Panamax MAX 5300-PM Home Theater Power Management
4.8
based on 14 reviews
from $417.00 - $499.99
Ratings Distribution
5 star
12
4 star
1
3 star
1
2 star
0
1 star
0
Category Average
4.1
More Images
Pros
  • Durable (5)
  • Good cord length (5)
  • Great protection (5)
  • Warranty (4)
  • Confusing / difficult controls (2)
  • Easy setup (2)
  • Great sound quality (2)
  • Interfaces well with tv (2)
  • Lightweight (1)
See less See more
Best Uses
  • Audio equipment (5)
  • High-end equipment (5)
  • Tv's (4)
  • Living room (2)
  • Movies (2)
  • Computers (1)
  • Large rooms (1)
  • Smaller rooms / apartments (1)
  • Surround sound solution (1)
  • Television shows (1)
Provided by OneCall
Improves Picture and Sound Quality
Level 4 power cleaning and filtration eliminates common symptoms of contaminated power (including loss of detail, pops, hisses, hums and visual artifacts) and allows you`re a/V equipment to perform up to its full capability.
Monitors Incoming Line Voltage and Provides a Visual Indication of Power Level
Panamax's patent pending AVM circuitry continuosly monitors the incoming power as displayed on the digital voltmeter. In case of an undervoltage or an overvoltage, a flashing lightning bolt will be displayed in red in the voltmeter, and power to the connected equipment is automatically turned off if either of these conditions is detected. When voltage returns to a safe level, power to the equipment is automatically reconnected.
Reduces Cross-Contamination Between Components
The M5300-PM is designed to provide noise isolation between 5 isolated outlet banks (including 1 bank with 2 high current outlets) so that any noise created by an A/V component cannot contaminate the power going to equipment plugged into another outlet bank.
Specification Description
Model M5300-PM, M5300PM, PMXM5300PM
UPC 050616008167
12V Trigger (1) Rear Input
12V Trigger (1) Rear Output
AC Outlets 11
Connected Equipment Warranty $5,000,000
Cord Length 10 Feet
Depth (Inches) 12.75
Height (Inches) 3.5
Joule Rating 2125
RF (3) Rear Input
RF (3) Rear Output
RJ45 Ethernet (1) Front Output
RJ45 Ethernet (1) Rear Output
RJ45 Ethernet (2) Rear Input
Telephone Line (RJ11) (1) Rear Input
Telephone Line (RJ11) (1) Rear Output
Weight (Pounds) 30
Width (Inches) 17
Panamax MAX 5300-PM Home Theater Power Management Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Apr 27, 2009
Panamax MAX 5300-PM Home Theater Power Management Reviews
Most helpful positive review
Most helpful negative review
4.0
Panamax Power!
"I connect everything through the Panamax. So far it works great. No complaints...." Read Full Review »
Feb 10, 2009 by Shane
See more positive Panamax MAX 5300-PM Home Theater Power Management reviews
3.0
Good, but not worth 5 Stars or $500
"I've had this unit for about 2 weeks now. Looking at the functionality, it has two main features. They are power conditioning and surge protection. I can't tell if there is any "power conditioning" going on, as everything looks and sounds the same as my older Monster Power Center. Nothing is worse though. I'm sure it's protecting my equipment and if it's not there is a great warranty and protection plan. What I ..." Read Full Review »
Nov 21, 2008 by cimpala
See more negative Panamax MAX 5300-PM Home Theater Power Management reviews
Displaying 1 - 5 of 14 Reviews
Show
Sort by
Panamax Power!
4.0
    Pros
  • Clear Sound
  • Easy To Setup
  • Interfaces Well With TV
  • Intuitive Controls
    Cons
  • None
    Best Uses
  • Living Room
  • Movies
  • Surround Sound Solution
  • Television Shows
"I connect everything through the Panamax. So far it works great. No complaints. "
Was this Home Theater review on the Panamax MAX 5300-PM Home Theater Power Management helpful to you?
Feb 10 2009
Shane
CA
I am:
  • Audiophile
  • Tech Savvy
Reviewed at:
Price: $499.99
[2 of 2 customers found this review helpful]
Home Theater System Must
5.0
    Pros
  • Durable Construction
  • Good Cord Length
  • Good Warranty
  • Great Protection
    Cons
  • None
    Best Uses
  • Audio Equipment
  • High-End Equipment
  • TV's
"I purchased the Panamax to provide protection and power filtering for my new 60" Pioneer PDP-6020FD. I also have the Panamax providing power to a Harmon Kardon receiver, Motorola STB and a DVD player. I didnt want to take a chance with power problems (surge, spikes, over and under voltage) or dirty …"  Read Full Review »
 Report Abuse  (2)  (0)  0 comments
Sep 23 2008
Southern Cross
Rowlett, Texas
I am:
  • Tech Savvy
Reviewed at:
Great Product!!
5.0
    Pros
  • Good Cord Length
  • Good Warranty
  • Great Protection
    Cons
  • None
    Best Uses
  • Audio Equipment
  • TV's
"I have my Panamax 5300-PM hooked up to my Plasma TV, Xbox 360, PS3, Wii, Sat. Receiver, and surround sound receiver. This thing rocks!! It does it's job very well and gives me that wonderful piece of mind. People spend thousands of dollars on home theater equipment but don't bother protecting it. …"  Read Full Review »
Nov 11 2008
Chris O.
Peoria, IL
I am:
  • Professional
Reviewed at:
3.0
"I've had this unit for about 2 weeks now. Looking at the functionality, it has two main features. They are power conditioning and surge protection. I can't tell if there is any "power conditioning" going on, as everything looks and sounds the same as my older Monster Power Center. Nothing is worse t …"  Read Full Review »
Nov 21 2008
cimpala
Boston, MA
Reviewed at:
Price: $499.99
Protection at its finest
5.0
    Pros
  • Good Cord Length
  • Good Warranty
  • Great Protection
    Cons
  • None
    Best Uses
  • Audio Equipment
  • TV's
"Comfort knowing that the Panamax 5300-PM is protecting my home theatre equipment. Isolated banks really do help to clean up picture. A great product that look very sleek in any entertainment center. A must have for anyone looking to protect there A/V purchase. "
Jan 12 2009
Stu
Cabot, AR
I am:
  • Tech Savvy
Reviewed at:
Price: $499.00
pages: 1 2 3 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
