Nikon SC-28 TTL Coiled Remote Cord
#5
4.6
based on 88 reviews
Ratings Distribution
5 star
58
4 star
25
3 star
3
2 star
2
1 star
0
Category Average
4.3
Low Price:
$54.95 at B&H Photo Video
 Trusted:
$54.95 at Adorama
Find it at Amazon
$54.95 - $81.00
from 8 stores
More Images
Pros
  • Lightweight (55)
  • Reliable (41)
  • Easy to use (37)
  • Well built / quality construction (28)
  • Durable (25)
  • Convenient interface (22)
  • Consistent output (9)
  • Versatile (8)
  • Easy to pack (5)
  • Fast recycling (4)
See less See more
Cons
  • Pricey (4)
  • Weak construction (2)
  • A little short (1)
  • Bulky (1)
  • Bulky and cord is to long (1)
  • Can block lens (1)
  • Difficult to shorten (1)
  • Hot shoe foot too fragile (1)
  • Needs another foot (1)
Best Uses
  • Fill flash (38)
  • Lighting (30)
  • Photography (25)
  • Portraits (21)
  • General purpose (18)
  • Night photography (16)
  • Photojournalism (14)
  • Sports photography (8)
  • Close -ups (6)
  • Tote along (6)
Provided by CameraWorld.com
3 feet coiled cord connects multiple SB-600 and or SB-800 Speedlights to selected Nikon SLR's with a standard ISO accessory shoe (D1 series, D2H, D70, D100, F5, F100, N80, N75 or N65)
Up to two units can be connected to the SC-28's terminals through the TTL Multi-flash Sync cord SC-26 or SC-27 for TTL Multi-flash photography.
Specification Description
Model 4765, SC 28
UPC 018208047659
System Dedication Nikon
Nikon SC-28 TTL Coiled Remote Cord Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 16, 2009
Nikon SC-28 TTL Coiled Remote Cord Reviews
Most helpful positive review
[6 of 6 customers found this review helpful]
Most helpful negative review
[0 of 1 customers found this review helpful]
4.0
Almost Perfect!
"I just got this yesterday from the local Wolf Camera and I have to say that this cable does what it is made for and is exactly what Nikon claims. Works flawlessly on my Nikon D40 and SB-600. The only thing I wish it had was a "hotshoe like" connector on the bottom of the flash side of the cable, so that I could use the flash stand that came with the SB-600.. Looks like I'll have to get a small tripod. Other than..." Read Full Review »
Jul 24, 2008 by BluAlien
See more positive Nikon SC-28 TTL Coiled Remote Cord reviews
3.0
Unrealiable after 1st failure!
"I purchase about two SB-28 units per year. They are extremely reliable until first failure, and then become sporatic and unrealiable. Plastic housing for female ISO is weak-link. I shoot 40-50 events per year. Plastic housing splits after 20 or so events(2000-2500)shots. I always carry a spare and now consider this limited life in my pricing...." Read Full Review »
Dec 29, 2008 by Don
See more negative Nikon SC-28 TTL Coiled Remote Cord reviews
Displaying 1 - 5 of 88 Reviews
Show
Sort by
Almost Perfect!
4.0
    Pros
  • Reliable
  • Strong Construction
    Cons
  • None
    Best Uses
  • Fill Flash
  • Lighting
  • Photography
"I just got this yesterday from the local Wolf Camera and I have to say that this cable does what it is made for and is exactly what Nikon claims. Works flawlessly on my Nikon D40 and SB-600. The only thing I wish it had was a "hotshoe like" connector on the bottom of the flash side of the cable, so …"  Read Full Review »
Was this Camera Flash Accessory review on the Nikon SC-28 TTL Coiled Remote Cord helpful to you?
 Report Abuse  (6)  (0)  0 comments
Jul 24 2008
BluAlien
California
I am:
  • Hobbyist/Enthusiast
Great quality, worth the $$
5.0
    Pros
    Cons
  • Pricey
    Best Uses
  • Off camera flash
"Compared to "knock-off" cords, this one is pricey, but the quality far exceeds the others. The only downside is that it does not have a hot shoe foot built into the end that accepts the flash (for use with brackets, etc). It does have a 1/4-20 female thread and the Manfrotto metal shoe adapter recom …"  Read Full Review »
Nov 16 2009
FE Fan
Pittsburgh, PA
I am:
  • Photo Enthusiast
Reviewed at:
Price: $54.95
Get that speedlight off the camera
5.0
    Pros
  • Easy To Pack
  • Easy to Use
  • Lightweight
  • Reliable
    Cons
  • None
    Best Uses
  • Close -ups
  • Special Events
  • Tote Along
  • Travel
"Perfect for getting the speedlight off-center for macro lighting, without the need for using the built-in flash for command (and defeating the purpose of getting the flash off the camera in the first place). Compact, inexpensive, and works great. Get the 1 to 3 meter cord for wide-angle shots. "
Nov 5 2009
cav2108
Austin, TX
I am:
  • Semi-pro Photographer
Reviewed at:
Price: $54.95
[2 of 2 customers found this review helpful]
Useful for getting off-camera TTL
5.0
    Pros
  • Lightweight
  • Reliable
    Cons
    Best Uses
  • Fill Flash
  • Lighting
  • Night Photography
  • Photography
  • Photojournalism
  • More »
"It's built well, it stretches quite a ways, it does what it's supposed to. The only thing it needs is a metal foot on the flash end to go with the screw mount. This would allow for a little more flexibility in attaching the flash end to flash brackets or other supports. "
 Report Abuse  (2)  (0)  0 comments
Feb 10 2007
Vince
Nebraska
I am:
  • Professional
Reviewed at:
Price: $54.95
[1 of 1 customers found this review helpful]
Simple and Effective
5.0
    Pros
  • Controls the light angle
  • Convenient Interface
  • Lightweight
  • Never in the way
  • Reliable
  • More »
    Cons
  • None
    Best Uses
  • Photojournalism
"Some good friends recently asked me to shoot their wedding. That meant taking the camera hand-held for most of the frames. I wanted a little more dramatic lighting than you get shooting straight ahead with the flash mounted on the camera. And besides I needed to be able to quickly switch from lan …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Apr 10 2008
Bob
Rio Rancho, NM
I am:
Reviewed at:
Price: $54.95
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
