Onkyo TX-SR706S Home Theater Receiver (Silver)
4.8
based on 21 reviews
from
Ratings Distribution
5 star
17
4 star
4
3 star
0
2 star
0
1 star
0
Category Average
4.3
More Images
Pros
  • Great sound quality (28)
  • Easy setup (18)
  • Accurate controls (12)
  • Durable (9)
  • Good power output (9)
  • Attractive design (7)
  • Audyssey makes it easy (1)
  • Faroudja 1080p upscaling (1)
  • Feature laden (1)
  • Flexible (1)
See less See more
Cons
  • Gounding screw inop (1)
  • Lack of power (1)
  • Runs hot (1)
Best Uses
  • Home theater (14)
  • Large rooms (10)
  • Entertainment (7)
  • Basic systems (3)
  • Production quality (2)
  • Smaller rooms / apartments (2)
  • Music collection (1)
Provided by OneCall
THX Select2 Plus Certified with New THX Loudness Plus Technology
THX Select2 Plus certification, with THX Loudness Plus, ensures the TX-SR706 is ideally suited for a room where the screen-to-seat viewing distance is approximately 10 to 12 feet, and the room size is approximately 2000 cubic feet. By achieving THX Select2 Plus certification, the TX-SR706 meets the world`s most demanding home theater standards for audio quality and performance, and promises to play at reference volume levels with minimal distortion. Also, a new technology,THX Loudness Plus, improves how you experience movies at lower volume levels.To counteract the loss or distortion of ambient and bass sounds at lower volumes,THX Loudness Plus automatically adjusts the front-to-back speaker levels and frequency balance.This ensures that you can experience all the details of your movies when listening below the reference level.
Processing 1080p Video and High-Def Surround Sound
via HDMI™ With the latest HDMI version and advanced A/V processing capabilities, the TX-SR706 is a powerful control center for all highdefinition media, including Blu-ray Disc and HD broadcasts. You can connect up to four components via HDMI to receive and switch compatible sources and send a 1080p video signal to an HDTV. On the audio side, you have onboard high-definition surround sound codecs—Dolby TrueHD® and DTS-HD™ Master Audio—enabling lossless, studiomaster audio quality from Blu-ray Disc.This version of HDMI also supports Onkyo`s RIHD system control function and provides greater bandwidth to deal with higher resolutions, 36-bit Deep Color™, and high frame rates.
HDMI Video Upscaling (Up to 1080p) with Faroudja
DCDi Cinema (Directional Correlational Deinterlacing) Technology The Faroudja DCDi Cinema video processor takes the TX-SR706 into a higher class when it comes to video processing. Its power lies in its ability to take all video signals, regardless of the input, and upscale them up to 1080p.You simply select the desired resolution via the TX-SR706`s set-up menus to match the resolution of your display. Upscaling takes the video resolution to full HD quality, so it better matches the native resolution of today`s high-definition displays. Faroudja video processors are synonymous with quality, and DCDi Cinema effectively removes video artifacts during the video signal deinterlacing process.
Correcting Room Acoustics and Loudness with Audyssey
MultEQ™ and Audyssey Dynamic EQ™ Audyssey MultEQ is a powerful built-in solution for countering distortion in dedicated home theaters.This technology detects speakers, and then sets levels, delays and crossovers, as well as measuring room acoustics. Using the TX-SR706`s set-up menu, it takes up to six measurements around the listening area and uses high-resolution equalization filters for satellites and the subwoofer. MultEQ covers both the frequency response and the time domain (where most of the problems lie) across the entire listening area. The results are immediately obvious—a clear, well-balanced and natural sound. After calibration, Audyssey Dynamic EQ solves the problem of deteriorating sound quality at lower volumes. Dynamic EQ selects the best possible frequency response and surround levels moment-by-moment, resulting in an ideal listening experience at any volume level.
Push-Pull Amplification Design with Three-Stage Inverted Darlington Circuitry
The TX-SR706`s push-pull amplification design uses different transistors on each channel to separately amplify the positive and negative halves of the waveform. Meanwhile, three-stage inverted Darlington circuitry helps reduce distortion at the output stage. The whole design works to realize a highly efficient drive capability. RIHD (Remote Interactive over HDMI) for System Control. The TX-SR706 offers integrated system control with selected HDMI-compatible high-definition displays, DVD and hard disk recorders, and Blu-ray Disc players. With one remote control, you can control several functions, including Standby,Volume Command, and Direct
Change. RIHD lets you seamlessly integrate the TX-SR706 with other leading brand-name devices, including those with Panasonic VIERA Link and Toshiba CE-Link capability, and selected Sharp displays.
*Compatibility depends on respective model.
*Panasonic VIERA Link is the new name for EZ Sync.
Two High-Quality Texas Instruments Digital Signal Processing (DSP) Chips
The TX-SR706 assigns two Texas Instruments (Aureus™) DSP chips to handle the greater processing requirements of Dolby TrueHD and DTS-HD Master Audio, Audyssey MultEQ, and post-processing.
Cirrus Logic Digital-to-Analog Converters (DACs) for Highly Precise Audio
You will find top-quality Cirrus Logic DACs included in the TX-SR706 to push analog audio performance to even greater levels.These DACs offer 24-bit conversion and support sampling rates of up to 192 kHz, while
displaying high resistance to clock jitter and offering a 120 dB dynamic range.
Music Optimizer to Support Compressed Digital Music Files
While MP3 or AAC files may sound fine on a portable digital player, the limitations of these compressed files can be exposed when played back through a home entertainment system. Onkyo has designed onboard Music Optimizer technology to improve the quality of compressed audio signals. Compressed music loses a substantial amount of bit information at higher frequencies, so the Music Optimizer technology works to overcome this limitation and enhance audio quality.
XM Satellite Radio and SIRIUS Satellite Radio Programming
By using the ports on the TX-SR706's rear, it's possible to access both XM and Sirius Satellite Radio. XM Satellite Radio offers 170 digital channels of radio programming, including 69 commercial-free music channels; over 30 channels of news, sports, talk and entertainment; and over 20 dedicated channels of XM Instant Traffic and Weather. SIRIUS brings access to over 130 digital-quality channels, including 69 channels of 100% commercial-free music, plus exclusive channels of sports, news, talk, entertainment, traffic, weather, and data.
Specification Description
Model TX-SR706S, TXSR706S
UPC 751398008221
2:2 Pulldown Receiver Call-In Special
3D Virtual Surround Yes
Analog Audio (3) Rear Output
Analog Audio (7) Rear Input
Analog Audio Front Input
Analog Audio / Video (1) Rear Output
Analog Audio / Video (4) Rear Input
Analog Audio / Video Front Input
Audio Inputs Yes
Channels 7.1
Coaxial Digital Input 3
Color Silver
Component Video (1) Rear Output
Component Video (2) Rear Input
D/A Converter 192kHz / 24-bit
Depth (Inches) 14.8
Dolby Digital EX Surround Yes
Dolby Digital Surround Yes
Dolby Pro Logic Surround Yes
DTS (usually referred as ’dts’) Yes
DTS Neo6 Yes
Frequency Response 5Hz-100kHz
HDMI (1) Rear Output
HDMI (4) Rear Input
HDMI Yes
Headphone Jack Front Output
Height (Inches) 6.9
Monitor Output Rear Output
Multi-Channel 7.1 Channel Input
Multi-Channel 7.1 Channel Pre-Out
Multi-Room/Multi-Source Yes
MultiRoom Capable Yes
On Screen Display Yes
Optical (1) Front Input
Optical (2) Rear Input
Optical Digital Input 3
Phono Rear Input
Preamplifier Outputs 7.1 Channels
Radio Frequencies AM FM and Sirius or XM Option
Radio Station Programmable Memories (Presets) 40
Remote Control Included
RS-232C Rear Input
S-Video Front Input
Satellite Radio Sirius Satellite Radio Ready
Satellite Radio XM Radio Ready
THX Yes
Tuner AM
Tuner FM
Tuner Sirius Satellite Radio Ready
Tuner XM Radio Ready
Type of Receiver Home Theater Surround
Video Inputs Yes
Watts per channel 100
Weight (Pounds) 27
Width (Inches) 17.1
Onkyo TX-SR706S Home Theater Receiver (Silver) Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: TX-SR706S Home Theater Receiver (Silver)
See all eBay results
  at eBay.com
Product Reviews
Last update: Apr 22, 2009
Onkyo TX-SR706S Home Theater Receiver (Silver) Reviews
Displaying 1 - 5 of 21 Reviews
Show
Sort by
TX-SR706
5.0
    Pros
  • Attractive Design
  • Clear Sound
  • Great Sound
    Cons
  • None
    Best Uses
  • Entertainment
"I have HD cable TV box hooked up to Samsung LN52A650 and older Toshiba DVD player. I bought this after reading many reviews from different sites. Wanted THX with all the other processing formats and was concerned about heat issues reported on 606 model. I am very happy after about 3 weeks of use and …"  Read Full Review »
Was this Amplifier, Receiver & Equalizer review on the Onkyo TX-SR706S Home Theater Receiver (Silver) helpful to you?
Jan 19 2009
ATO John
Auburn, WA
I am:
  • Practical
  • Tech Savvy
Reviewed at:
Onkyo SR706S
4.0
    Pros
  • Attractive Design
  • Clear Sound
  • Easy To Set Up
  • Flexible
  • Good Value
  • More »
    Cons
  • Gounding Screw InOp
    Best Uses
  • Basic Systems
  • Entertainment
  • Larger Rooms
"You must read the manual to get all the functionality out of this receiver. "Well worth the read." However, if you're just a basic user no need to figure out the finer points.
My 20 yr old Maggie’s (Magnaplaner speakers) never sounded better. Prior to buying the 706 my system consisted of sepa …"  Read Full Review »
Jan 17 2009
Ninja
ATL, GA area
I am:
  • Audiophile
  • Tech Savvy
Reviewed at:
[1 of 1 customers found this review helpful]
Unbelievable New Technology!
5.0
    Pros
  • Attractive Design
  • Audyssey Makes It Easy
  • Clear Sound
  • Durable
  • Easy To Set Up
  • More »
    Cons
  • Could Use More Power
    Best Uses
  • Entertainment
  • Larger Rooms
  • Production Quality
"Frankly, the Onkyo TX-SR706S amazes me. This technological marvel replaces a "state-of-the-art" and "award-winning" $3,000 Yamaha DSP-A1 Amp (no tuner) from only 9 years ago. Honestly, there is NO COMPARISON between the two. The Onkyo delivers better technology, better performance, better features, …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Dec 27 2008
Rob Blu-ray, now with my Onkyo
Owasso, OK
I am:
  • Audiophile
  • Musically Inclined
  • Practical
  • Professional
  • Tech Savvy
Reviewed at:
Well worth the price
5.0
    Pros
  • Attractive Design
  • Clear Sound
  • Easy To Set Up
  • Great Sound
    Cons
  • Runs hot
    Best Uses
  • Entertainment
  • Larger Rooms
"I got "forced" into buying a new receiver after upgrading to blu-ray since my old receiver couldn't keep up with the bit rate of HD sound. I'm glad that I didn't just buy a Sony like I usually do. After reading multiple reviews on the internet I discovered that Onkyo was now the front runner in hom …"  Read Full Review »
Jan 18 2009
John Hunter
York, PA
I am:
  • Audiophile
  • Tech Savvy
Reviewed at:
Wow!!
5.0
    Pros
  • Attractive Design
  • Clear Sound
  • Easy To Set Up
  • Great Sound
    Cons
  • None
    Best Uses
  • Entertainment
"I have been planning my new home theater set up for a while and did much reasearch ad nauseum to settle on this receiver. The 2 things that I questioned were heating issues on earlier models now a thing of the past with open shelving furniture and long term reliability which I found to be above aver …"  Read Full Review »
Jan 9 2009
Beamer
West Palm Beach, FL
I am:
  • Practical
Reviewed at:
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
