#198
based on 8 reviews
Ratings Distribution
| 5 star |
2 |
| 4 star |
4 |
| 3 star |
0 |
| 2 star |
1 |
| 1 star |
1 |
Category Average
Where to Buy
BizRate Rating
Good 8.8
BizRate Rating
Good 8.7
Product Reviews
Displaying 1 - 5 of 8 Reviews
OmniMount Wall Speaker Mounting Kit - 20 lb. max weight Review
Pros
Cons
Best Uses
"My speakers weigh 7.7 lbs, according to the manual. I tried Sanus mounts rated for "Up to 8 pounds". The mounts weren't able to hold the speaker from sagging all the down to the wall. I can't believe they didn't break under the strain. I took them down and threw those cheap plastic things in the …" Read Full Review »
[0 of 1 customers found this review helpful]
Pros
Cons
Best Uses
"Wall mount would not hold speaker. Speaker is 15 pounds. Could not tighten ball enough. Speaker kept slipping.
Drilled hole through ball and used screw but it would not hold.
Pros
Cons
Best Uses
"Great product. Exactly what I needed, a little bit of research and a reliable retailer go a long way in making your HT look and function just the way you want it. "
"The mount held my Triad Speakers tightly against the wall with no movement. I read other reviews of this mount saying that it slips. I didn't experience any slippage at all. The key is really tightening the allen screw, which isn't easy to do in the tight space between the speaker and the wall. I …" Read Full Review »
"The product was what I needed...unfortunately, it wasn�t a perfect match. I had to fashion an adapter plate. Not because of your company, just because the product I own was older. My only problem was that I received the wrong instructions in the box for my product. I had to get the white papers off …" Read Full Review »
Email Address: (required)
Comments:
or Cancel
Where to Buy
BizRate Rating
Good 8.8
BizRate Rating
Good 8.7
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.comPrices, inventory, and product information are provided by the merchants and may include any promotional discounts that are not available to all customers. We assume no responsibility for accuracy of price information provided by merchants, but please price_alerts|snabela|powerreviews.com to any pricing discrepancies so we can notify the merchant. Additionally, sales taxes and shipping costs are not included in listed prices, so please check with the merchant for total costs.
Powered by PowerReviews, Inc. ©2009 All Rights Reserved
