful picture right away. Followed the steps for set up in the manual and was finished in 10 minutes. The image is great, looks good wherever you want to put it, plenty of …"  Read Full Review »
    Was this LCD TV review on the Panasonic 26" VIERA 720p LCD HDTV helpful to you?
    Jan 28 2008
    Chuck
    Oceanside, CA
    I am:
    • Tech Savvy
    Reviewed at:
    Great value and nice performance.
    4.0
      Pros
    • Aspect choices
    • Attractive Design
    • Bright Image
    • Fast Setup
    • More »
      Cons
      Best Uses
    • Bedrfoom TV chest
    • Home
    • Kitchen
    • Movies
    • Office
    • More »
    "Fits nicely into a bedroom TV chest (armoir) previously housing a 27" crt set. Picture and sound beyond expectations. The screen aspect choices are better than our 37" Hatachi. Remote control not totally user friendly and it's hard to hold. Sleep timer deeply imbedded in Menu sequence, but not a …"  Read Full Review »
    Apr 14 2008
    bkoach2
    Louisville, KY
    I am:
    • Slightly savvy for 62
    Reviewed at:
    Worth it!
    4.0
      Pros
    • Reduced Glare
    • Sound
      Cons
    • Lousy Remote
      Best Uses
    • Bedroom
    "Being a devils' advocate, the most negative comment I can add is the world's worst remote.Location and shape of buttons are counter-intuitive. Sleep timer setting is very cumbersome. On the flip side, I was so impressed with the sound quality. It was much better than anticipated. My old 20" anal …"  Read Full Review »
    Apr 7 2008
    JusticeFood
    Alexandria, VA
    I am:
    • Practical
    • Value Oriented
    Reviewed at:
    Great Value in LCD TV
    5.0
      Pros
    • Attractive Design
    • Fast Setup
    • Good Resolution
    • Simple Controls
      Cons
    • None
      Best Uses
    • Home
    • Movies
    "I've owned a number of Panasonic products and been very happy. This TV continues that trend. The setup was very simple and the remote is easy to learn. The sound is awesome. Very rich with deep bass tones. I don't have HD cable, so I was a bit concerned about the SD picture, but it's fine. The di …"  Read Full Review »
    May 19 2008
    Keith
    Souderton, PA
    I am:
    • Tech Savvy
    Reviewed at:
    [1 of 1 customers found this review helpful]
    Very Good TV with Awsome colors
    4.0
      Pros
    • Clear Audio
    • Clear Picture
    • Easy Controls
    • Easy To Set Up
      Cons
    • No PC Connectivity
      Best Uses
    • Dorm Rooms
    • Office
    • Small Rooms
    "Very Good TV with Brilliant colors and deep blacks. I compared it to Sony, Toshiba, Sharp and Samsungs top 26 inch models and this had better and sharper colors. Price was not a major issue for me, I just wanted a good quality picture so I asked them to put the TV's side by side and play the same m …"  Read Full Review »
     Report Abuse  (1)  (0)  0 comments
    May 31 2007
    MC
    Chicago, IL
    I am:
    • Professional
    • Tech Savvy
    Reviewed at:
    pages: 1 2 3 4 5 Next »
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    ebay
      at eBay.com
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
