NXG Ruby Series 19.68-Ft. Optical Audio Toslink Cable
#2097
3.0
based on 2 reviews
Ratings Distribution
5 star
1
4 star
0
3 star
0
2 star
0
1 star
1
Category Average
4.1
$51.79 at RadioShack
Find it at Amazon
Find it at Ebay
$51.79
from 1 store
Pros
  • Consistent performance (1)
  • Good length (1)
See less See more
Cons
  • Inconsistent signal (1)
  • No performance increase (1)
  • Wears out quickly (1)
Best Uses
  • High-end equipment (1)
Provided by RadioShack
Get the sound quality your want with this optical digital audio cable from NXG.
Specification Description
Model nxr-7006
Benefits Accurate digital audio signal transfer for greater clarity with enhanced transparencyIdeal for use with Dolby® Digital and DTS
Cable Compliant Standards RoHS
Cable Length 19 ft
Cable Type Toslink
Capacity UOM mAh
Color Red
Country Of Origin China
Description Header Hear the movie the way it was meant to be heard.
Display Catalog Number 55029455
Enclosure Color Red
End Product Indicator Yes
Jacket Material PVC
Left Connector(s) Toslink
Manufacturer Labor Warranty 1
Manufacturer Part Number nxr-7006
Manufacturer Parts Warranty 1
MAP Price 43.99
Model NXR-7006
Operating Temperature UOM ° F
Product Dimensions UOM feet
Product Disclaimer *Dolby is a registered trademark of Dolby Laboratories Licensing Corporation. DTS is a registered trademark of Digital Theater Systems, Inc.
Product Length 19.68
Product Type Fiber optic cables
Right Connector(s) Toslink
Supported Languages English
NXG Ruby Series 19.68-Ft. Optical Audio Toslink Cable Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 2, 2009
NXG Ruby Series 19.68-Ft. Optical Audio Toslink Cable Reviews
Displaying 1 - 2 of 2 Reviews
Show
Sort by
Too many problems
1.0
    Pros
  • Good Length
    Cons
  • Inconsistent Signal
  • No Performance Increase
  • Wears Easily
    Best Uses
  • None
"The first cable never worked and I had to return it. The second one worked for two months and now I have to return it for a new one. This has not been very compatible for our new home theatre system. "
Was this Audio Visual Cable & Connector review on the NXG Ruby Series 19.68-Ft. Optical Audio Toslink Cable helpful to you?
Nov 2 2009
JL
Kalamazoo, MI
I am:
  • Casual User
Could have used instructions
5.0
    Pros
  • Consistent Performance
    Cons
  • None
    Best Uses
  • High-End Equipment
"Store Manager, TJ, was extremely knowledgeable and helpful. "
Apr 24 2009
Sparky
Sanford, NC
I am:
  • Casual User
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
