Onkyo HTS5200 1200 Watts 7.1 Home Theater System
4.1
based on 12 reviews
from $454.00 - $599.98
Ratings Distribution
5 star
6
4 star
3
3 star
2
2 star
0
1 star
1
Category Average
4.1
More Images
Pros
  • Great sound quality (7)
  • Easy setup (5)
  • Interfaces well with tv (3)
  • Confusing / difficult controls (2)
  • Thundering bass (2)
  • Good separation (1)
See less See more
Cons
  • Difficult to set up (2)
  • Not enough connection options (2)
  • Not true 71 surround (1)
  • Poor energy useage (1)
  • Poor interface (1)
  • Poor sound quality (1)
Best Uses
  • Living room (4)
  • Movies (4)
  • Surround sound solution (4)
  • Large rooms (3)
  • Smaller rooms / apartments (3)
  • Television shows (1)
Provided by OneCall
Stacked with Options and Versatility—From Multiple High-Definition (1080p) Sources to the iPod, Gaming, and SIRIUS™ Satellite Radio
If you want an idea of where Onkyo’s home theater packages are heading, the HT-S5200 is well worth checking out.Like previous Onkyo 7.1-channel receiver/speaker packages, the HT-S5200 delivers reassuringly hefty amounts of power and all-round performance. And in line with other recent offerings, it’s also perfectly suited for high-definition entertainment in the home: 1080p video takes center stage from sources such as Blu-ray Disc, DVD, HD broadcasting, and gaming. The emphasis is still on Onkyo’s audio prowess, so the HT-S5200 is equipped with three groundbreaking Audyssey technologies that will give you the edge in terms of surround sound.It also features some exciting innovations from Onkyo: a dedicated port that connects the iPod via the Dock for the iPod and DSP modes specifically designed for gaming.
Includes dedicated RI iPod dock (UP-A1L) which supports the following iPods:
  • 4th Gen iPod
  • 4th Gen iPod (color display)
  • iPod Photo
  • iPod video
  • iPod Classic (80, 120 and 160GB)
  • 1st - 4th Gen iPod Nano
  • 1st and 2nd Gen iPod Touch
  • iPhone and iPhone 3G
  • * separate audio connection required
    Specification Description
    Model HT-S5200, HTS5200
    UPC 751398008948
    Analog Audio (2) Rear Output
    Analog Audio (5) Rear Input
    Analog Audio / Video (1) Rear Output
    Analog Audio / Video (3) Rear Input
    Command / Control Proprietary Plug
    Component Video (1) Rear Output
    Component Video (2) Rear Input
    Disc Player DVD Player - Single
    HDMI (1) Rear Output
    HDMI (4) Rear Input
    Main Features DVD Player / Radio
    MP3 or iPod Connectivity iPod Dock included
    Optical (2) Rear Input
    Play Modes Surround (7.1 Channels)
    Radio Bands AM/FM with Sirus Capability
    Speaker Switching A+B
    Speaker Switching A/B
    Speakers 7 Satellites + Subwoofer
    Subwoofer Out Rear Output
    Surround Modes DTS
    Surround Modes DTS 96/24
    Surround Modes DTS ES
    Surround Modes DTS NEO:6
    Surround Modes Dolby Digital
    Surround Modes Dolby Digital EX
    Surround Modes Dolby Pro Logic IIx
    Surround Power Rating (watts) 100
    Surround Power Rating (watts) 130
    Tuner AM
    Tuner FM
    Onkyo HTS5200 1200 Watts 7.1 Home Theater System Questions
    Questions and Answers
    Where to Buy
    $494.00
    $1.99 Shipping On Orders Over $100 at TigerDirect ends 12/31/09
    BizRate Rating Outstanding 9.1
    $459.98
    $454.00
    5% off orders at Abt.com
    BizRate Rating Outstanding 9.4
    Show all 8 stores
    _
    Product Reviews
    Last update: Nov 19, 2009
    Onkyo HTS5200 1200 Watts 7.1 Home Theater System Reviews
    Most helpful positive review
    Most helpful negative review
    4.0
    Good entry level HT box system
    "This is a good solution for someone looking for a quick and easy home theater fix. The Onecall price is what sold me. If I had the money, I would have gotten a receiver separate from the speakers. That way, I could have a receiver with true 7.1 surround sound. The way this receiver works is the audio is connected from your source (ie dvd player) via component or optical cable. These connections can only handle 5..." Read Full Review »
    Jun 16, 2009 by Collin
    See more positive Onkyo HTS5200 1200 Watts 7.1 Home Theater System reviews
    3.0
    Not enough bang for your buck
    "I thought that this system would do better and much more. There are not enough component inputs and audio outputs. I was really upset at the fact that there is no audi pass thru via HDMI. However it delivers good sound quality and awesome bass. The subwoofer that it came with "blew up" [...]. Also plan on buying a universal remote with this system because you will need it. ABT has some good ones. [...] I would r..." Read Full Review »
    Nov 19, 2009 by Home Theatre Man
    See more negative Onkyo HTS5200 1200 Watts 7.1 Home Theater System reviews
    Displaying 1 - 5 of 12 Reviews
    Show
    Sort by
    3.0
      Pros
    • Clear Sound
    • Thundering Bass
      Cons
    • Difficult To Setup
    • No audio output via HDMI
    • Not enough inputs
      Best Uses
    • Movies
    • Surround Sound Solution
    "I thought that this system would do better and much more. There are not enough component inputs and audio outputs. I was really upset at the fact that there is no audi pass thru via HDMI. However it delivers good sound quality and awesome bass. The subwoofer that it came with "blew up" [...]. Also p …"  Read Full Review »
    Was this Home Theater review on the Onkyo HTS5200 1200 Watts 7.1 Home Theater System helpful to you?
    Nov 19 2009
    Home Theatre Man
    Chicago, Illiniois
    I am:
    • Movie Enthusiast
    • Tech Savvy
    Reviewed at:
    Price: $454.00
    4.0
      Pros
    • Clear Sound
    • Easy To Setup
      Cons
      Best Uses
    • Movies
    • Smaller Rooms
    "This is a good solution for someone looking for a quick and easy home theater fix. The Onecall price is what sold me. If I had the money, I would have gotten a receiver separate from the speakers. That way, I could have a receiver with true 7.1 surround sound. The way this receiver works is the audi …"  Read Full Review »
    Jun 16 2009
    Collin
    MA
    I am:
    • Audiophile
    • Musically Inclined
    • Tech Savvy
    Reviewed at:
    Price: $459.98
    Good Bang For The Buck
    4.0
      Pros
    • Clear Sound
    • Easy To Setup
    • Good separation
    • Interfaces Well With TV
    • Intuitive Controls
      Cons
    • None
      Best Uses
    • Living Room
    • Smaller Rooms
    "This unit was purchased to replace an old Sony 5.1 Our living room is a unique shape and correct speaker placement was a challenge. I found and read the manual on-line before the unit arrived. There is a system calibration system built into this product which actually works well. In our relatively …"  Read Full Review »
    Jul 23 2009
    Ken
    Grand Junction, CO
    I am:
    • ProRecording Studio Owner
    Reviewed at:
    Price: $494.00
    [1 of 3 customers found this review helpful]
    Aweful system
    1.0
      Pros
    • Clear Sound
      Cons
    • Poor Interface
    • Poor Sound Quality
      Best Uses
    • Smaller Rooms
    "I gave away my Harmon Kardon because it was a older version without hdmi .So I purchase Onkyo s5200 system for the first time.Ok I spend hours on this trying to figure out why the hdmi audio did not work.
    Well stupid as this sounds this Onkyo with 3 hdmi connection only allows Video hdmi run throug …"  Read Full Review »
     Report Abuse  (1)  (2)  0 comments
    Jul 27 2009
    superman
    st louis missouri
    I am:
    • Tech Savvy
    Reviewed at:
    Price: $494.00
    My wife and I(both ...
    5.0
    "My wife and I(both teachers with modest budget) looked around at several home theater package deals, and kept coming back to this. It is a definite upgrade from our old system as far as quality goes. This system has great sound for our living room 20' X 16'. Set-up was extremely easy, and took ab …"  Read Full Review »
    Sep 6 2009
    DaBears34
    Undisclosed
    pages: 1 2 3 Next »
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
