OmniMount 32" To 60" Universal Flat Panel Mount with Tilt (2N1-L)
#465
3.5
based on 6 reviews
Ratings Distribution
5 star
0
4 star
5
3 star
0
2 star
0
1 star
1
Category Average
4.4
$79.97 - $119.00
from 14 stores
More Images
Pros
  • Easy to install (4)
  • Sturdy (4)
  • Interfaces well with tv (3)
  • Attractive design (1)
  • Supports weight (1)
See less See more
Cons
  • Difficult to adjust (1)
  • Difficult to assemble (1)
  • Limited adjustability (1)
  • Marginal tilt capability (1)
  • Not long enough (1)
Best Uses
  • Bedroom (3)
  • Home (2)
  • Classroom (1)
  • Convenience (1)
  • Decoration (1)
  • Office (1)
  • Space saver (1)
Provided by LCD Mounts Online
OmniMount's new WorldMount Series offers stylish and durable design to compliment your flat panel display! This universal wall mount will sit remarkably flush to the wall and offer an adjustable tilting feature to provide an optimum viewing angle.
Features:
  • Universal design fits most screens 32" to 54"
  • Easy 3-step installation with Lift 'n' Lock system
  • Low mounting profile
  • Built in security bar
  • Available in black or platinum
  • Adjustable tilt between -5 and +15 degrees
  • Weight capacity: 175 lbs
2N1-L Installation Instructions
Need professional installation? Use the or the ! Give us a call with any questions!
Specification Description
Model 2N1-L, 2N1-L B, 2N1-LB, 2N1-LP
UPC 728901019357
Accessory Indicator Yes
Benefits Low-profile design allows your flat panel to fit snugly against the wallFlexible tilt angles allow you to adjust your viewing angle t
Capacity UOM mAh
Country Of Origin Switzerland
Description Header Hang it up.
Display Catalog Number 16-311
Included in the Box Large flat panel tilt mountMounting hardware
Manufacturer Labor Warranty 2
Manufacturer Parts Warranty 2
MAP Price 0.0
Model 2N1-L
New Date Mon Feb 19 00:00:00 CST 2007
Operating Temperature UOM ° F
Product Dimensions UOM inches
Product Height 2.62
Product Length 32.37
Product Type Wall mounts
Product Weight 15
Product Weight UOM pounds
Product Width 21
Supported Languages English
OmniMount 32" To 60" Universal Flat Panel Mount with Tilt (2N1-L) Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: May 13, 2008
OmniMount 32" To 60" Universal Flat Panel Mount with Tilt (2N1-L) Reviews
Displaying 1 - 5 of 6 Reviews
Show
Sort by
Great mount, but I wish it was longer...
4.0
    Pros
  • Easy To Install
  • Interfaces Well With TV
  • Sturdy
    Cons
  • Not long enough
    Best Uses
  • Bedroom
  • Classroom
  • Home
  • Office
"The mount works great, and I would recommend it to friends/family. The only problem I had with it is that it wasn't long enough to mount centered on my wall. I have 3 studs in a recessed space that was designed to be a home entertainment center area. The studs are all about 16" apart. The mount's ou …"  Read Full Review »
Was this TV Wall Mount review on the OmniMount 32" To 60" Universal Flat Panel Mount with Tilt (2N1-L) helpful to you?
Jan 13 2008
WoRkAh0LiC
Chino, CA
I am:
  • Gearhead
Reviewed at:
Price: $89.95
Quality and Easy to Install
4.0
    Pros
  • Easy To Install
  • Sturdy
    Cons
  • Difficult To Adjust
    Best Uses
  • Bedroom
"Great product with straight forward instructions. Adjustment is a challenge to get a firm grip with the limited space (between bracket and LCD) and tool provided. "
May 13 2008
BadaBing66
New York
I am:
  • Tech Savvy
Reviewed at:
Price: $89.95
Overall Pretty Good
4.0
    Pros
  • Easy To Install
  • Sturdy
    Cons
  • Marginal Tilt Capability
    Best Uses
  • Home
"Solid product that came with all the necessary parts to match numerous configurations. The tilt capability left something to be desired. "
Dec 18 2007
Retired
Minneapolis
I am:
  • Tech Savvy
Reviewed at:
Price: $89.95
Great Wall Mount!
4.0
    Pros
  • Attractive Design
  • Supports Weight
    Cons
  • Difficult To Assemble/Wire
    Best Uses
  • Convenience
  • Decoration
  • Space Saver
"Assembly was easy except for tightening the tilt screws, which were recessed and hard to get to. "
Mar 5 2008
GdaddyTexas
Plano, Texas
I am:
  • Bargain Hunter
  • Practical
Reviewed at:
Happy on the inside
4.0
    Pros
  • Easy To Install
  • Sturdy
    Cons
  • Limited Adjustability
    Best Uses
  • Bedroom
"[...] Easy to mount on the wall. I am very happy with this product and recommend it "
May 13 2008
T spoon
Boston, MA
I am:
  • Technically Challenged
Reviewed at:
Price: $89.95
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
