OmniMount Cch1p Set-top Center Channel Shelf
#5
4.6
based on 12 reviews
Ratings Distribution
5 star
8
4 star
3
3 star
1
2 star
0
1 star
0
Category Average
4.1
Low Price:
$24.70 at Abt Electronics
 Trusted:
$34.40 at OneCall
Find it at Amazon
$24.70 - $34.40
from 2 stores
Pros
  • Easy setup (7)
  • Attractive design (6)
  • Sturdy (5)
  • Quality mounting hardware (4)
  • Adjustable (1)
  • Easy to install (1)
  • Fast setup (1)
  • Interfaces well with tv (1)
See less See more
Cons
  • Flimsy (1)
  • Not so easy to install (1)
  • Setup complicated (1)
Best Uses
  • Basic use (4)
  • Home (3)
  • Saving space (3)
  • Surround sound speakers (2)
  • Audiophiles (1)
  • Bedroom (1)
  • Classroom (1)
  • Office (1)
  • Utilizing space (1)
Provided by Beach Audio
  • Adjustable support legs fit CRTs, LCDs, DLPs, and other projection TVs
  • Supports most any center channel speaker or, DVD, VCR, cable box, satellite or HD receiver
  • Low profile design
  • Platinum in door
  • OmniMount Cch1p Set-top Center Channel Shelf Questions
    Questions and Answers
    Where to Buy
    $24.70
    BizRate Rating Outstanding 9.4
    $34.40
    BizRate Rating Outstanding 9.1
    Product Reviews
    Last update: Oct 29, 2009
    OmniMount Cch1p Set-top Center Channel Shelf Reviews
    Most helpful positive review
    [1 of 1 customers found this review helpful]
    Most helpful negative review
    4.0
    Great product for a DLP, LCOS
    "I have a sony SXRD LCOS TV which is a rear projection TV similar to DLP, but with a different lamp type. The problem with these types of TV is that they have steep backs and finding a set top shelf can be difficult. This shelf works perfectly and sits well on top of the Television, it sturdy enough to hold a bit of weight and looks good. The only problem is that the instruction manual is more confusing then i..." Read Full Review »
    Aug 03, 2007 by Ez
    See more positive OmniMount Cch1p Set-top Center Channel Shelf reviews
    3.0
    Overall A Good Product
    "The unit itself is a great idea but the construction is por with the front tabs not screwing in well to the main plate. Other than this I am satisfied with the product...." Read Full Review »
    Sep 06, 2008 by Flounder
    See more negative OmniMount Cch1p Set-top Center Channel Shelf reviews
    Displaying 1 - 5 of 12 Reviews
    Show
    Sort by
    Liked it so much I bought another!
    4.0
      Pros
    • Attractive Design
    • Easy To Set Up
      Cons
    • None
      Best Uses
    • Audiophiles
    • Basic Use
    "This shelf is *almost* perfect. The front pegs could use some sort of foam/rubber to keep from scratching your television and the sticky pads shipped could do a better job, but those are very minor complaints. I liked this product so much I ordered a second. If you want to place components on top …"  Read Full Review »
    Was this Shelf System review on the OmniMount Cch1p Set-top Center Channel Shelf helpful to you?
    Oct 29 2009
    Jeremy in Texas
    Jasper, Tx
    I am:
    • Tech Savvy
    Reviewed at:
    Price: $24.70
    4.0
      Pros
    • Attractive Design
    • Quality Mounting Hardware
    • Sturdy
      Cons
    • Difficult Setup
      Best Uses
    • Utilizing Space
    "I have a sony SXRD LCOS TV which is a rear projection TV similar to DLP, but with a different lamp type. The problem with these types of TV is that they have steep backs and finding a set top shelf can be difficult. This shelf works perfectly and sits well on top of the Television, it sturdy enoug …"  Read Full Review »
     Report Abuse  (1)  (0)  0 comments
    Aug 3 2007
    Ez
    Bronx, NY
    I am:
    • Tech Savvy
    Reviewed at:
    Price: $24.70
    Pricey, but gets the job done.
    4.0
      Pros
    • Sturdy
      Cons
      Best Uses
    • Bedroom
    • Classroom
    • Home
    • Office
    "It isn't an eyesore! It is the only product of this type that I could find in a platinum finish. I overlooked it at first because of the price and I didn't think it was meant to hold my dvd player on top of my tv. After searching online for a while, and only finding ugly tv shelfs, I went back to th …"  Read Full Review »
    May 28 2007
    SassyCass
    Austin, TX
    I am:
    • Practical
    Reviewed at:
    Price: $24.70
    PErfect solution
    5.0
      Pros
    • Attractive Design
    • Easy Setup
    • Sturdy
      Cons
    • None
      Best Uses
    • Saving Space
    • Surround Sound Speakers
    "This is the perfect solution for my hi-end center channel speaker which weighs about 10 lbs. Previously had an entertainment center with "bridge" style shelf for that speaker over my 50" DLP.
    It's strong, sturdy, easy to install (directions aren't super clear as to what fasteners go where so you ha …"  Read Full Review »
    Dec 3 2007
    Clem Chowder
    Gainesville,FL
    I am:
    • Audiophile
    • Tech Savvy
    Reviewed at:
    3.0
      Pros
    • Easy To Adjust
    • Easy To Install
    • Interfaces Well With TV
      Cons
    • Flimsy
      Best Uses
    • Home
    "The unit itself is a great idea but the construction is por with the front tabs not screwing in well to the main plate. Other than this I am satisfied with the product. "
    Sep 6 2008
    Flounder
    San Diego
    I am:
    • Gearhead
    Reviewed at:
    Price: $34.40
    pages: 1 2 3 Next »
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
