Panamax Black Home Theater Power Management System
4.7
based on 19 reviews
from $79.80 - $149.95
Ratings Distribution
5 star
13
4 star
5
3 star
0
2 star
0
1 star
0
Category Average
4.1
Low Price:
$79.80 at Vanns.com
 Trusted:
$79.99 at Crutchfield
$79.95 at OneCall
see all stores
More Images
Pros
  • Durable (7)
  • Good cord length (6)
  • Great protection (6)
  • Easy setup (4)
  • Warranty (4)
  • Great sound quality (3)
  • Interfaces well with tv (2)
  • Compact design (1)
  • Compact size (1)
  • Confusing / difficult controls (1)
See less See more
Best Uses
  • Audio equipment (5)
  • Tv's (5)
  • High-end equipment (4)
  • Computers (2)
  • Large rooms (2)
  • Surround sound solution (2)
  • Home (1)
  • Television shows (1)
Provided by OneCall
Improves Picture and Sound Quality
The M8-HT-PRO's Power Cleaning and Premium Filtration eliminate common symptoms of contaminated power (including loss of detail, pops, hisses, hums and visual artifacts) and allows your A/V equipment to perform up to its full capability.
Monitors Incoming Line Voltage
Panamax's patent pending AVM circuitry continuously monitors the incoming line voltage and disconnects your equipment in the event of an over voltage or under voltage (brownout). Power is automatically reconnected when voltage returns to a safe level, eliminating service calls or system downtime.
Reduces Cross-Contamination Between Components
The M8-HT-Pro is designed to provide noise isolation between the two isolated outlet banks so that any noise created by an A/V component in one bank cannot contaminate the power to the equipment that is plugged into the other outlet bank.
Premium Filtration
Improves Picture and Sound. Provides clean power by filtering out noise common to household power.
AVM (Automatic Voltage Monitoring)
Protects equipment against prolonged over/ under voltages by disconnecting the power and reconnecting it when safe power returns.
Coax/Sat Protection
Protects equipment from electrical surges that travel over Cable, Satellite, and Antenna lines.
12 Volt Trigger
Allows source equipment to activate or deactivate outlets 5-8 on the M8-HT-PRO.
Telephone/LAN Line Protection
Protects equipment from electrical surges that travel over Telephone and network lines.
8 Outlets
4 Balanced Double L Filtration Circuit Outlets, 4 High Current Outlets.
Surge Protection
Exclusive Protect or Disconnect circuitry. In the event of a catastophic surge such as lightning, it completely disconnects AC power to connected equipment
Hi Def Ready
Hi-Def Designed to work with your High Definition system.
Specification Description
Model M5400-PM, M5400PM, M8-HT-PRO, M8HT-PRO
UPC 050616008150
12V Trigger (1) Rear Input
12V Trigger (1) Rear Output
AC Outlets 11
AC Outlets 8
Connected Equipment Warranty $5,000,000
Cord Length 10 Feet
Cord Length 8 Feet
Depth (Inches) 12.75
Depth (Inches) 6
Height (Inches) 2
Height (Inches) 3.5
Joule Rating 2125
Power Cord 8 Feet
RF (3) Rear Input
RF (3) Rear Output
RJ45 Ethernet (1) Front Output
RJ45 Ethernet (1) Rear Input
RJ45 Ethernet (1) Rear Output
RJ45 Ethernet (2) Rear Input
Telephone Line (RJ11) (1) Rear Input
Telephone Line (RJ11) (1) Rear Output
Weight (Pounds) 36
Weight (Pounds) 4
Width (Inches) 12.5
Width (Inches) 17
Panamax Black Home Theater Power Management System Questions
Questions and Answers
Where to Buy
$149.00
BizRate Rating Outstanding 9.4
$79.95
BizRate Rating Outstanding 9.1
$79.80
BizRate Rating Outstanding 9.2
Show all 7 stores
_
Product Reviews
Last update: Oct 21, 2009
Panamax Black Home Theater Power Management System Reviews
Displaying 1 - 5 of 19 Reviews
Show
Sort by
[3 of 3 customers found this review helpful]
Nice and Secure Protector
4.0
"Bought it because of the new lcd tv 52", and having home theater system plus the deskopt hooked up to one place. In total I have hooked to the power conditioner the tv, receiver, media player, dvd player, cable set top box, pc, phone, and another small power surge protector . The nice feature is the …"  Read Full Review »
Was this Home Theater review on the Panamax Black Home Theater Power Management System helpful to you?
 Report Abuse  (3)  (0)  0 comments
Feb 12 2008
Pleasanton, CA
Reviewed at:
Price: $79.98
Great power conditioner and great price
5.0
    Pros
  • Clear Sound
  • Easy To Setup
  • Interfaces Well With TV
    Cons
  • None
    Best Uses
  • Larger Rooms
  • Surround Sound Solution
  • Television Shows
"A must have for costly home theater system. The 5 million dollar guarantee sold me. If your system fries and the Panamax failed, they replace everything. Plus, it removes the static from household appliances, voltage flucuations, etc. Crucial to maximizing your enjoyment from the system.
Make sure …"  Read Full Review »
May 26 2009
T bone
Columbus, Ohio
I am:
  • Practical
  • Technically Challenged
Reviewed at:
Price: $79.95
4.0
Feb 12 2008
Pleasanton, CA
Reviewed at:
Price: $79.98
M5400 line conditioner
5.0
"Gauges voltages accurately. There is a noticable difference in the audio. Less interference, less static. Virtually elimates all nosie in the video. The picture especially in formats of 1080p has a crystal, lifelike image. Best product on the market for the money. "
Jan 13 2008
jamwall42
New Jeresy
Reviewed at:
Price: $79.98
Glad I bought it
5.0
    Pros
  • Durable Construction
  • Good Warranty
  • Great Protection
    Cons
  • None
    Best Uses
  • Audio Equipment
  • TV's
"Not sure if my area of the Midwest has voltage issues, but after reading about the potential for problems, I am glad I have it protecting my new HDTV, Bluray and receiver. Its appearance is so sleek. I preferred its look over the Monster products, which seemed too flashy (for my taste). [...] "
Jul 26 2009
irish 54
Eagan, MN
I am:
  • Tech Savvy
Reviewed at:
Price: $79.95
pages: 1 2 3 4 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
