Close Login Module
Join
Onkyo THX Select2 Plus 7.1-Channel Home Theater Receiver - TX-SR706B
#5
4.5
based on 63 reviews
Ratings Distribution
5 star
38
4 star
25
3 star
0
2 star
0
1 star
1
Category Average
4.3
$699.00 - $794.00
from 2 stores
Pros
  • Clean sound (62)
  • Good power (53)
  • Accurate controls (49)
  • Easy setup (45)
  • Durable (30)
  • Flexibility (1)
  • Good value (1)
  • Great features (1)
  • Hdmi tv-screen set-up (1)
  • Solid (1)
See less See more
Cons
  • Difficult to set up (4)
  • Limited functions (3)
  • No audio cables (2)
  • Gets too hot (1)
  • Heavy (1)
  • Limited sound stages (1)
  • Manual (1)
  • Needs a cooling fan (1)
  • Needs a facelift (1)
Best Uses
  • Home theater (60)
  • Larger rooms (19)
  • Audiophiles (18)
  • Smaller rooms (17)
  • Basic systems (13)
  • And medium rooms (1)
  • Easy listening (1)
  • Ht if basic sound desired (1)
  • Medium rooms (1)
Where to Buy
Product Reviews
Last update: Nov 2, 2009
Onkyo THX Select2 Plus 7.1-Channel Home Theater Receiver - TX-SR706B Reviews
Most helpful positive review
[3 of 3 customers found this review helpful]
Most helpful negative review
[0 of 1 customers found this review helpful]
5.0
Perfect Receiver at this price point
"My Denon 2308 recently died. Its under warranty but getting that repaired easily is another story. I bought the Onkyo to get me through the 4+ weeks I wouldnt have an engine to drive my HDTV & BluRay Movies. The best part about that is being able to compare the Onkyo with the Denon. The Onkyo is the clear winner. Here is where its better: + Easy Setup + Much better interface + More user friendly + Unit has mo..." Read Full Review »
Jan 09, 2009 by KD
See more positive Onkyo THX Select2 Plus 7.1-Channel Home Theater Receiver - TX-SR706B reviews
1.0
Also having problems with audyssey...
"This is the second Onkyo 7 series receiver I have owned. I liked the 705 so much that when my neighbor wanted to buy it, I upgraded to the 706. However, here is where the honeymoon ended. After setting up my 7.1 system, I went to complete the audyssey auto seaker setup. The mic is not picking up the test tones. After trying everything I could think of, including calling OneCall, I tried the mic that worked ..." Read Full Review »
Nov 13, 2008 by LB
See more negative Onkyo THX Select2 Plus 7.1-Channel Home Theater Receiver - TX-SR706B reviews
Displaying 1 - 5 of 63 Reviews
Show
Sort by
5.0
    Pros
  • Accurate Controls
  • Clean Sound
  • Easy To Set Up
  • Good Power
    Cons
  • Needs a facelift
    Best Uses
  • Home Theater
  • Medium Rooms
"My Denon 2308 recently died. Its under warranty but getting that repaired easily is another story. I bought the Onkyo to get me through the 4+ weeks I wouldnt have an engine to drive my HDTV & BluRay Movies. The best part about that is being able to compare the Onkyo with the Denon. The Onkyo is th …"  Read Full Review »
Onkyo is in cabinet on right
  • Picture of Product
Jan 9 2009
KD
Washington DC area
I am:
  • Musically Inclined
  • Tech Savvy
Reviewed at:
[6 of 6 customers found this review helpful]
Not too much, not too little..just right
4.0
    Pros
  • Accurate Controls
  • Clean Sound
  • Durable
  • Easy To Set Up
  • Good Power
    Cons
  • None
    Best Uses
  • And medium rooms
  • Audiophiles
  • Home Theater
  • Smaller Rooms
"I use this as a pre amp in a medium sized dedicated home theater room which has been very well acoustically treated (this ROOM sounds great). I use separate amps for my power hungry Magnepans. If you are already used to setting up home theater equipment, then you will find it pretty routine. It coul …"  Read Full Review »
Dec 29 2008
Campoly
DFW, TX
I am:
  • Audiophile
  • No wire or DAC hang ups
  • Practical
  • Tech Savvy
Reviewed at:
[5 of 5 customers found this review helpful]
Excellent value.
4.0
    Pros
  • Clean Sound
  • Easy To Set Up
  • Good Power
    Cons
  • None
    Best Uses
  • Home Theater
"I just wanted a decent mid-range receiver that does all the latest lossless audio formats and has 7.1 channels so it's ready to take advantage of BluRay as that format evolves. So my primary focus is on a system that plays audio for movies and video games as it's primary function. Currently I have t …"  Read Full Review »
Sep 24 2008
Joao G.
Brasil
I am:
  • Tech Savvy
Reviewed at:
Must Buy!!!!
5.0
    Pros
  • Accurate Controls
  • Clean Sound
  • Durable
  • Easy To Set Up
  • Good Power
    Cons
  • No Audio Cables
    Best Uses
  • Home Theater
  • Larger Rooms
  • Smaller Rooms
"After extensive research, I bought this receiver to hook-up my PolkAudio speakers RM6880 5.1 channel. I must say that I am really impressed with the sound quality. This is a must buy if you have 5.1 channel or 7.1 channel setup. Although I was not expecting anything awesome since my living room layo …"  Read Full Review »
Apr 17 2009
Jazzer
Los Angeles, CA
I am:
  • Practical
Reviewed at:
[2 of 3 customers found this review helpful]
Bells and whistles
4.0
    Pros
  • Clean Sound
  • Easy To Set Up
  • Good Power
    Cons
  • None
    Best Uses
  • Home Theater
  • Smaller Rooms
"After much research and a few headaches I chose this receiver to be the center of my family room movie theater.
In 1991 I purchased a Yamaha A/V receiver when only a few AV receivers were available and it is still serving me well although outdated for my current wants/needs.
Because of the ser …"  Read Full Review »
Dec 18 2008
Chip
Mystic, CT
I am:
  • Audiophile
  • Practical
  • Tech Savvy
Reviewed at:
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
