OmniMount 42" to 63" Xtra Large Flat Panel Cantilever Mount
#7
4.9
based on 22 reviews
Ratings Distribution
5 star
19
4 star
3
3 star
0
2 star
0
1 star
0
Category Average
4.4
Low Price:
$279.98 at OneCall
 Trusted:
$279.98 at Vanns.com
Find it at Amazon
$279.98 - $499.99
from 11 stores
More Images
Pros
  • Attractive design (7)
  • Supports weight (6)
  • Easy assembly (5)
  • Easy to move (4)
  • Easy to wire (4)
  • Holds all components (3)
  • Smooth edges (3)
  • Can support weight (2)
  • Adjustable (1)
  • Easy to install (1)
See less See more
Cons
  • Heavy / bulky (2)
  • Limited adjustability (1)
  • Pricey (1)
Best Uses
  • Space saver (4)
  • Convenience (3)
  • Bedroom (2)
  • Decoration (2)
  • Changing viewing angle (1)
  • Family/living room (1)
  • Great for large rooms (1)
Provided by OneCall
Combines CL-X with UAL Universal Adapter plate
The new Wishbone Series flat panel cantilever wall mounts will heighten the wow factor of any television room as much as the new LCD or plasma screen it is holding. Designed with the consumer and installer in mind, these flat panel cantilever mounts are as practical as wall mounts come, yet highly versatile and easy to install. Unlike traditional basic wall brackets, OmniMount`s Wishbone Series cantilevers allow the flat panel television to be extended away from the wall for multiple viewing options. Rugged die cast aluminum construction and included wall stud mounting hardware secures not only the flat panel television, but peace of mind as well. The CL-X offers a dual-arm configuration with a dual-stud mounting bracket for added strength and reliability. A double-capacity cable management system allows for twice as many unsightly wires to be neatly tucked away within the cantilever`s housing for a clean, organized look.
  • Tilt, pan and swivel for optimum viewing
  • Innovative 4-link tilting mechanism for a secure, smooth movement
  • Double-arm i-beam design for added strength
  • Die-cast aluminum construction for maximum support in a lightweight mount
  • Lift n` Lock(TM) for easy installation
  • Integrated cable management hides wires
  • Dual j-box openings for A/V and electrical connections
  • Includes universal adapter with two sets of rails for greater panel compatibility
  • Rack and pinion mechanism for easy self-centering
  • A double-capacity cable management system is seamlessly integrated into the UCL-X, allowing for twice as many cables to be neatly tucked away within the cantilever`s housing.
  • VESA 100 and 200 compatible
  • Lift and lock mounting system
  • Weight capacity: 200 lbs.
  • Dual arm cable management
  • Specification Description
    Model UCL-X P, UCL-XP, UCLX, UCLX-P
    UPC 728901014956
    Accessory Indicator Yes
    Benefits Accommodates screen sizes of 42" to 63" for a variety of mounting optionsConfidently place up to 200 lbs. on this stylish wall mount<
    Capacity UOM mAh
    Country Of Origin China
    Description Header That right support.
    Display Catalog Number 55011880
    Manufacturer Labor Warranty 2
    Manufacturer Part Number UCL-XP
    Manufacturer Parts Warranty 2
    MAP Price 0.0
    Model UCL-XP
    Operating Temperature UOM ° F
    Product Dimensions UOM inches
    Product Type Wall mounts
    Product Weight UOM pounds
    Supported Languages English
    OmniMount 42" to 63" Xtra Large Flat Panel Cantilever Mount Questions
    Questions and Answers
    Where to Buy
    Product Reviews
    Last update: Oct 5, 2009
    OmniMount 42" to 63" Xtra Large Flat Panel Cantilever Mount Reviews
    Displaying 1 - 5 of 22 Reviews
    Show
    Sort by
    [1 of 1 customers found this review helpful]
    "The Omnimount UCL-Xp is ...
    5.0
    "The Omnimount UCL-Xp is a solid, thoughtfully designed wall mount that exceded my expectations. I am an engineer and could not be happier with the attention to detail, strength and ease of installation. It is hefty (need help to install) but provides multiple adjustments that allow for a light touch …"  Read Full Review »
    Was this TV Wall Mount review on the OmniMount 42" to 63" Xtra Large Flat Panel Cantilever Mount helpful to you?
     Report Abuse  (1)  (0)  0 comments
    Oct 18 2006
    Peabody32
    Undisclosed
    Reviewed at:
    Great Wall Mount
    5.0
      Pros
    • Attractive Design
    • Easy To Assemble
    • Easy To Move
    • Easy to Wire
    • Holds All Components
    • More »
      Cons
    • Expensive
      Best Uses
    • None
    "This is a serious wall mount. If you want to hang a large flat panel, I highly recommend this mount. I mounted my 46" LCD with this mount. It's extremely stable and easy to articulate into any position. "
    Mar 2 2009
    Rob
    New Jersey
    I am:
    • Practical
    Reviewed at:
    Price: $279.98
    Really Heavy Duty
    5.0
      Pros
    • Attractive Design
    • Easy To Assemble
    • Easy To Move
    • Smooth Edges
    • Supports Weight
      Cons
    • None
      Best Uses
    • None
    "Easy to install. Looks complicated when you first unpack. Take a deep breath and throw out 90% of the un-needed hardware that is included for various brands. Installs in 15 minutes once you figure out what the matching hardware is for your TV. "
    Jan 26 2009
    BuckeyeBill
    Hubbard, Oh
    I am:
    • High-End Shopper
    Reviewed at:
    Price: $279.98
    Very sturdy and adjustable
    5.0
      Pros
    • Can Support Weight
    • Easy To Adjust
    • Easy To Install
    • Interfaces Well With TV
    • Sturdy
      Cons
    • None
      Best Uses
    • Bedroom
    • Changing Viewing Angle
    • Family/Living Room
    "I have 2 of these for large LCD tv's. I used them in corners to hold the tv at an angle across the corner. The installation is not difficult but is a 2 person job. "
    Aug 31 2009
    Mike Toledo OH
    Toledo, OH
    I am:
    • Enthusiast
    Reviewed at:
    Price: $279.98
    Could Support a Small Family
    5.0
      Pros
    • Good construction
    • High quality
      Cons
    • None
      Best Uses
    "This mount is fantastic. It is super strong and can hold virtually any size flat panel t.v. The best part is how easy the mount swivels, tilts, and expands. This mount hold a 60 in lcd and my 8 year old daughter has no problems moving the tv around for Hannah Montana. Couldn't be happier. "
    Jun 30 2009
    Roger from Maine
    Cumberland, Maine
    Reviewed at:
    Price: $339.00
    pages: 1 2 3 4 5 Next »
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
