Nikon SB-400 Speedlight Unit
#5
4.5
based on 283 reviews
Ratings Distribution
5 star
161
4 star
107
3 star
13
2 star
2
1 star
0
Category Average
4.3
$5.99 - $129.99
from 16 stores
Pros
  • Lightweight (229)
  • Consistent output (147)
  • Fast recycling (141)
  • Durable (139)
  • Easy to use (123)
  • Quiet (60)
  • Easily interchangeable (59)
  • Versatile (44)
  • Powerful (42)
  • Easy to clean (40)
See less See more
Cons
  • Slow recycling (5)
  • Weak output (5)
  • Not interchangeable (2)
  • Not sure yet (2)
  • Pricey (2)
  • Underpowered (2)
  • Weak casing (2)
  • Add weight to camera (1)
  • Bulky (1)
Best Uses
  • General purpose (195)
  • Portraits (124)
  • Fill flash (72)
  • Night photography (62)
  • Back-up (33)
  • Photojournalism (25)
  • Everyday (19)
  • Home (14)
  • Travel (14)
  • Sports photography (9)
Provided by OutdoorPros.com
Nikon SB-400 Speedlight Unit (4806) Nikon has a long history of development of a variety of products that allow for the simple enjoyment of high-quality imaging, beginning of course, with digital cameras. In recent years, the digital wave has led to great changes in the ways in which images, videos and music are enjoyed. Nikon SB-400 Speedlight Unit (4806) Features: • Compact, lightweight Speedlight unit perfect for anyone looking for more power and coverage than a built-in flash • Simple, intuitive operation. Put it on, turn it on and shoot! • 18mm angle of coverage with Nikon DX-format digital SLR cameras • Utilizes Nikon's i-TTL intelligent flash technology for great flash exposures • Operates on two AA-size (1.5V) batteries • Fast 2.5 second recycling time keeps you shooting quickly • Bounce capabilities in 4 steps-up to 90 degrees helps reduce background shadows and soften the light • Approximate guide number of 98.4 feet at ISO 200 (at 18mm zoom head setting). • Flash shooting distance range from 2 ft. up to 66 ft. • Compatible with all Nikon Creative Lighting System cameras Nikon SB-400 Speedlight Unit (4806) Specifications: • Guide Number: 30m/98.4ft. (ISO 200, m/ft at 18mm zoom-head position, 20 degrees C/68 degrees F) • Electronic Construction: Automatic Insulated Gate Bipolar Transistor (IGBT) and series circuitry • Flash Exposure Control: Flash exposure control set on the camera: Slow-sync, red-eye reduction, red-eye reduction in slow sync, rear-curtain sync flash, FV lock flash, manual flash (with Nikon Creative Lighting System digital and 35mm SLR cameras), i-TTL, M (manual with the D40 only) • Lens Coverage: Light distribution covers an 18mm lens when mounted on a Nikon DX-format digital SLR camera (27mm lens when mounted on a D3's FX-format or the F6 35mm SLR) • Minumum Recycling Time: 3.9 sec. with Alkaline batteries; 4.2 with Lithium batteries, 3.1 with Oxyride batteries; 2.5 with Ni-MH batteries • Flash Duration: Approx. 1/1, 300th second at full output. • Required Power Source: Two AA batteries (1.5V or lower); Alkaline-manganese, Lithium, Oxyride or Ni-MH rechargeable (2600mAh 1.2v) • Supplied Accessories: SS-400 Soft case • Weight: Approx. 4.5 oz. (without batteries) • Minimum Number of Flashes: Approx. 140 • Supplied Accessories: SS-400 Soft case
Specification Description
Model 4806, SB-400
UPC 018208048069
Compatible Battery (2) AA Batteries
Connection Type 1 x Hot Shoe
Dedication Nikon
Depth (Inches) 3.1
Guide Number ISO 100 51 - 100
Height (Inches) 2.2
Light Type Flash Light
Recycle Time (seconds) 2.5
Weight (Pounds) .28
Width (Inches) 2.6
Nikon SB-400 Speedlight Unit Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 16, 2009
Nikon SB-400 Speedlight Unit Reviews
Most helpful positive review
[11 of 11 customers found this review helpful]
Most helpful negative review
[3 of 5 customers found this review helpful]
5.0
Don't under estimate this flash.
"I had concerns that this flash would not have the power to do the job of lighting up a large dance floor in a NYC Club. I'm not sure how this would perform on a Nikon D2x, however, on a Nikon D40 it's a perfect match. Match this flash with the D40, a $75.00 Stroboframe camera flip bracket, a $50.00 Nikon flash cable (don't get the cable with the focus assist)and pick up a $17.00 Sto-Fen Omni Bounce designed fo..." Read Full Review »
Jan 27, 2008 by Mr. S. Randall Thomas
See more positive Nikon SB-400 Speedlight Unit reviews
3.0
Save up for the SB-600
"I got this flash in August and already want the next model and it is only December. Due to the fact that this flash can only bounce well when in the landscape position I have become really limited when shooting indoor. Much better than the built-in flash however...." Read Full Review »
Dec 11, 2007 by foltzy
See more negative Nikon SB-400 Speedlight Unit reviews
Displaying 1 - 5 of 283 Reviews
Show
Sort by
5.0
    Pros
  • Consistent Output
  • Easily Interchangeable
  • Easy To Clean
  • Fast Recycling
  • Lightweight
  • More »
    Cons
  • none
    Best Uses
  • Back-Up
  • Club Photography
  • General Use
  • Night Photography
  • Photojournalism
  • More »
Match this flash with the D40, a $75.00 Stroboframe camera flip bracket, a $50 …"  Read Full Review »
Club Mars 2112, New York City
  • Using Product
  • Made with Product
Was this Camera Flash review on the Nikon SB-400 Speedlight Unit helpful to you?
 Report Abuse  (11)  (0)  0 comments
Jan 27 2008
Brooklyn, New York
I am:
  • Professional
Reviewed at:
Price: $111.95
[18 of 18 customers found this review helpful]
Bounce Flash Eliminates Red Eye
5.0
    Pros
  • Durable
  • Good Value
  • High Quality
    Cons
  • None
    Best Uses
  • Indoor Photos
  • Parties
  • Portaits
"I've shot a couple of hundred indoor photographs with the SB 400 so far, and what impresses me most is the "bounce flash" feature. You can tilt the light portion of the flash head at a number of angles, including straight up, so that the flash does not wash out the scene or create red eye. Instead t …"  Read Full Review »
Puppies (no red eye)
  • Made with Product
Natural colors and light
  • Made with Product
 Report Abuse  (18)  (0)  0 comments
Jan 16 2007
Greg the Photobug
Milwaukee
[7 of 7 customers found this review helpful]
D40 owners, Buy it!
5.0
    Pros
  • Consistent Output
  • Durable
  • Fast Recycling
  • Lightweight
    Cons
  • None
    Best Uses
  • General Use
  • Portraits
  • Sports Photography
"This last weekend I took photos of the Sawtooth relay in Idaho. Since it was an all day event I knew I would be needing fill flash for my pictures. This little flash worked very well. I am shooting with a Nikon D40 which works perfectly with this flash.
The flash can keep up with the camera's c …"  Read Full Review »
first frame........
first frame........
and the next, with the flash
  • Made with Product
 Report Abuse  (7)  (0)  0 comments
Jun 15 2008
Tortuga
Bellevue, Idaho
I am:
  • Hobbyist/Enthusiast
Reviewed at:
Price: $111.95
[8 of 8 customers found this review helpful]
Small flash Big difference
4.0
    Pros
  • Consistent Output
  • Fast Recycling
  • Lightweight
    Cons
  • None
    Best Uses
  • General Use
  • Portraits
"I was not sure such a little item would make a difference, but the color and quality of the pictures is huge. I just shot some practice shots when I got it and bounced the light off the ceiling. It softened the picture and the color was right on. Because it is so light and little I will be packin …"  Read Full Review »
1.With camera flash
1.With camera flash
  • Picture of Product
SB 400 bounced off ceiling
 Report Abuse  (8)  (0)  0 comments
Sep 9 2008
Photomom
Homer Glen, IL
I am:
  • Casual user
[5 of 5 customers found this review helpful]
The speedlight is all you need
4.0
    Pros
  • Durable
  • Easy To Use
  • Lightweight
  • Reliable
    Cons
  • None
    Best Uses
  • Everyday use
  • Home
"I don't normally like to use flash but during the holidays it was a must. my photos were much more natural when I bouncened it off the ceiling with the speed light. It has taken over 300 photos on one set of batteries. I was impressed with thye simplicity and function. i know there is more expensive …"  Read Full Review »
Smokie the christms cat
  • Made with Product
 Report Abuse  (5)  (0)  0 comments
Jan 7 2009
Bill
Lex., Ky
I am:
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
