Niles Audio SS-6
#117
5.0
based on 2 reviews
Ratings Distribution
5 star
2
4 star
0
3 star
0
2 star
0
1 star
0
Category Average
4.3
Low Price:
$143.95 at OneCall
 Trusted:
$143.96 at Your Electronic Warehouse
Find it at Amazon
$143.95 - $144.99
from 3 stores
More Images
Pros
  • Great sound quality (3)
  • Easy setup (2)
  • Attractive design (1)
  • Compact (1)
  • Durable (1)
See less See more
Best Uses
  • Basic systems (1)
  • Entertainment (1)
  • Large rooms (1)
  • Smaller rooms / apartments (1)
Provided by OneCall
Power handling: 100 watts per channel
Protection circuit safeguards receiver/amplifier
Spring-loaded push terminals on rear panel accommodate up to 14 gauge wire
72 adhesive-backed room identification labels
Requires an amplifier that is compatible with a 4 ohm speaker
Dimensions: 11-1/2" wide x 2" high x 6-3/4" deep
Approximate shipping weight: 5 lbs.
Niles Audio SS-6 Questions
Questions and Answers
Where to Buy
Niles Audio SS-6
Product Reviews
Last update: Apr 27, 2009
Niles Audio SS-6 Reviews
Displaying 1 - 2 of 2 Reviews
Show
Sort by
Great for your Home Audio needs
5.0
    Pros
  • Clean Sound
  • Easy To Set Up
    Cons
  • None
    Best Uses
  • Basic Systems
  • Larger Rooms
  • Smaller Rooms
"The Niles SS-6 was an easy fit for me. I had a Niles SS-4. I recently added a sunroom to my home which added another zone and 2 speakers to hook up. I now had 5 zones hooked up. The Niles SS-6 gives me room to expand up to 6 zones. I might also add that I use the Niles volume controls for each of my …"  Read Full Review »
Apr 27 2009
Joe Hoffman
Maumee, Ohio
I am:
  • Musically Inclined
  • Practical
  • Tech Savvy
Reviewed at:
Price: $143.95
Good Product, Good Price
5.0
    Pros
  • Attractive Design
  • Clear sound
  • Compact
  • Durable
  • Easy To Set Up
  • More »
    Cons
  • None
    Best Uses
  • Entertainment
"Easy to install. Even for me, which says a lot. Used in a new home, pre-wired for stereo but had to hook up myself. Stereo company wanted over $1000 to come out. I did set up myself for much, much less. Sounds and works great. "
Jun 19 2008
rudy
Chester Springs, PA
I am:
  • Technically Challenged
Reviewed at:
Price: $144.99
Email Address: (required)
Comments:
or Cancel
Where to Buy
Niles Audio SS-6
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
