OmniMount 4N1MP Medium Flat Panel Cantilever Mount
#566
3.0
based on 17 reviews
Ratings Distribution
5 star
3
4 star
7
3 star
0
2 star
1
1 star
6
Category Average
4.4
Low Price:
$79.97 at RadioShack
 Trusted:
$112.50 at pcRUSH
$79.99 at Sears
see all stores
$79.97 - $129.95
from 7 stores
More Images
Pros
  • Easy to install (5)
  • Multiple viewing angles (5)
  • Adjustable (4)
  • Sturdy (4)
  • Good value (3)
  • Interfaces well with tv (3)
  • Attractive design (2)
  • Durable (2)
  • Easy assembly (2)
  • Easy to move (2)
See less See more
Cons
  • Small capacity (2)
  • Arm extends far from wall (1)
  • Doesn't fit tv (1)
  • Flimsy (1)
  • I can't think of any (1)
  • Incorrect directions (1)
  • Interface somewhat margin (1)
  • Un-safe if use w 37"flat (1)
Best Uses
  • Bedroom (2)
  • Changing viewing angle (2)
  • Convenience (2)
  • Great corner bracket (1)
  • Home (1)
  • Not>17" pc monitor (1)
  • Office (1)
  • Space saver (1)
  • Tv location (1)
  • With a wall stud (1)
Provided by Mounts and More
OmniMount's new WorldMount Series offers maximum functionality! This universal articulating mount provides maneuverability, adaptability and a stylish look to compliment your flat panel. With smooth and easy tilt, pan and swivel adjustments, you can achieve the perfect viewing position every time!
Features:
  • Fits most screens 23" to 37"
  • VESA 100/200 compatible
  • Easy 3-step installation
  • Tilt, swivel and pan abilities
  • Touch of a finger maneuverability
  • Extends from 4.14" to 14.35"
  • Platinum finish
  • Holds up to 80 lbs
*May require mounting adapter
4N1-M Specifications
Need professional installation? Use the or the ! Give us a call with any questions!
Specification Description
Model 4N1-M, 4N1-M P, 4N1-MP, 4N1MP
UPC 728901016752
Accessory Indicator Yes
Benefits Engineered for reliability, this mount fits panel TVs from 23-37"Durable construction and design supports up to 80 lbs.VESA
Capacity UOM mAh
Country Of Origin China
Description Header From the floor to the wall with ease.
Display Catalog Number 16-149
Manufacturer Labor Warranty 12
Manufacturer Parts Warranty 12
MAP Price 0.0
Model 4N1-M
New Date Sun Nov 19 00:00:00 CST 2006
Operating Temperature UOM ° F
Product Type Wall mounts
Required to function Some TV models may require adapter plate 1600323.
Supported Languages English
OmniMount 4N1MP Medium Flat Panel Cantilever Mount Questions
Questions and Answers
Where to Buy
$129.95
$129.95
$79.99
Code SEARS5OFF50 : $5 Off Orders Over $50!
Show all 7 stores
Product Reviews
Last update: Oct 19, 2009
OmniMount 4N1MP Medium Flat Panel Cantilever Mount Reviews
Most helpful positive review
Most helpful negative review
4.0
My 2 cents, I'm a Professional Installer
"I'm a professional Audio/Video installer. This is one of my favorite wall mounts for corner applications. I have used it more than 30 times. I find it to be easy install on solid walls, sheetrock walls with wood studs (townhomes)and even sheetrock walls with alumunium/steel studs (apts) with the hilti toggle bolts (preferably used in corner applications.) It requires only the use of 2 lag bolts. Once the ..." Read Full Review »
Oct 19, 2009 by D the Installer
See more positive OmniMount 4N1MP Medium Flat Panel Cantilever Mount reviews
2.0
Can't live up to hype
"Several critical problems recommend against using this device for any TV weighing more than 40 pounds (about 19-22" more or less). First: both manufacturer and sellers seem to have no knowledge of how weight specs and ratings work. This is reflected in product description on the packaging...which is largely unusable to making a purchase decision. Even on this site (Radio Shack), the advertising says the device ..." Read Full Review »
Mar 01, 2009 by Expert
See more negative OmniMount 4N1MP Medium Flat Panel Cantilever Mount reviews
Displaying 1 - 5 of 17 Reviews
Show
Sort by
4.0
    Pros
  • Easy To Install
    Cons
  • None
    Best Uses
  • Changing Viewing Angle
I find it to be easy install on solid walls, sheetrock walls with wood studs (townhomes)and even sheetrock walls with alumunium/steel studs (apts) with …"  Read Full Review »
Was this TV Wall Mount review on the OmniMount 4N1MP Medium Flat Panel Cantilever Mount helpful to you?
Oct 19 2009
D the Installer
New York City
I am:
  • Power User
2.0
    Pros
  • None
    Cons
  • Insufficient Capacity
    Best Uses
  • Convenience
"Several critical problems recommend against using this device for any TV weighing more than 40 pounds (about 19-22" more or less). First: both manufacturer and sellers seem to have no knowledge of how weight specs and ratings work. This is reflected in product description on the packaging...which is …"  Read Full Review »
Mar 1 2009
Expert
Sacramento, Calif
I am:
  • High-End Shopper
Unsafe...DO NOT BUY!!!
1.0
    Pros
  • Attractive Design
  • Easy To Assemble
  • Easy To Move
  • Easy to Wire
  • Smooth Edges
    Cons
  • Flimsy Construction
    Best Uses
  • Convenience
  • Space Saver
"I bought this mount for a 37" Flat Screen Polaroid TV. Within a few months I noticed the arm was hanging crooked. Turns out, a part fell out of the main (weight bearing) arm. I contacted the manufacturer and sent them pictures of the defect, concerned that my TV would fall and injury someone. They a …"  Read Full Review »
Jun 21 2009
maylu
Florida
I am:
  • Practical
  • Stylish
Result'd in 37"LCD Smashed on my HEAD!!
1.0
    Pros
  • Multiple Viewing Angles
    Cons
  • UN-SAFE if use w 37"Flat
    Best Uses
  • Not>17" PC Monitor
"4N1-M Mount does NOT support LG37"LCD FlatScreens! In less than a week after the correctly installed product the MOUNT Failed @ the Swivel Bolts sheared and theentire weight of TV & 1/2 of the Mount/Plate and ALL fell down, forward and Screen shatered on my Head. Although not seriously hurt, not and …"  Read Full Review »
Mar 19 2008
Jon w/ Smashed FlatScreen
Ft. Lauderdale, FL
I am:
  • Heavy Construction Manage
  • Professional
[1 of 1 customers found this review helpful]
WORKED LIKE A CHARM
5.0
    Pros
  • Easy To Adjust
  • Easy To Install
  • Interfaces Well With TV
  • Sturdy
    Cons
  • None
    Best Uses
  • Bedroom
  • Home
  • Office
"IT dont get any better if u have a HEAVY 32" lcd hdtv like the insignia 32" model. but this mount held it unlike best buys own model that did not hold it and was flimzy. i couldnt be more satisfyed. all it took was anchoring screws into stud, mounting mount on tv, lifting tv up on to bracked that wa …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Jan 2 2008
Keith
Pittsburgh, PA
I am:
  • Gearhead
  • Professional
  • Tech Savvy
pages: 1 2 3 4 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
