OmniMount CMK White Wall Cable Management Kit
#686
4.3
based on 11 reviews
from $11.95 - $22.00
Ratings Distribution
5 star
6
4 star
3
3 star
1
2 star
1
1 star
0
Category Average
4.1
More Images
Pros
  • Good value (1)
  • Got mom's approval (1)
See less See more
Cons
  • Difficult to align holes (1)
Best Uses
  • Covering up cables (1)
Provided by Mounts and More
Need an attractive way to hide the wires and cables of your entertainment center? Try OmniMount's Wall Cable Management System.
Features:
  • Modular design
  • Covers can be cut to any length
  • Kit includes: (3) 16" wall covers, (1) 90° connector and (2) end caps
  • White finish
CMK Installation Instructions
Specification Description
Model CMK, CMK Mini, CMK-MINI
UPC 728901019319
Accessory Indicator Yes
Benefits Modular design allows for any configurationCovers can be cut to custom/desired lengthsPaintable so it can match any wall
Capacity UOM mAh
Country Of Origin China
Description Header Hang 'em and hide 'em.
Display Catalog Number 16-807
Enclosure Color White
Included in the Box 16" x 2.3" covers (3)90° elbowEnd caps (2)Installation templateHardware kitInstruction manual
Manufacturer Labor Warranty 5
Manufacturer Parts Warranty 5
MAP Price 0.0
Model CMK Mini
Operating Temperature UOM ° F
Product Type Cable duct
Subtitle Online and in-store order only
Supported Languages English
OmniMount CMK White Wall Cable Management Kit Questions
Questions and Answers
Where to Buy
$11.95
$19.95
$16.99
Code FALLSAVINGS33 : $5 Off Orders Over $50
Show all 6 stores
_
Product Reviews
Last update: Jul 6, 2009
OmniMount CMK White Wall Cable Management Kit Reviews
Most helpful positive review
Most helpful negative review
4.0
Cable Managament System
"Puts a perfect finish to a wall mounted HDTV. Gives you a choice of adhesive pads or wall anchors with screws. Paintable but matched my wallpaper just fine. Inexpensive for length included. Even came with an elbow. Plenty of room for all the cables you need. Using screws requires drilling many holes in the wall...." Read Full Review »
Apr 02, 2008 by BigNinja
See more positive OmniMount CMK White Wall Cable Management Kit reviews
3.0
Best for thin, individual cables
"While they are called 2 inch covers, you only get about 1 inch in total, 1/2 on each side, so it is best used with individual cables, like HDMI. If you are using RGB, you will need to separate the wires. Easy to install and looks good on the wall - especially once they are painted. Clean look...." Read Full Review »
Mar 25, 2009 by Jonathan D. Sarn
See more negative OmniMount CMK White Wall Cable Management Kit reviews
Displaying 1 - 5 of 11 Reviews
Show
Sort by
4.0
    Pros
  • Good Value
  • Got Mom's approval
    Cons
    Best Uses
"Puts a perfect finish to a wall mounted HDTV. Gives you a choice of adhesive pads or wall anchors with screws. Paintable but matched my wallpaper just fine. Inexpensive for length included. Even came with an elbow. Plenty of room for all the cables you need. Using screws requires drilling many ho …"  Read Full Review »
HDTV installation
HDTV installation
  • Picture of Product
Was this Audio Visual Cable & Connector review on the OmniMount CMK White Wall Cable Management Kit helpful to you?
Apr 2 2008
BigNinja
Oxnard, CA
Reviewed at:
Price: $11.95
[5 of 5 customers found this review helpful]
Hides Cables Great
4.0
"This is a great product to hide cables if your TV is wall mounted or want Hide cables anywhere else. You can use adhesive to hook this down or screw it down. You just stick the clips to it, then stick it to the wall,remove by sliding it off the clips, and run wires through it, then snap it back to t …"  Read Full Review »
 Report Abuse  (5)  (0)  0 comments
Jan 16 2009
Kamalpreet Singh
Amazon
Reviewed at:
Price: $19.95
Does the job
4.0
"As the title says, this product does its job, covering the cables. It paints very easily and blends reasonably well into the wall. It is pretty large (4") so you can definitely see it, but when you have lots of cables to hide, it has to be that way. The only real complaint I have is in the installat …"  Read Full Review »
Jul 5 2009
D. B. Samuel
New Haven, CT
Reviewed at:
Price: $19.95
Works great and looks good
5.0
"The Omnimount 4-inch works great. I am very happy with it and even bought another one. It looks really good and is very wide which is exactly what I needed. I am running a very thick HDMI cable, coax, cat-5, power, and rca from my equipment up to my TV. Because of a fireplace, everything had to …"  Read Full Review »
Jul 6 2009
Kevin Stephenson
Muscle Shoals, AL USA
Reviewed at:
Price: $19.95
[2 of 2 customers found this review helpful]
Better than expected
5.0
"I wanted to run the cables in the wall, but decided that would be too much work. This worked out great - when painted, the texture matches the wall perfectly and blends right in. Holds all the chunky cables securely and slides behind the tv and console easily. Perfect fit. A little pricey, but w …"  Read Full Review »
 Report Abuse  (2)  (0)  0 comments
Jun 12 2008
J. J. Huang
Elkridge, MD USA
Reviewed at:
Price: $19.95
pages: 1 2 3 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
$11.95
$19.95
$16.99
$19.99
Code SEARS5OFF50 : $5 Off Orders Over $50!
$19.99
Code KMART5OFF50 : Save $5 off $50 with coupon ends 12/31/09
$22.00
5% off orders at Abt.com
BizRate Rating Outstanding 9.4
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
