Onkyo HT-S9100THXB 7.1-Channel THX Certified Home Theater System
4.8
based on 9 reviews
from $899.99 - $1,099.99
Ratings Distribution
5 star
7
4 star
2
3 star
0
2 star
0
1 star
0
Category Average
4.1
Low Price:
$899.99 at OneCall
 Trusted:
$1,099.99 at Newegg
Find it at Amazon
Pros
  • Great sound quality (9)
  • Interfaces well with tv (9)
  • Easy setup (7)
  • Thundering bass (7)
  • Confusing / difficult controls (6)
See less See more
Cons
  • Bulky speakers (2)
  • Difficult to set up (1)
  • Rather large (1)
Best Uses
  • Movies (8)
  • Surround sound solution (8)
  • Living room (7)
  • Television shows (5)
  • Large rooms (4)
  • Smaller rooms / apartments (2)
  • Great for all av sounds (1)
Provided by OneCall
If you thought our first THX Integrated System Certified receiver/speaker package was a great concept, then this power-packed followup will be sure to please.The HT-S9100THX is the first THX I/S Plus Certified system to handle full high-definition processing of 1080p video and the master quality of Dolby® TrueHD and DTS-HD Master Audio™.Whatever input you choose—whether gaming, movies, broadcasts, or music—the HT-S9100THX draws on a reservoir of precise amplification power to create a breathtaking home entertainment experience.With video upscaling, revolutionary audio equalization and acoustic treatment technologies, and integrated control with leading display brands, the HT-S9100THX is a fail-safe solution for most home environments.
Specification Description
Model HTS9100
UPC 751398008283
Analog Audio (2) Rear Output
Analog Audio (5) Rear Input
Analog Audio Front Input
Analog Audio / Video (1) Rear Output
Analog Audio / Video (3) Rear Input
Analog Audio / Video Front Input
Component Video (1) Rear Output
Component Video (2) Rear Input
D/A Converter 24-bit/192kHz
HDMI (1) Rear Output
HDMI (4) Rear Input
Headphone Jack Front Output
Multi-Channel 7.1 Channel Input
Optical (2) Rear Input
Preamplifier Outputs Subwoofer
S-Video (1) Rear Output
S-Video (4) Rear Input
Surround Modes DTS-HD High Resolution
Surround Modes DTS-HD Master Audio
Surround Modes Dolby Digital Plus
Surround Modes Dolby TrueHD
Surround Power Rating 130 Watts x 7
Tuner AM
Tuner FM
Onkyo HT-S9100THXB 7.1-Channel THX Certified Home Theater System Questions
Questions and Answers
Where to Buy
$899.99
BizRate Rating Outstanding 9.1
$1,099.99
BizRate Rating Outstanding 9.2
Product Reviews
Last update: Jun 1, 2009
Onkyo HT-S9100THXB 7.1-Channel THX Certified Home Theater System Reviews
Displaying 1 - 5 of 9 Reviews
Show
Sort by
Awesome!
5.0
    Pros
  • Clear Sound
  • Easy To Setup
  • Interfaces Well With TV
  • Intuitive Controls
  • Thundering Bass
    Cons
  • Rather large
    Best Uses
  • Larger Rooms
  • Living Room
  • Movies
  • Surround Sound Solution
  • Television Shows
"I decided to go with this system after looking at several, and I am really blown away by the sound. I have this connected to a Blu-Ray player and I couldn't be happier by how well this system takes advantage of Blu-Ray's advanced sound capabilities. The only downside I can think of is the size of …"  Read Full Review »
Was this Home Theater review on the Onkyo HT-S9100THXB 7.1-Channel THX Certified Home Theater System helpful to you?
Nov 1 2008
Devin Lee
Beckley, WV
I am:
  • Tech Savvy
Reviewed at:
Price: $899.99
Very Nice Big Boy Toy !!
5.0
    Pros
  • Clear Sound
  • Easy To Setup
  • Thundering Bass
    Cons
  • None Yet
    Best Uses
  • Great for all AV sounds
"Have had this unit for about a month now and am lovin' it. The bass is awesome. Clarity of all the sounds are great. Am using the 7.1 surround and at times I can't tell if the sounds are from the Onkyo or something else it's so realistic. I actually picked up the phone to answer it because I thought …"  Read Full Review »
Oct 4 2008
Don of Agra
Agra, Oklahoma
I am:
  • Tech Savvy
Reviewed at:
Price: $899.99
You can not go wrong with this product
5.0
    Pros
  • Clear Sound
  • Easy To Setup
  • Thundering Bass
    Cons
  • Bulky speakers
    Best Uses
  • Larger Rooms
  • Living Room
  • Movies
  • Smaller Rooms
  • More »
"Aside from the bulky speakers, this is an awesome product at this price range. Excellent sound quality for HTIB. Faithfully reproduces everything from music, to movies, to video games. Great surround sound accuracy/immersion. The Audyssey EQ microphone makes for quick calibration. It provides an On …"  Read Full Review »
Jan 2 2009
100Calories
Ripon, CA
I am:
  • Tech Savvy
Reviewed at:
Price: $899.99
7.1 THX best value 4 True Theater Experi
5.0
    Pros
  • Clear Sound
  • Easy To Setup
  • Thundering Bass
    Cons
  • Bulky speakers
    Best Uses
  • Living Room
  • Movies
  • Smaller Rooms
  • Television Shows
"Aside from the bulky speakers, this is an awesome product for its price. Excellent sound quality for HTIB. Faithfully reproduces everything from music, to movies, to video games. Great surround sound accuracy/immersion. The Audyssey EQ microphone makes for quick calibration. It provides an On Screen …"  Read Full Review »
Jan 2 2009
100Calories
Ripon, CA
I am:
  • Tech Savvy
Reviewed at:
Price: $899.99
Great Home Theatre
5.0
    Pros
  • Clear Sound
    Cons
  • Difficult To Setup
    Best Uses
  • Larger Rooms
  • Living Room
  • Movies
  • Television Shows
"This is a great surround sound solution. The THX certification is why I bought this product. The sound is clear and the realism of the sound is so good I've actually thought a knocking sound was coming from my door instead of the speakers! "
Jun 1 2009
Ted
Vergennes, VT
I am:
  • Practical
Reviewed at:
Price: $899.99
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
