Close Login Module
Join
Panasonic 1.9Ghz DECT 6.0 Expandable Cordless Phone System with Four Handsets (Model #KX-TG1034S)
#3
4.2
based on 139 reviews
Ratings Distribution
5 star
122
4 star
88
3 star
12
2 star
11
1 star
14
Category Average
3.8
$37.00 - $99.98
from 15 stores
More Images
Pros
  • Nice features (141)
  • Comfortable handset (139)
  • Easy setup (117)
  • Nice sound (105)
  • Strong signal (98)
  • Good speakerphone (88)
  • Compact design (84)
  • Wide range (74)
  • Attractive design (38)
  • Good sound quality (37)
See less See more
Cons
  • Poor sound quality (17)
  • Limited range (10)
  • Creates static (7)
  • Lacks features (7)
  • Not durable (5)
  • Weak signal (5)
  • Poor battery life (3)
  • Always have a landline (1)
  • Answer machine defective (1)
Best Uses
  • Everyday (109)
  • Home use (90)
  • Outdoors (31)
  • Office (24)
  • Long talks (22)
  • Conference calls (9)
  • Telecommuting (8)
  • High call volume (5)
  • Speaker phone (2)
Where to Buy
$37.00
$38.99
BizRate Rating Outstanding 9.1
$39.00
Show all 15 stores
Product Reviews
Last update: Oct 31, 2009
Panasonic 1.9Ghz DECT 6.0 Expandable Cordless Phone System with Four Handsets (Model #KX-TG1034S) Reviews
Most helpful positive review
[129 of 131 customers found this review helpful]
Most helpful negative review
4.0
This is the best phone I have ever purch
"This product won my heart over so many phones I have owned. I have tried Vtech, Unidon, ATT. I am still using AT&T phone in two of my rooms. When I purchase that 3 years ago It costed me a fortune. It is still working good but it is lacking some features which panasonic has most of them. The feature of transfering your Address book to another phone in just a touch of a button & to be able to hear the messages f..." Read Full Review »
Jun 18, 2008 by DJ
See more positive Panasonic 1.9Ghz DECT 6.0 Expandable Cordless Phone System with Four Handsets (Model #KX-TG1034S) reviews
3.0
DECT 5.8 was better
"you stop hearing yourself while talking into the handset then you start hearing yourself, makes you think that you lost the connection. Not bad weather friendly! Will disconnect when lighting is around. battery definitely does not last as long as they say!, this is good for a second phone not a primary one, always have a landline for everyday use..." Read Full Review »
Jul 30, 2009 by Staten Island,NYC Travel Guy
See more negative Panasonic 1.9Ghz DECT 6.0 Expandable Cordless Phone System with Four Handsets (Model #KX-TG1034S) reviews
Displaying 1 - 5 of 139 Reviews
Show
Sort by
[1 of 1 customers found this review helpful]
Good phone system
4.0
    Pros
  • Ans machine integrated
  • Attractive Design
  • Comfortable Handset
  • Good battery life
  • Good Sound Quality
  • More »
    Cons
  • Base-not near window
  • Can't turn off ringers
  • Programming a bit hard
    Best Uses
  • Intercom
"I bought this phone to replace a set of cordless phones that gave up, like previous ones, mainly because of the battery failures. The replacements were so expensive that I thought I'd try the new generation. So far (2 months), it's doing great on that front. The one big problem we had was a loud …"  Read Full Review »
Jan 29 2008
Northwesterner
Pacific Northwest
I am:
  • Value Oriented
Reviewed at:
Price: $39.00
Great Cordless Phone
5.0
    Pros
  • Attractive Design
  • Nice Features
    Cons
  • None
    Best Uses
  • Long Talks
"The Dect 6.0 Panasonic is my first cordless phone.This phone has great sound, no interference from the computer or microwave. I especially like the Speaker Phone and it comes with easy instructions for setup. The SP allows me to multitask while talking on the phone. My family and friends said they c …"  Read Full Review »
Jan 3 2008
SandRat
Upper Marlboro, Maryland
I am:
  • Quality Oriented
Reviewed at:
Price: $39.00
What a de-stresser item
5.0
    Pros
  • Compact design
  • Easy To Set Up
  • Good Sound
  • Good Speakerphone
  • More »
    Cons
  • None
    Best Uses
  • Everyday Use
  • Home Use
  • Multi locations of phone
  • Outdoors
"The quantity of handsets makes this the most practical house phone I've ever owned. Not only did I buy a set for myself, I got a set for my 89yr old mother and she LOVES them!!! She never has to look for the phone. There's one or sometimes two at hand at all times. No matter what room we are in we c …"  Read Full Review »
Aug 9 2009
Gramma the Multi-tasker
Three Rivers, MI
I am:
  • Value Oriented
[3 of 4 customers found this review helpful]
Very Good Phones
4.0
"I used to own Panasonic cordless phones yeards ago and had problems. I currently own the AT&T; 2440 2.4Ghz model and has worked well for us for the past few years. Now that we have a wireless network, baby monitor, SIDS monitor, microwave, wireless musical equipment, etc. the DECT 6.0 makes the most …"  Read Full Review »
Aug 26 2007
rpeavey24
Huntley, IL
Reviewed at:
Price: $49.99
This was the right choice
5.0
    Pros
  • Easy To Set Up
  • Good Sound
  • Good Speakerphone
  • Strong Signal
  • More »
    Cons
  • None
    Best Uses
  • Everyday Use
  • Home Use
"I needed to replace a product that used special rechargeable batteries that did not provide enough talk time. This was the one product that did the job. I was looking for value and other Panasonic models did not give me the functionality for the price.
I did not need certain features and could li …"  Read Full Review »
May 27 2009
Nikunj
Sugar Land, TX
I am:
  • Value Oriented
Reviewed at:
Price: $39.00
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
$37.00
$38.99
$39.00
BizRate Rating Outstanding 9.4
$39.00
5% off orders at Abt.com
$39.00
$39.99
$42.99
$49.97
$49.99
$53.99
BizRate Rating Outstanding 9.3
$69.99
$69.99
$72.99
BizRate Rating Outstanding 9.0
$93.94
$99.98
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
