Outstandin Cmw178 23''-40'' Articulating Flat Panel Wall Mount
4.4
based on 9 reviews
from $69.99
Ratings Distribution
5 star
4
4 star
5
3 star
0
2 star
0
1 star
0
Category Average
4.4
$69.99 at Sears
Find it at Amazon
Find it at Ebay
Pros
  • Interfaces well with tv (8)
  • Sturdy (8)
  • Adjustable (6)
  • Easy to install (6)
  • Can support weight (5)
  • Multiple viewing angles (2)
  • Awesome (1)
  • Can support 35lbs easily (1)
  • Easy setup (1)
  • Easy to use (1)
See less See more
Cons
  • Bad assembly directions (1)
  • Instruction was not clear (1)
  • No instructions (1)
  • Poor instructions (1)
  • Tilt adjustment awkward (1)
Best Uses
  • Bedroom (5)
  • Changing viewing angle (5)
  • Family/living room (5)
  • Home (5)
  • Office (2)
  • New lcd wall mount (1)
Provided by Beach Audio
  • For VESA mounting, 50 x 50, 75 x 75, 100 x 100, 100 x 200, 200 x 200, and 400 x 200mm
  • Adjustable tilt: 5 degree up and 20 degree down
  • Maximum load capacity: 88lbs (40kg)
  • Flat Panel size: 23 inches to 40 inches
  • Wall clearance: 5.5 inches to 31 inches
  • Outstandin Cmw178 23''-40'' Articulating Flat Panel Wall Mount Questions
    Questions and Answers
    Where to Buy
    $69.99
    Code SEARS5OFF50 : $5 Off Orders Over $50!
    Product Reviews
    Last update: Oct 31, 2009
    Outstandin Cmw178 23''-40'' Articulating Flat Panel Wall Mount Reviews
    Displaying 1 - 5 of 9 Reviews
    Show
    Sort by
    Perfect extension length for 270 rotate
    5.0
      Pros
    • Can Support Weight
    • Easy To Adjust
    • Easy To Install
    • Interfaces Well With TV
    • Sturdy
      Cons
    • None
      Best Uses
    • Bedroom
    • Changing Viewing Angle
    • Family/Living Room
    • Home
    • Office
    "I bought this exclusively because the extension is long enough to mount the support on an outside corner of a wall and then fold the TV flat against wall. This allows swinging for almost 270 degrees of rotation (TV can be viewed from two maybe 3 rooms). I was also very pleased by the quality and st …"  Read Full Review »
    Was this TV Wall Mount review on the Outstandin Cmw178 23''-40'' Articulating Flat Panel Wall Mount helpful to you?
    Oct 31 2009
    Craig
    Milwaukee, WI
    I am:
    • Enthusiast
    Reviewed at:
    Almost Outstanding Outstandin
    4.0
      Pros
    • Easy To Install
    • Great Price
    • Very sturdy
      Cons
    • No instructions
      Best Uses
    "Great unit for the price. However, the tilt must be adjusted by using an Allen wrench. It would be easier to have a knob.
    My unit did not come with instructions. I emailed two people listed on Outstandin's website. One told me he was only a distributor and that I should do a web search. I did …"  Read Full Review »
    Sep 12 2009
    gibeau
    New York
    I am:
    • Casual User
    Reviewed at:
    GOOD PRICE - GOOD PRODUCT
    4.0
      Pros
    • Easy To Adjust
    • Easy To Install
    • More »
      Cons
    • Poor instructions
      Best Uses
    • Bedroom
    • Home
    "This is a good product for the price. It's well made, heavy duty, and looks very nice and functions well after installation. The only con I have is that there were no actual installation instructions, only an exploded view of the hardware. Otherwise a good product. "
    Oct 20 2009
    New LCD owner
    Texas
    I am:
    • Casual User
    Reviewed at:
    Item worth way more than what you pay!
    5.0
      Pros
    • All around awesome
    • Easy To Adjust
    • Easy To Install
    • More »
      Cons
    • none
      Best Uses
    • Bedroom
    • Home
    • Office
    "I use the product for a 32" lcd in my bedroom. Which awesome because it's easier to adjust the viewing angle of the tv then to angle the bed in the room. "
    Sep 1 2009
    Kevin the Awesome
    Hanover, Pa
    I am:
    • Enthusiast
    Reviewed at:
    No mounting instructions
    4.0
      Pros
    • Easy To Adjust
    • Sturdy
      Cons
    • None
      Best Uses
    • Bedroom
    • Home
    "The box arrived broken with loose parts falling out of it and missing. No instructions were included.
    It is a great product, though. Very sturdy and easy to handle. Makes rear hook-ups easy. "
    Jun 29 2009
    durban
    Milwaukee, WI
    I am:
    • Casual User
    Reviewed at:
    pages: 1 2 Next »
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
