Niles OS7.3 Black (Pr) 7 Inch 2-Way High Performance Indoor Outdoor Speakers
#254
5.0
based on 1 review
Ratings Distribution
5 star
1
4 star
0
3 star
0
2 star
0
1 star
0
Category Average
4.4
$503.96 at OneCall
Find it at Amazon
Find it at Ebay
$503.96
from 1 store
Pros
  • Attractive design (1)
  • Crisp sound (1)
  • Easy to connect (1)
  • Great sound quality (1)
  • Powerful (1)
See less See more
Best Uses
  • Basic systems (1)
  • Home theater (1)
  • Outdoors (1)
Provided by OneCall
Niles once again raises the bar. With their first OS Indoor/Outdoor models they revealed a radical new understanding of loudspeaker capabilities. Niles original OS Indoor/Outdoor loudspeakers are constantly praised for their ability to deliver exemplary reliability and outstanding sound quality. These attributes have made Niles OS Indoor/Outdoor loudspeakers the best selling loudspeakers in their class.
Woofer Technology
  • Integrated woofer/baffle assembly increases cone area to provide powerful bass output
  • 7 Mica-filled polypropylene cone is extremely rigid to reduce breakup and lower distortion
  • Butyl rubber cone surround damps resonance and provides exceptional durability
    Tweeter Technology
  • 1 UltraSilk dome with fluid-cooling and ultra-wide dispersion for clear, detailed and extended high frequencies
    Patent Pending Integrated Woofer/Baffle Assembly
  • Increases the woofer cone-area to cabinet-width ratio for enhanced bass output
    Interlaced Carbon Fiber Woofer Cone
  • Reduces breakup and lowers distortion
    Butyl Rubber Woofer Cone Surround
  • Damps resonance and provides exceptional durability
    Dispersion Stabilizer
  • Distributes midrange tones for clear off-axis sound
    Tri-laminate Teteron Dome Tweeter
  • 1 fluid-cooled tweeter provides ultra-wide dispersion for clear, detailed and
    extended high-frequencies
    Weatherproof Engineering
  • Enables OS loudspeakers to handle extreme hot, cold and moist environments,
    exceeding the military`s strict anti-corrosion specification MIL-STD-883D
    Advanced Material Science
  • Elevates appearance and longevity of the cabinet and grille, plus enhances the
    performance of the woofers, tweeters and crossovers
    Architectural Friendly Design
  • Delivers stellar acoustical performance yet tucks discretely away into corners and
    under eaves
    Low Diffraction Grille and Front Baffle
  • Ensures that the sound waves emanating from the woofer and tweeter are not
    reflected by the surrounding parts of the loudspeaker for precise imaging and
    acoustical accuracy
    Rigid, Acoustically Inert Cabinet
  • Prevents transmission of unwanted vibrations for clean and dynamic bass response
    All-Weather Versatility
  • Reduces installation limitations to provide great sound from the beaches of Miami
    to the harsh winters of Minneapolis
    Home Theater Applicability
  • Enables OS loudspeakers to be used as left, center, right, or surround loudspeakers
    in home theater systems
    Integrated Mounting Bracket and Shelf Stand
  • Provide a variety of secure, quick and easy mounting solutions
    Tapered Shape
  • Facilitates mounting in corners and under eaves
    Inverted Gold Plated 5-Way Binding Posts
  • Repel moisture and ensure positive connections in virtually any conditions over
    long periods of time
  • Specification Description
    Model FG00991
    UPC 760514009912
    Application Indoor / Outdoor
    Color Black
    Depth (Inches) 9.1875
    Frequency Response 65Hz - 21kHz
    Height (Inches) 13.3
    Impedance 8 ohms
    Sensitivity 91dB
    Single Channel Yes
    Speaker Terminals 5-Way Binding Post
    Speaker Type Outdoor
    Water Resistant Yes
    Weight (Pounds) 18
    Width (Inches) 8.1875
    Niles OS7.3 Black (Pr) 7 Inch 2-Way High Performance Indoor Outdoor Speakers Questions
    Questions and Answers
    Where to Buy
    $503.96
    BizRate Rating Outstanding 9.1
    Product Reviews
    Last update: Jul 27, 2009
    Niles OS7.3 Black (Pr) 7 Inch 2-Way High Performance Indoor Outdoor Speakers Reviews
    Displaying 1 - 1 of 1 Reviews
    Show
    Sort by
    These speakers are fantastic
    5.0
      Pros
    • Attractive Design
    • Crisp Sound
    • Easy To Connect
    • Great Sound Quality
    • Powerful
      Cons
    • None
      Best Uses
    • Basic Systems
    • Home Theater
    • Outdoors
    "My system includes 8 outdoor speakers - 4 pair placed strategically around the patio/pool area.
    I have been using Niles 0S5 series - they have done well.
    After 8 years I needed to replace a set - and stepped up to the Niles OS7 series. Wow - what a difference. These speakers are powerful, have a …"  Read Full Review »
    Was this Speaker & Subwoofer review on the Niles OS7.3 Black (Pr) 7 Inch 2-Way High Performance Indoor Outdoor Speakers helpful to you?
    Jul 27 2009
    none
    charlotte nc
    I am:
    • Musically Inclined
    • Practical
    Reviewed at:
    Price: $503.96
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
