Close Login Module
Join
Nikon ML-3 Compact Modulite Remote Control Set
#272
4.4
based on 32 reviews
Ratings Distribution
5 star
17
4 star
12
3 star
1
2 star
2
1 star
0
Category Average
4.2
$169.95 - $199.99
from 3 stores
More Images
Pros
  • Durable (17)
  • Lightweight (13)
  • Easy setup (11)
  • Easy to use (11)
  • Reliable (8)
  • Nice button configuration (7)
  • Nice features (7)
  • Strong signal (5)
  • Ergonomic design (4)
  • Improves function (4)
See less See more
Cons
  • Weak signal (3)
  • Pricey (2)
  • Battery door problems (1)
  • Bracket-bo-many months (1)
  • Bulky (1)
  • Can't think of one (1)
  • Hard to find (1)
  • Have to be very accurate (1)
  • Needs better design (1)
Best Uses
  • Macro (10)
  • Travel (8)
  • Everyday (7)
  • High-end equipment (7)
  • Landscapes (6)
  • Studio (5)
  • Portraits (4)
  • Home (3)
  • Professional work (3)
  • Special events (3)
Where to Buy
BizRate Rating Outstanding 9.1
$169.95
BizRate Rating Outstanding 9.6
$189.95
No Tax Outside NY
$199.99
Product Reviews
Last update: Sep 29, 2009
Nikon ML-3 Compact Modulite Remote Control Set Reviews
Most helpful positive review
Most helpful negative review
[4 of 5 customers found this review helpful]
4.0
Neat gadget with helpful capabilities.
"This accessory is great for family or self pics and covert capture of wildlife. I have gotten 50-60 foot range with it, well over the spec of 30 feet. On the minus side, the remote's battery door tends to slip off. Also, remember to turn off the remote when finished or it will be dead the next time you need it...." Read Full Review »
Feb 05, 2007 by epainter
See more positive Nikon ML-3 Compact Modulite Remote Control Set reviews
2.0
Gets the job done
"I found some difficulty with the product as far as mounting it was concerned. The reciever part of the remote is supposed to be mounted on the hot shoe mount of the camera and does so just fine. But I found myself scratching my head wondering where I would mount the reciever when I wanted to use the popup flash or a hot shoe mounted flash. I did however manage to rig up the reciever to work in conjunction with t..." Read Full Review »
Jan 21, 2008 by P.H
See more negative Nikon ML-3 Compact Modulite Remote Control Set reviews
Displaying 1 - 5 of 32 Reviews
Show
Sort by
4.0
    Pros
  • Great Features
  • Lightweight
  • Range exceeds specs
  • Simple Controls
  • Versatile
    Cons
    Best Uses
  • Home
  • Office
  • Professional Work
  • Special Events
  • Travel
  • More »
"This accessory is great for family or self pics and covert capture of wildlife. I have gotten 50-60 foot range with it, well over the spec of 30 feet. On the minus side, the remote's battery door tends to slip off. Also, remember to turn off the remote when finished or it will be dead the next time …"  Read Full Review »
Brown wren taken with D100 & 28-300 Tamron zoom.
  • Using Product
Feb 5 2007
epainter
Fort Wayne, IN
I am:
  • Hobbyist/Enthusiast
  • Professional
Reviewed at:
Price: $169.95
[8 of 8 customers found this review helpful]
Now be in the shot, not behind it...
5.0
    Pros
  • Nice Button Configuration
  • Nice Features
    Cons
  • Should be built-in
  • Uses hot shoe
    Best Uses
  • High-End Equipment
"This has several modes, including single, continuous, delayed single (timer) and motion activated.
The delayed mode is great for taking self or group photos, but unlike the self portrait there’s no racing to get into position. One can activate the remote then hide it and the photo is taken about 3 …"  Read Full Review »
Dec 9 2008
puddin'head
Las Vegas
I am:
  • Tech Savvy
Reviewed at:
Price: $189.95
[11 of 12 customers found this review helpful]
Took a little fiddling but works great
4.0
    Pros
  • Durable
    Cons
  • None
    Best Uses
"I had to fiddle with the setup between the buttons and my camera configuration before I understood how to make use of all the functions. You need to be in C or M on your camera body for the camera to fire consistently. However, for my purposes, it works fantastically. I have been using it at ranges …"  Read Full Review »
Apr 17 2008
Noonan
Los Angeles
I am:
  • Gearhead
Reviewed at:
Price: $189.95
Just Works. Period. (D200)
5.0
    Pros
  • Durable
  • Easy to Use
  • Improves Function
  • Lightweight
    Cons
  • None
    Best Uses
  • Everyday Use
  • Macro Photography
  • Traveling
"This remote is perfect--it does exactly what is advertised to do, albeit with slightly better range in the field.
A trick.... When I'm using my flash, I put some double stick tape on the side and glue the receiver to the flash. That holds it on. "
Jan 22 2008
SolPo
Edina, MN
I am:
Reviewed at:
Price: $169.95
Gets the job done
2.0
    Pros
  • Easy to Use
  • Improves Function
  • Lightweight
    Cons
    Best Uses
  • Everyday Use
  • Macro Photography
"I found some difficulty with the product as far as mounting it was concerned. The reciever part of the remote is supposed to be mounted on the hot shoe mount of the camera and does so just fine. But I found myself scratching my head wondering where I would mount the reciever when I wanted to use the …"  Read Full Review »
Jan 21 2008
P.H
Allenton, WI
I am:
Reviewed at:
Price: $169.95
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
$169.95
$189.95
No Tax Outside NY
$199.99
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
