Orbital SuperClamp TV Wall Mount Combo w/VCR/DVD Mount for 19"-27" TVs
#423
4.4
based on 23 reviews
Ratings Distribution
5 star
12
4 star
9
3 star
2
2 star
0
1 star
0
Category Average
4.4
Low Price:
$72.00 at CSN Stores
 Trusted:
$72.00 at Mounts and More
Find it at Amazon
$72.00
from 4 stores
More Images
Pros
  • Adjustable (15)
  • Easy to install (14)
  • Interfaces well with tv (14)
  • Sturdy (14)
  • Multiple viewing angles (12)
  • Cable box holder stinks (1)
  • Clever design (1)
  • Value (1)
See less See more
Cons
  • Poor interface with tv (2)
  • Cable box hold is wobbly (1)
  • Check base tv size (1)
  • Dvd static with position (1)
  • Flimsy (1)
  • Limited adjustability (1)
  • Need about 22" above tv (1)
  • Nothing bad to add (1)
  • Poor assembly instructions (1)
Best Uses
  • Bedroom (9)
  • Classroom (6)
  • Office (6)
  • Changing viewing angle (4)
  • Home (4)
  • Workout room (1)
Provided by CSN Stores
SuperClamp Wall Mount Combo w/VCR/DVD Mount has a revolutionary "clamp design", clean appearance, and quick and easy installation which makes it a favorite with the consumer. Ideal for recreation rooms, dens, offices, home entertainment centers, game rooms, etc. It also is a great application for commercial use such as Hotels, Restaurants, Retail Stores, Schools and Hospitals.
Features:
  • For 19"-27" TVs.
  • Exclusive clamp design holds TV securely in place.
  • Arm rotates 120 degrees at wall for maximum adjustability.
  • Cross bar added for additional reinforcement.
  • Platform slots for mounting TV.
  • Platform tilts 10 degrees creating perfect viewing from all angles.
  • Over-sized, heavy duty back plate provides greater holding power.
  • Reinforced steel tubing for added strength.
  • TV Mount Accommodates up to 130 lbs.
  • Includes stackable VCR/DVD mount.
  • VCR/DVD mount has a sleek and stackable design and can pivot 180 degrees independently from the television wallmount.
  • VCR/DVD Mount accommodates up to 20 lbs.
Orbital SuperClamp TV Wall Mount Combo w/VCR/DVD Mount for 19"-27" TVs Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Jun 5, 2008
Orbital SuperClamp TV Wall Mount Combo w/VCR/DVD Mount for 19"-27" TVs Reviews
Most helpful positive review
Most helpful negative review
4.0
Reasonable Option for TV
"It pretty much worked as promised. The problem I had was with installation. I asked both CSN store and the manufacturer for dimensions or a brochure and neither one sent me anything. It turns out you need a significant amount of clearance over the TV before you can attach it to the wall. I think this was about 22 inches. With a low ceiling, the TV for us ended near the reach of our kids, which defeated the ..." Read Full Review »
Jun 05, 2008 by SH in Seattle
See more positive Orbital SuperClamp TV Wall Mount Combo w/VCR/DVD Mount for 19"-27" TVs reviews
3.0
Everthink worked fine but...
"The clamp or attachment design for the cable or satellite box has no means of really being stable. It's design is screwed to the main tube with nothing to square of against so it kinda swings off kilter at the slightest touch. The result is a slightly dissatisfying, un level cheapness. The TV holder itself is pretty well made and does the job fine of holding these heavy CRT's with no problem. Also would have li..." Read Full Review »
May 27, 2008 by Chris
See more negative Orbital SuperClamp TV Wall Mount Combo w/VCR/DVD Mount for 19"-27" TVs reviews
Displaying 1 - 5 of 23 Reviews
Show
Sort by
4.0
    Pros
  • Interfaces Well With TV
  • Multiple Viewing Angles
  • Sturdy
  • Value
    Cons
  • Limited Adjustability
  • Need about 22" above TV
    Best Uses
  • Home
  • Office
"It pretty much worked as promised. The problem I had was with installation. I asked both CSN store and the manufacturer for dimensions or a brochure and neither one sent me anything. It turns out you need a significant amount of clearance over the TV before you can attach it to the wall. I think …"  Read Full Review »
Was this TV Wall Mount review on the Orbital SuperClamp TV Wall Mount Combo w/VCR/DVD Mount for 19"-27" TVs helpful to you?
Jun 5 2008
SH in Seattle
Seattle, CA
I am:
  • Practical
  • Tech Savvy
Reviewed at:
Price: $72.00
very good product
5.0
    Pros
  • Easy To Adjust
  • Easy To Install
  • Sturdy
    Cons
  • Tv base does not swiwel
    Best Uses
  • Office
"everything was perfect, until the time came for me to move the arm back around 90 degrees, in other to avoid moving the whole unit and having multiple holes on my wall and tilt the position of the tv towards the other opposite side.Similar to moving forward- and turning around on the same spot.But t …"  Read Full Review »
Jul 18 2007
Lillianna the Best!
Orlando, Florida
I am:
  • Professional
Reviewed at:
Price: $72.00
3.0
    Pros
  • Easy To Install
  • Sturdy
    Cons
  • Flimsy
    Best Uses
  • None
"The clamp or attachment design for the cable or satellite box has no means of really being stable. It's design is screwed to the main tube with nothing to square of against so it kinda swings off kilter at the slightest touch. The result is a slightly dissatisfying, un level cheapness. The TV holde …"  Read Full Review »
May 27 2008
Chris
Miami FL
Reviewed at:
Price: $72.00
Doesn't work for all TVs
3.0
    Pros
  • Easy To Adjust
  • Easy To Install
  • Sturdy
    Cons
  • Poor Interface With TV
    Best Uses
  • None
"The clamp has a relatively small lip on it, so it will only work well with TVs that have a very sharp corner on the top edge. My TV has a rounded, beveled edge, and the clamp kept slipping off (almost sending my TV crashing to the ground). In the end, I had to take the clamp out to the shop, strai …"  Read Full Review »
Jun 12 2007
Dave
Austin, Tx
I am:
  • Tech Savvy
Reviewed at:
Price: $72.00
Perfect for the task at hand
5.0
    Pros
  • Easy To Adjust
  • Easy To Install
  • Sturdy
    Cons
  • None
    Best Uses
  • Classroom
"I purchased this tv mount for use in a classroom that has small children attending. I wanted a product that was practical, economical, and sturdy. I am very pleased with how this product looks with our tv mounted on it. It was very easy to install and it performs great. "
Mar 10 2008
Mark
Litchfield, NH
I am:
  • Practical
Reviewed at:
Price: $72.00
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
