OCZ Technology Vendetta CPU Cooler
#60
4.5
based on 34 reviews
Ratings Distribution
5 star
21
4 star
11
3 star
0
2 star
1
1 star
1
Category Average
4.3
$24.00 - $29.99
from 4 stores
More Images
Provided by TigerDirect
OCZ Vendetta CPU Cooler - Socket, 754, 775, 939, AM2
OCZ Technology Vendetta CPU Cooler Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Oct 25, 2009
OCZ Technology Vendetta CPU Cooler Reviews
Most helpful positive review
Most helpful negative review
5.0
Wasn't sure this product ...
"Wasn't sure this product would help my overheating situation but did it ever... and then some! Board I have (Socket 754) allows cpu overclock between 200MHz (default) to 300MHz). Without the 'Vendetta', could only reach 202MHz, board would shut down at 203MHz... with the Vendetta? The board was hitting 210MHz ( I incremented 1 step at a time...) with the CPU temp registering a mere 139 Degrees F! The Vendett..." Read Full Review »
May 23, 2009 by harbek2000
See more positive OCZ Technology Vendetta CPU Cooler reviews
2.0
I bought this to use on ...
"I bought this to use on my AMD 6000 3.1. be warned the mounting for a AMD is very weak,I believe this Heatsink was designed for a Intel as Intel mounting is much more solid.The base didn't even cover my whole CPU and I had to point it up or down,due to AMD type mount you cannot point it towards the back blowing towards the rear outtake fan. It cooled my CPU by 4c at idle and 7c at full load and this is useing OC..." Read Full Review »
Feb 16, 2009 by Jcdew
See more negative OCZ Technology Vendetta CPU Cooler reviews
Displaying 1 - 5 of 34 Reviews
Show
Sort by
5.0
board was h …"  Read Full Review »
Was this Computer Fan & Cooling System review on the OCZ Technology Vendetta CPU Cooler helpful to you?
May 23 2009
harbek2000
Undisclosed
Even though the Vendetta ...
5.0
"Even though the Vendetta 2 is priced the same at newegg; it wouldn't fit my new build which is not my primary so I went with this one instead because all of the newer bigger heat sinks are basically the same dimensions--the Cooler Masters, the True and Dark Knight.
I'm only going from 2.8 to 3.2 (m …"  Read Full Review »
Apr 12 2009
crashdummy
Undisclosed
I have a Phenom 9850 quad ...
4.0
"I have a Phenom 9850 quad core. I tried the stock fan, which is very loud--it was the loudest fan in my case BY FAR, which includes 2 80mm case fans, and a Radeon 4850 video card. I did alot of research and found this one well reviewed. This is fairly large--if you have a full sized case, no probl …"  Read Full Review »
Aug 21 2008
atlascott
Undisclosed
I ordered this cooling ...
4.0
"I ordered this cooling unit when I was building a new PC because reviews of the Intel Quad Core Processor I was ordering had mentioned that the stock cooler was garbage and it was. I opened up my box and couldn't believe the size of the box my heatsink was in. This thing looks like a radiator for …"  Read Full Review »
Jul 2 2009
Rich
Undisclosed
Make sure you have ...
4.0
"Make sure you have decided on the type of case you uses. I found that the crouser case has a fan and duct for the cpu cooler but this cooler works so well the duct is not needed. Cant use it any way, I do have a fan in the place of the fand and duct just to help pull air out. The Opperational temp i …"  Read Full Review »
May 28 2009
Clint
Undisclosed
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
