Onkyo TX-8255 Stereo Receiver
#263
4.4
based on 24 reviews
from $194.00 - $200.00
Ratings Distribution
5 star
10
4 star
13
3 star
1
2 star
0
1 star
0
Category Average
4.3
Pros
  • Great sound quality (24)
  • Easy setup (20)
  • Accurate controls (15)
  • Good power output (12)
  • Durable (11)
  • Attractive design (4)
  • Clarity (1)
  • Excellent separation (1)
  • Good manual (1)
  • Good remote control (1)
See less See more
Cons
  • Limited functions (2)
  • Heavy / bulky (1)
  • Lack of power (1)
  • Limited sound controls (1)
  • Poor sound quality (1)
Best Uses
  • Basic systems (19)
  • Smaller rooms / apartments (11)
  • Large rooms (4)
  • Audiophiles (2)
  • Entertainment (2)
  • Background audio (1)
  • Production quality (1)
  • Secondary system (1)
  • Semi-audiophiles (1)
Provided by B&H Photo Video
TX-8255 2-Channel Stereo Receiver (Black)
Specification Description
Model TX-8255, TX8255
UPC 751398008306
Analog Audio (2) Rear Output
Analog Audio (6) Rear Input
Audio Inputs Yes
Channels 2
Color Black
Depth (Inches) 13
Frequency Response 10Hz-100kHz
Headphone Jack Front Output
Height (Inches) 5.9
MultiRoom Capable Yes
Radio Frequencies AM FM and XM Option
Radio Station Programmable Memories (Presets) 40
Stereo Power Rating 50 Watts x 2
Tuner AM
Tuner FM
Type of Receiver Stereo
Watts per channel 50
Weight (Pounds) 16.5
Width (Inches) 17.1
Onkyo TX-8255 Stereo Receiver Questions
Questions and Answers
Where to Buy
$200.00
No Tax Outside NY ends 09/09/15
BizRate Rating Outstanding 9.7
$194.00
BizRate Rating Outstanding 9.1
$194.00
Product Reviews
Last update: Oct 26, 2009
Onkyo TX-8255 Stereo Receiver Reviews
Most helpful positive review
[3 of 3 customers found this review helpful]
Most helpful negative review
4.0
Excellent Sound-Low Cost
"As with every Onkyo product I've owned, this small receiver is a deceptive powerhouse that delivers excellent dimensional sound. Let's be honest here, if you want that super premium sound level, you have to spend more than [$] list price, BUT, for a really excellent smaller room stereo receiver, with an excellent overall sound stage, particulary at J&R's discounted price, this is a solid winner and I'm used to l..." Read Full Review »
Apr 10, 2009 by Brucie B
See more positive Onkyo TX-8255 Stereo Receiver reviews
3.0
Fine or the price
"I was looking for an inexpensive system to replace one that finally died on me. I couldn't find anything with a built in cd player, cassette deck and turntable inputs. Everything today has iPod docks instead. So, I settled for just a relatively inexpensive receiver. My only complaint about this unit is the very limited bass and treble control. Virtually no bass at all. I'm using the same speakers that were hooke..." Read Full Review »
Apr 20, 2009 by Music Junkie
See more negative Onkyo TX-8255 Stereo Receiver reviews
Displaying 1 - 5 of 24 Reviews
Show
Sort by
4.0
    Pros
  • Accurate Controls
  • Clarity
  • Clean Sound
  • Easy To Set Up
  • Excellent Separation
  • More »
    Cons
  • None
    Best Uses
  • Basic Systems
  • Semi-Audiophiles
"As with every Onkyo product I've owned, this small receiver is a deceptive powerhouse that delivers excellent dimensional sound. Let's be honest here, if you want that super premium sound level, you have to spend more than [$] list price, BUT, for a really excellent smaller room stereo receiver, wit …"  Read Full Review »
Was this Amplifier, Receiver & Equalizer review on the Onkyo TX-8255 Stereo Receiver helpful to you?
 Report Abuse  (3)  (0)  0 comments
Apr 10 2009
Brucie B
Naperville, IL
I am:
  • Audiophile
Reviewed at:
Price: $194.00
[2 of 2 customers found this review helpful]
A Stereo Receiver not a Home Theater Amp
4.0
    Pros
  • Accurate Controls
  • Clean Sound
  • Durable
  • Easy To Set Up
  • Remote not required
    Cons
  • None
    Best Uses
  • Audiophiles
  • Basic Systems
  • Smaller Rooms
"I started out with Heathkit receivers and have had maybe 10 or 15 stereo amplifier or receivers over the last 40 years.
This unit is fairly normal confiduration for a stereo receiver. The 6 rear component connections are adequate for the "normal" system, if such an animal exists. I have a secon …"  Read Full Review »
 Report Abuse  (2)  (0)  0 comments
Feb 12 2009
Henry
Portland metropolitan area, Oregon
I am:
  • Audiophile
  • Practical
  • Tech Savvy
Reviewed at:
Price: $200.00
Good Features For The Price
4.0
    Pros
  • Accepts iPod dock
  • Easy To Set Up
  • Good Power
  • Phono input
    Cons
    Best Uses
  • Basic Systems
  • Smaller Rooms
"This receiver replaced a more powerful one in my library. It is a good receiver for the price, and has more than adequate power for the space it is in. It is difficult to find a moderately priced receiver with a phono input, so this one was an obvious choice for anyone who has a collection of viny …"  Read Full Review »
Jun 25 2009
Jack
Louisiana
I am:
  • Tech Savvy
Reviewed at:
Price: $200.00
The Best for Less
5.0
    Pros
  • Accurate Controls
  • Clean Sound
  • Durable
  • Easy To Set Up
  • Good Power
    Cons
  • None
    Best Uses
  • Basic Systems
"My old Sony amp/receiver died and I looked everywhere for the right replacement. As a dedicated headphone listener, I finally realized I didn't need 200 wats per channel. The Onkyo TX-8255 was perfect to drive my cassette deck, CD changer and turntable. I could have purchased the Onkyo locally bu …"  Read Full Review »
Mar 18 2009
vetteman
Cincinnati, Ohio
I am:
  • Musically Inclined
  • Practical
  • Technically Challenged
Reviewed at:
Price: $194.00
[1 of 1 customers found this review helpful]
No Frills, Great Sound
5.0
    Pros
  • Attractive Design
  • Clear Sound
  • Durable
  • Easy To Set Up
  • Great Sound
    Cons
  • Bulky
    Best Uses
  • Basic Systems
  • Entertainment
  • Larger Rooms
  • Production Quality
  • Smaller Rooms
"I bought this receiver to replace my old MCS receiver from the late 70s. I was looking for something similar to that old unit in that it wasn't overly "teched out". My son who is a professional musician and can hear evey little pin drop in a recording, suggested the TX-8255. The sound quality is equ …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Jan 1 2009
Pizzaboy
Phoenix, AZ.
I am:
  • Practical
  • Tech Savvy
Reviewed at:
Price: $200.00
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
