Onkyo HT-S9100THX 7.1-Channel Home Theater System
#21
4.6
based on 10 reviews
from $994.00 - $1,099.99
Ratings Distribution
5 star
9
4 star
0
3 star
0
2 star
0
1 star
1
Category Average
4.1
More Images
Pros
  • Easy setup (8)
  • Great sound quality (8)
  • Powerful (6)
  • Simple / intuitive controls (6)
  • Attractive design (5)
  • Confusing / difficult controls (2)
  • Interfaces well with tv (2)
  • Durable (1)
  • Good value (1)
  • High quality (1)
See less See more
Cons
  • Heavy / bulky (1)
  • Poor sound quality (1)
Best Uses
  • Basic use (2)
  • Large rooms (2)
  • Movies (2)
  • Living room (1)
  • Smaller rooms / apartments (1)
  • Surround sound solution (1)
Provided by B&H Photo Video
Choosing the right home theater system is often challenging and frustrating. This Home Theater System eliminates the confusion associated with making a sound choice. With exquisite high-definition surround sound reproduction, HDMI 1080p Deep Color Processing, and 1200W of earth moving power, the Onkyo HT-S9100THX 7.1-Channel Home Theater System will take your home theater experience to new heights. Designed and built with both professional audio pundits and home theater enthusiasts in mind, it combines unsurpassed clarity and functionality by utilizing THX Integrated Systems Plus Certification. It features four HDMI (Ver. 1.3a) inputs, and two HD component inputs, enabling an effortless, high-bandwidth transfer of video signals to the latest HDTV displays. It features 1080i HD video upconversion with Faroudja DCDi Edge Technology, regardless of the connection. This system combines style and clarity with an impressive A/V (130W-Per Channel) digital receiver. It offers 192KHz/24-bit audio processing technology to create a wider, more enveloping surround-sound experience. It features Dolby Digital Plus, Dolby TrueHD, DTS-HD Master Audio, and DTS-HD High Resolution Audio decoding. In addition, Onkyo also includes a sophisticated 7.1-Channel speaker system capable of delivering a full, clear, and tight sound response. It consists of two (2-Way) front satellite speakers, four (2-Way) surround speakers, one (2-Way) center speaker, and a powerful 290W down-firing 12" subwoofer. Moreover, it presents superb audio processing that will be hard to match. Onkyo exclusives like Wide Range Amplifier Technology (WRAT), All Discrete Circuitry, Optimum Gain Volume Circuitry, High Current Power Supply (H.C.P.S.), and Audyssey 2EQ Room Calibration offer the cleanest signal on the market. With HDTV component switching, Blu-ray/PlayStation 3 compatibility, RIHD System Control, 7.1-CH Discrete Input, AM/FM tuner, and connectivity to virtually any A/V source or playback component you can imagine, your entertainment choices are endless with the HT-S9100THX.
Specification Description
Model HT-S9100THX, HT-S9100TXB
UPC 751398008283
MP3 or iPod Connectivity iPod Dock optional
Play Modes Surround (7.1 Channels)
Speakers 7 Satellites + Subwoofer
Stereo Power per channel (Watts) 130
Onkyo HT-S9100THX 7.1-Channel Home Theater System Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Aug 9, 2009
Onkyo HT-S9100THX 7.1-Channel Home Theater System Reviews
Most helpful positive review
[7 of 8 customers found this review helpful]
Most helpful negative review
[1 of 6 customers found this review helpful]
5.0
Best Bang for Your Buck
"I just finished my basement with a section set aside for a theater area. A theater installer friend recommended this system because of the quality and price. I was a little worried because I could not get the system locally. No one in town could get the system. The installer friend of mine said that he has one on back order for 2 months. I checked on line and found 1 system left at J&R's. I decided to take ..." Read Full Review »
Jan 09, 2009 by S Wilson
See more positive Onkyo HT-S9100THX 7.1-Channel Home Theater System reviews
1.0
hts9100thx (junk)
"Good cosmetically. Poor Volume even at +18 (maximum). Used Reciever less than one hour and "POOF" no more workie. What a piece of junk. I have bought Onkyo only for the past 25 years but no more. I had a bad feeling about this unit from jump street. Should have gone with my gut...." Read Full Review »
Jun 09, 2009 by Fat Cat
See more negative Onkyo HT-S9100THX 7.1-Channel Home Theater System reviews
Displaying 1 - 5 of 10 Reviews
Show
Sort by
5.0
    Pros
  • Attractive Design
  • Easy Controls
  • Easy To Set Up
  • Great Sound
  • Powerful
    Cons
  • None
    Best Uses
  • Basic Use
"I just finished my basement with a section set aside for a theater area. A theater installer friend recommended this system because of the quality and price. I was a little worried because I could not get the system locally. No one in town could get the system. The installer friend of mine said …"  Read Full Review »
Was this Shelf System review on the Onkyo HT-S9100THX 7.1-Channel Home Theater System helpful to you?
 Report Abuse  (7)  (1)  0 comments
Jan 9 2009
S Wilson
Omaha NE
I am:
  • Musically Inclined
  • Practical
Reviewed at:
Price: $994.00
[5 of 5 customers found this review helpful]
very happy
5.0
    Pros
  • Clear Sound
  • Easy To Setup
  • Interfaces Well With TV
  • Intuitive Controls
    Cons
  • None
    Best Uses
  • Movies
"I shopped around a lot for a sound system for my new LCD tv. I set myself a budget that wouldn't break the bank but would hopefully add to watching a movie on the new set. What I found at the local stores was less than I wanted. After reading the online reviews, I'm very happy that I chose the THX s …"  Read Full Review »
 Report Abuse  (5)  (0)  0 comments
Dec 9 2008
hercdriver
pittsburgh, pa
I am:
  • Practical
Reviewed at:
Price: $1,000.00
HT-S9100THX Great product for the price
5.0
    Pros
  • Attractive Design
  • Easy Controls
  • Easy To Set Up
  • Great Sound
  • Powerful
    Cons
  • Bulky
    Best Uses
  • None
"The setup of this receiver was extremely simple. I did the auto setup with the mycrophone they provided. Although, manually adjusting is simple to do as well, if you prefer. I have my Samsung UN55B7100 hooked up to the out and my other componets Samsung 2500BDP Blue ray player, Verizon Fios Cab …"  Read Full Review »
Mar 31 2009
mkwijr
Lynn, MA
I am:
  • Tech Savvy
Reviewed at:
Price: $1,000.00
THIS ROCKS!
5.0
    Pros
  • Clear Sound
  • Easy To Setup
    Cons
  • None
    Best Uses
  • Larger Rooms
  • Living Room
  • Movies
  • Smaller Rooms
  • Surround Sound Solution
"This is the best home theatre in-a-box product around. I am very pleased w/ it. I am using it w/ a 60" Pioneer Kuro plasma TV. John from Berthoud Enterprises (815-344-2353) In stalled the TV & Onkyo THX system. WOW! "
Oct 20 2008
Lu
SE Wisconsin
I am:
  • Practical
  • Tech Savvy
Awesome sound
5.0
    Pros
  • Durable
  • Good Value
  • High Quality
    Cons
  • None
    Best Uses
  • None
"This is our first true surround sound system. We were impressed with the ease of installation and calibration. Running all the wires to the speakers was a little bit of a hastle, but the end results were worth it. We are very happy with the quality of the sound we are getting. "
Feb 3 2009
Nina in Alabama
Gurley, AL
Reviewed at:
Price: $1,000.00
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
