Nikon ML-L3 Remote Control Transmitter
#6
4.5
based on 475 reviews
Ratings Distribution
5 star
295
4 star
147
3 star
17
2 star
4
1 star
12
Category Average
4.2
$5.99 - $33.30
from 9 stores
Pros
  • Lightweight (248)
  • Easy to use (246)
  • Durable (182)
  • Easy setup (112)
  • Reliable (110)
  • Nice button configuration (84)
  • Ergonomic design (80)
  • Strong signal (71)
  • Improves function (66)
  • Nice features (39)
See less See more
Cons
  • Weak signal (12)
  • Not enough features (10)
  • Not functional (10)
  • Small (7)
  • Easy to lose (4)
  • Flimsy (4)
  • Not durable (4)
  • Buttons wear easily (3)
  • Difficult to use (3)
Best Uses
  • Portraits (124)
  • Macro (116)
  • Travel (103)
  • Everyday (95)
  • Landscapes (87)
  • Studio (84)
  • Home (74)
  • High-end equipment (32)
  • Upgrade (32)
  • Replacement (15)
Provided by B&H Photo Video
The Nikon MLL3 acts as a wireless shutter release capable of instantly triggering the shutter without disturbing the camera up to a distance of approximately 16' in front of the camera. Recommended for taking pictures of subjects that are difficult to approach or to minimize vibration for close-ups and time exposure. Powered by CR-2025 3v battery (included).
Specification Description
Model 4730, 4730-, 4730NCP, ML-L3
UPC 018208047307
Camera Type Camera
Select Remote Controls
To Fit Nikon AF
Nikon ML-L3 Remote Control Transmitter Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 13, 2009
Nikon ML-L3 Remote Control Transmitter Reviews
Most helpful positive review
Most helpful negative review
[2 of 2 customers found this review helpful]
5.0
Very Nice Accessory!
"This remote is an awesome accessory to have! You have to set up your camera to use it, so don't freak out if it doesn't work when you open the box and point it at your camera. You can change your camera to remote shutter, then it works great. It is great when you need a group shot. It can used on my D60 in instant release, 2 second delayed release, and can also be used in Bulb Shutter mode to take exposures up t..." Read Full Review »
Feb 22, 2009 by IsaacMTSU
See more positive Nikon ML-L3 Remote Control Transmitter reviews
3.0
Works fine, but....
"This remote works fine and the range seems pretty good. I have not had it long, so I cannot really speak to its durability or battery life.That being said, I was a bit disappointed when it arrived. First of all, it is tiny with no manufactured way to attach it to anything (like a lanyard or even a key ring). The tiny case it comes in has some slits, but they don’t look like they are good for much.Also, you ha..." Read Full Review »
May 04, 2008 by Nature Nut
See more negative Nikon ML-L3 Remote Control Transmitter reviews
Displaying 1 - 5 of 475 Reviews
Show
Sort by
5.0
    Pros
  • Durable
  • Lightweight
  • Quick Response
  • Reliable
    Cons
  • None
    Best Uses
  • Everyday use
  • long exposures
  • Macro Photography
  • Portraits
  • Reducing Camera Shake
"This remote is an awesome accessory to have! You have to set up your camera to use it, so don't freak out if it doesn't work when you open the box and point it at your camera. You can change your camera to remote shutter, then it works great. It is great when you need a group shot. It can used on my …"  Read Full Review »
HDR (9 shots) of the moon with the ML-L3 Remote
  • Made with Product
  • Using Product
Was this Camera Accessory review on the Nikon ML-L3 Remote Control Transmitter helpful to you?
Feb 22 2009
IsaacMTSU
Murfreesboro,TN
I am:
  • Hobbyist/Enthusiast
Reviewed at:
Price: $17.95
Even helps an amature
5.0
    Pros
  • Durable
  • Lightweight
  • Simple Controls
    Cons
  • None
    Best Uses
  • Home
  • Special Events
"Being a beginner sometimes I am not as steady as I should be, but the Nikon remote along with a good tripod takes my shaky hands out of the picture and allows me to concentrate on composition and the "art" of photography. "
Took this from my deerstand using the remote
 Report Abuse  (2)  (0)  0 comments
Feb 6 2007
sekoonce
Lake Charles, Louisiana
I am:
  • Casual user
  • Getting started
Reviewed at:
Price: $17.95
Easy to Lose!
5.0
    Pros
  • Easy to Use
    Cons
  • Easily Lost
    Best Uses
  • None
"This is a must have item for many of todays new cameras.
Do yourself a favor though...buy two!
It works great if you've got you're camera set up on a Grizzly and you've shot and shot at him feeding on berries and your waiting for him to raise his head and look knarly at you. Then you can be al …"  Read Full Review »
Dec 29 2008
Carson
Fremont, California
I am:
  • Casual Photographer
Reviewed at:
Price: $17.95
Life is easy now
4.0
    Pros
  • Easy to Use
  • Improves Function
  • Lightweight
    Cons
  • Small in my big Hands
    Best Uses
  • Macro Photography
  • Self Family Portraits
"Found the size a bit disturbing, way to small for my big hands. I might get another one just in case I misplace this one. I like to be able to take pictures of me and my family together. Great for low speed shots and macro. Put the camera on the tripod and take great stills of every thing with no sh …"  Read Full Review »
Nikon D40 48mm ISO 400 1/60 Sec Exposure
  • Made with Product
  • Using Product
Jan 21 2008
Darth50
Bakersfield, California
I am:
Reviewed at:
Price: $17.95
Very Useful
4.0
    Pros
  • Durable
  • Easy To Use
  • Lightweight
  • Reliable
    Cons
  • None
    Best Uses
  • Everyday use
  • Landscape Photography
  • Portraits
"Very easy to use and a great help in certain situations.Can be a little annoying if using far away,sometimes have to press it twice for the sensor to pick up the signal.But at close range...shoot away !!! "
  • Made with Product
  • Using Product
Aug 24 2009
BIRD
Calhoun,GA
I am:
Reviewed at:
Price: $17.95
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
