Onkyo TX-8522 Stereo Receiver
4.7
based on 20 reviews
Ratings Distribution
5 star
14
4 star
5
3 star
1
2 star
0
1 star
0
Category Average
4.3
More Images
Pros
  • Clean sound (18)
  • Good power (17)
  • Easy setup (16)
  • Accurate controls (15)
  • Durable (9)
  • Amazing (1)
  • Distinguishable sound (1)
  • Eazy operation (1)
  • Great sound (1)
  • User friendly (1)
See less See more
Cons
  • Have not discovered any (1)
  • Heavy (1)
  • Limited functions (1)
  • See above (1)
Best Uses
  • Basic systems (15)
  • Larger rooms (11)
  • Audiophiles (5)
  • Home theater (5)
  • Smaller rooms (5)
  • Background and multizone (1)
  • Fills a large room (1)
  • Multiple rooms (1)
  • Whole-house audio (1)
Provided by OneCall
Focusing on a Superior Audio Amplification Approach for Quality Stereo Sound
In the fast-paced world of home entertainment technology, change has become an understated word. Technologies now change so quickly that the new becomes yesterday`s product before you barely become accustomed to it. Perhaps it`s time to refocus on what`s really important for quality audio: first-rate sound with high power output. Forget about over-hyped processing technologies. If your receiver lacks the fundamental amplifier design from the power supply through to the output stage, everything else is superfluous. The TX-8522 is built with this in mind. Incorporating Onkyo`s proprietary Wide Range Amplifier Design (WRAT) with an isolated power transformer and discrete output stage, the TX-8522 is focused on maintaining the purity of music, radio and video sources. Also, with the option to take up XM(R) Satellite Radio or to connect your iPod(R) to the system, the TX-8522 gives you the versatility for a sweeping range of entertainment options.
  • Power Output (Stereo at 8 ohm, 20 Hz-20 kHz, FTC) 100 W/Ch
  • Dynamic Power (4 ohm) 135 W/Ch
  • 6 ohm Capable
  • 4 ohm Capable
  • Discrete Output Stage
  • Multiroom Connection
  • Audio Input/Output Terminals 2/1
  • Number of Presets 40
  • Preset Station Naming
  • Direct Access Tuning
  • Automatic/Manual Tuning
  • Headphone Jack
  • Sleep Timer
  • RI-Compatible Remote Control
  • Enhanced IPOD Compatibility
  • XM-Ready
  • DS-A1 Compatible
  • Specification Description
    Model TX-8522, TX8522
    UPC 751398007057
    AC Outlets 2
    Analog Audio (2) Rear Output
    Analog Audio (3) Rear Input
    Analog Audio / Video (2) Rear Input
    Analog Audio / Video Rear Output
    Audio Inputs 3
    Channels 2
    Command / Control IR Input
    Command / Control IR Output
    Command / Control Onkyo RI (Remote Interactive)
    Depth (Inches) 12.69
    Frequency Response 10Hz-100kHz
    Height (Inches) 5.875
    iPod Integration Yes
    Monitor Output Composite Video
    Monitor Output Rear Output
    Phono Rear Input
    Radio Station Programmable Memories (Presets) 40
    Speaker Terminals 5-Way Binding Post
    Stereo Power Rating 100 Watts x 2
    Tuner AM
    Tuner FM
    Tuner Sirius Satellite Radio Ready
    Tuner XM Radio Ready
    Type of Receiver Stereo
    Video Inputs 2
    Watts per channel 100
    Weight (Pounds) 19.8
    Width (Inches) 17.125
    Onkyo TX-8522 Stereo Receiver Questions
    Questions and Answers
    Where to Buy
    Amazon   at Amazon.com
    ebay
    eBay listings for: TX-8522 Stereo Receiver
    See all eBay results
      at eBay.com
    Product Reviews
    Last update: Sep 19, 2008
    Onkyo TX-8522 Stereo Receiver Reviews
    Most helpful positive review
    Most helpful negative review
    [0 of 1 customers found this review helpful]
    5.0
    Great Value Fast Shipment
    "When my Technics reciever (Part of a Technics Rack System) blew it's power supply a couple of weeks ago, I did a lot of research to find a reasonably priced replacement. I wanted good quality two channel sound without spending a fortune. The Onkyo TX 8522 looked like a good match for power (100 W/ch) and low distortion. The Folks at L&R had the lowest priced unit. It was shipped the next day and at my door st..." Read Full Review »
    Aug 04, 2008 by Phil
    See more positive Onkyo TX-8522 Stereo Receiver reviews
    3.0
    Product's Great ABT Support Terrible
    "Product works fine. In working condition. No scratches...." Read Full Review »
    Oct 22, 2007 by R
    See more negative Onkyo TX-8522 Stereo Receiver reviews
    Displaying 1 - 5 of 20 Reviews
    Show
    Sort by
    5.0
      Pros
    • Accurate Controls
    • Clean Sound
    • Durable
    • Easy To Set Up
    • Good Power
      Cons
    • None
      Best Uses
    • Audiophiles
    • Basic Systems
    • Larger Rooms
    "When my Technics reciever (Part of a Technics Rack System) blew it's power supply a couple of weeks ago, I did a lot of research to find a reasonably priced replacement. I wanted good quality two channel sound without spending a fortune. The Onkyo TX 8522 looked like a good match for power (100 W/c …"  Read Full Review »
    Was this Amplifier, Receiver & Equalizer review on the Onkyo TX-8522 Stereo Receiver helpful to you?
    Aug 4 2008
    Phil
    Maryland
    I am:
    • Audiophile
    • Musically Inclined
    • Tech Savvy
    Reviewed at:
    No doubt about it...Its the best!
    5.0
      Pros
    • Accurate Controls
    • Clean Sound
    • Durable
    • Easy To Set Up
    • Good Power
    • More »
      Cons
    • Heavy
      Best Uses
    • Audiophiles
    • Basic Systems
    "Basically Onkyo TX-8522 RDS Stereo Receiver by Onkyo is not really for sattelite sound but for a great sound matching it with my Infinty speakers I have it in Manila that will produce 100 Watts x 2 Channel /you will really find te crisp you're looking for CD/audio player, not to mention using portab …"  Read Full Review »
    Jul 11 2008
    ERWIN_HELERA
    Pacita, San Pedro, Laguna, Philippines
    I am:
    • Music Enthusiast
    • Professional
    • Tech Savvy
    Reviewed at:
    We love our 2-room capability receiver!
    5.0
      Pros
    • Accurate Controls
    • Clean Sound
    • Durable
    • Easy To Set Up
    • Good Power
      Cons
    • None
      Best Uses
    • Basic Systems
    • Larger Rooms
    • Multiple Rooms
    • Smaller Rooms
    "We are delighted with our Onkyo receiver. There was no problem with our 21-year old JVC, but it didn't have any iPod capability. The Onkyo puts out more power and the power is balanced across the two rooms; additionally, the volume level doesn't shift when one set of speakers is turned on or off ( …"  Read Full Review »
    Jun 4 2008
    WG
    Chicago, IL
    I am:
    • Practical
    Just what I was looking for
    4.0
      Pros
    • Clean Sound
    • Easy To Set Up
    • Good Power
      Cons
    • None
      Best Uses
    • Basic Systems
    • Larger Rooms
    "I replaced an old Marantz workhorse that finally went kaput. I wasn't sure anyone still made a good quality stereo receiver without all the home theater bells and whistles. This Onkyo delivers exactly what it promises–great stereo sound. This baby has the power to make my big 100w Cerwin-Vega floor …"  Read Full Review »
    Sep 19 2008
    Diehard Stereo Fan
    Broken Arrow, OK
    I am:
    Reviewed at:
    Just what I wanted, and More!
    5.0
      Pros
    • Accurate Controls
    • Clean Sound
    • Good Power
      Cons
    • None
      Best Uses
    • Audiophiles
    • Basic Systems
    • Home Theater
    • Larger Rooms
    "I needed a good amp with phonograph and plenty of other hookups. The Onkyo TX-8522 fit the bill and then some. I was able to connect all my devises: Thorens turntable, DVD/TV, CD, cassette deck, reel-to-reel, iPod will no problem. Plenty of wattage to drive my 6 speakers and the sound is awesome. …"  Read Full Review »
    Jun 23 2008
    Musicholic
    Ohio
    I am:
    • Tech Savvy
    Reviewed at:
    pages: 1 2 3 4 Next »
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    ebay
      at eBay.com
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
