OmniMount Systems Stainless Steel Speaker Mount
#73
4.8
based on 5 reviews
Ratings Distribution
5 star
4
4 star
1
3 star
0
2 star
0
1 star
0
Category Average
4.4
$24.15 - $46.17
from 12 stores
More Images
Provided by OneCall
With this stainless steel speaker mount, you can now easily suspend your speakers from the ceiling--ideal for creating an all-encompassing 5.1 surround system or adding audio to another room in the house. Designed to hold speakers up to 20 pounds in weight, this speaker mount has a ball mount which rotates and holds in any direction, allowing you to easily adjust the speaker angle to best suit your listening environment. All you need is a speaker with either pre-existing threaded inserts for the mounting plate, or a sturdy wood frame that can be safely drilled into.
Stainless steel construction means this mount is built to last and can be used for both outdoor and indoor applications. The mount is also designed with polymer reinforcements at critical areas to help minimize resonance, resulting in a clearer, more accurate sound.
  • Polymer reinforcements to help minimize resonance
  • Attaches to ceiling
  • Stainless steel construction
  • Holds speakers up to 20 pounds in weight
  • Ball mount rotates and holds in any direction
  • Specification Description
    Model 20.0 CEILING -WHITE, 20.0 CEILING W EA, 20.0 CEILING-W, 20.0CLWH
    UPC 728901007156
    Benefits High weight capacity holds up to 20 poundsWorks with virtually any surface; drywall, wood, brick, etc.360° base rotation
    Capacity UOM mAh
    Country Of Origin United States
    Description Header Heavy-duty mounting options.
    Display Catalog Number 55011308
    Included in the Box Complete mounting kit5/32" hex wrenchExtra jam nutClamp assemblyBall shaftAnchorsMountin
    Manufacturer Labor Warranty 2
    Manufacturer Part Number 20.0 CEILING-W
    Manufacturer Parts Warranty 2
    MAP Price 0.0
    Model 20.0 CEILING-W
    Operating Temperature UOM ° F
    Product Dimensions UOM inches
    Product Type Mounting kits
    Product Weight UOM pounds
    Supported Languages English
    OmniMount Systems Stainless Steel Speaker Mount Questions
    Questions and Answers
    Where to Buy
    Product Reviews
    Last update: Apr 21, 2009
    OmniMount Systems Stainless Steel Speaker Mount Reviews
    Displaying 1 - 5 of 5 Reviews
    Show
    Sort by
    [1 of 1 customers found this review helpful]
    These Things (Don't) Rock!
    5.0
    "These turned out to be the perfect mounts for my application. I have unusually heavy bookshelf speakers (Aperion) that I wanted to mount for use as my rear speakers in a 7.1 setup. I had trouble finding sturdy and unobtrusive mounts that would support them and give me some flexibility in terms of p …"  Read Full Review »
    Was this Speaker Stand & Mount review on the OmniMount Systems Stainless Steel Speaker Mount helpful to you?
     Report Abuse  (1)  (0)  0 comments
    Feb 8 2008
    Kevin Rusnak
    Ohio
    Reviewed at:
    Price: $39.99
    Amazing Mount!!!!
    5.0
    "These mounts are the best available for ceiling mounts! Easy to install, and they don't require mounting into a stud. A drill bit is included if you have to drill into your speakers to intall the mounting plate. I was able to unscrew the keyhole bracket on my Polk Monitor 30's and use those holes …"  Read Full Review »
    Jan 31 2009
    Ryan Lesniewski
    Cleveland, OH
    Reviewed at:
    Price: $39.99
    Speaker Mount
    5.0
    "The ceiling speaker mount was easy to install. I mounted a 12 pound speaker on the mount, which was designed to support up to 20 pounds. It held the speaker securely into position. "
    Mar 16 2007
    Mike R
    MD
    Reviewed at:
    Price: $39.99
    excellent for heavy speakers
    4.0
    "This was perfect for my b&w 13lb rear speakers.. very adjustable, solid, sturdy, and mount well to my plaster board ceiling with appropriate anchors. "
    Apr 21 2009
    A. Land
    Baltimore, MD
    Reviewed at:
    Price: $39.99
    [1 of 7 customers found this review helpful]
    Screwed over by Amazon
    5.0
    "The item was perfect, just not what I ordered or wanted. Amazon says I ordered the wrong item and I had to pay return shipping and a re-stocking charge. I sent Amazon a copy of the original order confirmation and it did not say ceiling mount anywhere, as it didn't when I ordered them!
    I doubt that I …"  Read Full Review »
     Report Abuse  (1)  (6)  0 comments
    Mar 22 2007
    Gary David Shaver
    Amazon
    Reviewed at:
    Price: $39.99
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
