NXG NX-PRO103i 10" 3-Way Ceiling Speaker Pair
#921
3.5
based on 2 reviews
Ratings Distribution
5 star
1
4 star
0
3 star
0
2 star
1
1 star
0
Category Average
4.4
$239.99 at RadioShack
Find it at Amazon
Find it at Ebay
$239.99
from 1 store
Pros
  • Great sound quality (2)
  • Attractive design (1)
  • Crisp sound (1)
  • Easy to connect (1)
  • Powerful (1)
See less See more
Cons
  • Grille covers bad design (1)
Best Uses
  • Ceiling or wall mounts (1)
  • Home theater (1)
Provided by RadioShack
NXG set a new standard for architectural speaker systems with their 10" 3-Way ceiling speakers.
Specification Description
Model NX-PRO103i
Additional features Cut out: 11.75" diameter
Benefits 150 watts provide maximum power handlingMinimum diffraction pivoting 1" fluid-cooled, high-tenacity teteron dome tweeter3.5"
Capacity UOM mAh
Connectivity technology Wired
Country Of Origin China
Description Header Maximum sound from your ceiling.
Display Catalog Number 55028957
Enclosure Color White
End Product Indicator Yes
Frequency response 28Hz-22kHz
Grille color White
Impedance 8 ohms
Included in the Box 10" speakers (2)
Inputs 2 x Post Terminal(Audio)
Manufacturer Labor Warranty 2
Manufacturer Part Number NX-PRO103i
Manufacturer Parts Warranty 2
MAP Price 239.99
Model NX-PRO103i
Operating Temperature UOM ° F
Power range 125-150 watts
Product Depth 5.5
Product Diameter 13
Product Dimensions UOM inches
Product Type Home speakers
Product Weight UOM pounds
Sensitivity 90 dB
Speaker type Ceiling & in-wall
Speakers included 2
Supported Languages English
Tweeter size 1 inches
Tweeter type High-tenacity teteron dome
Woofer size 10 inches
Woofer surround Rubber
Woofer type Metallic-anodized graphite-filled injection molded
NXG NX-PRO103i 10" 3-Way Ceiling Speaker Pair Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Oct 14, 2009
NXG NX-PRO103i 10" 3-Way Ceiling Speaker Pair Reviews
Displaying 1 - 2 of 2 Reviews
Show
Sort by
Best Ceiling Speaker Period
5.0
    Pros
  • Attractive Design
  • Crisp Sound
  • Easy To Connect
  • Great Sound Quality
  • Powerful
    Cons
  • None
    Best Uses
  • Home Theater
"These are the best sounding ceiling speakers period. I've demoed Klipsch, Jamo, Niles, Infinity, NHT and others. None could match the audio performance and these were 1/2 to 1/3 the price of the others. Previous reviewer gave them a 2 overall based on their grill design? Yea it's not the best, but w …"  Read Full Review »
Was this Speaker & Subwoofer review on the NXG NX-PRO103i 10" 3-Way Ceiling Speaker Pair helpful to you?
Oct 14 2009
Soundman
Lincoln NE
I am:
  • Audiophile
  • Movie Enthusiast
  • Professional
  • Tech Savvy
Poor Designed Grille Covers
2.0
    Pros
    Cons
    Best Uses
"The speakers deliver quality sound and performance. Once the grille cover is removed to screw the speaker into a mounting surface its impossible to re-attach them back to the assembly. The company probably had a machine along the assembly line to place them on the unit. When you try to re-attach th …"  Read Full Review »
May 2 2009
Paul
Kingwood, TX
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
