Nikon MB-D10 Multi Power Battery Pack
#2
4.6
based on 377 reviews
Ratings Distribution
5 star
260
4 star
91
3 star
14
2 star
10
1 star
2
Category Average
4.3
$3.99 - $299.99
from 12 stores
More Images
Pros
  • Easy to install (277)
  • Reliable (243)
  • Long-lasting (159)
  • Fast recharge (90)
  • Solid construction (81)
  • Widely compatible (48)
  • Versatile (21)
  • Good value (19)
  • Lightweight (17)
  • Charges quickly (12)
See less See more
Cons
  • Bulky (9)
  • Pricey (9)
  • Heavy (4)
  • Poor design (4)
  • Doesn't fit camera well (2)
  • Loses charge quickly (2)
  • Weight (2)
  • 4 way switch (1)
  • A little expensive (1)
Best Uses
  • Digital photography (230)
  • Photography (141)
  • Travel (97)
  • Power equipment (61)
  • Mobility (58)
  • Portraits (57)
  • Back-up (31)
  • Professional cameras (26)
  • Upgrade (12)
  • Sports photography (8)
Provided by B&H Photo Video
The Nikon MB-D10 Multi-Power Battery Grip allows the Nikon D300 & D700 to powered by two EN-EL3e batteries simultaneously - one in the camera body and one in the MB-D10 - effectively doubling your shooting capacity. The MB-D10 also provides a comfortable vertical grip with an additional shutter release and scroll wheel for easy access to the camera functions when shooting in the vertical orientation. It is also fairly compact with dimensions of 5.9 x 2.9 x 1.7 (15 x 75 x 45mm).With the included MS-D10 AA battery holder users can power the camera with 8 AA batteries.  Or you can use the Nikon EN-EL4 or EN-EL4A battery (sold separately) combined with the optional BL-3 Battery Chamber Cover to obtain a higher frame advance rate (8 Frames per second in the D300) than the EN-EL3e battery can provide.
Specification Description
Model 25359, MBD10
UPC 018208253593
Compatible With Nikon
Select Power Accessories
Nikon MB-D10 Multi Power Battery Pack Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 17, 2009
Nikon MB-D10 Multi Power Battery Pack Reviews
Most helpful positive review
Most helpful negative review
4.0
Lives long ... and prospers
"Shot about 800 frames on two-week trip so far with AA lithiums (Energizer). Haven't charged EL3e yet, but it still shows 93% -- occasionally even going up to 96%. Heavy to haul around but actually makes the D300 handle better for more stable shots, much like the motor-equipped Fs I used in the film days. Haven't used the vertical release much thus far, but found using consecutive-low setting minimizes sensiti..." Read Full Review »
Jan 19, 2009 by lgraffx
See more positive Nikon MB-D10 Multi Power Battery Pack reviews
2.0
2 stars ... and a step back.
"For two reasons we need it (the name self-explain!) right? (A) Who shots basically portraits is a must have to help the vertical position of the camera and (B) to carry more power. Are you all sure? For the D200, NIKON made a 10-STARS product. Reach the two goals. Is a wonderful product ... even the plastic little things sometimes break, but, two batteries on the chamber? Wow! You can forget the time left to..." Read Full Review »
Jun 04, 2008 by Carlos Bruno
See more negative Nikon MB-D10 Multi Power Battery Pack reviews
Displaying 1 - 5 of 377 Reviews
Show
Sort by
4.0
    Pros
  • Easy to Install
  • Long-Lasting
    Cons
  • Heavy to haul around
    Best Uses
  • Digital Photography
  • Photography
  • Power Equipment
  • Travel
Heavy to haul around but actually makes the D300 handle better for more stable shots, much like the motor-equipped Fs I used in the f …"  Read Full Review »
Hawaiian sunset
Hawaiian sunset
  • Using Product
  • Made with Product
Surf's up!
Surf's up!
  • Using Product
  • Made with Product
Was this Standard Camera Battery review on the Nikon MB-D10 Multi Power Battery Pack helpful to you?
Jan 19 2009
lgraffx
Chicago 'burbs
I am:
  • Semi-pro Photographer
Reviewed at:
Price: $254.95
[9 of 9 customers found this review helpful]
Works without Batteries!!! No kidding!!
5.0
    Pros
  • Easy to Install
  • Long-Lasting
  • Reliable
    Cons
  • None
    Best Uses
"Just wanted to comment on something I have not seen much written on. This product is a very well made grip, shutter release and control. MUCH better built than the D200 grip, no wobbling or flimsiness. It really completes the camera and for that reason alone I would buy it.
Due to the really exce …"  Read Full Review »
 Report Abuse  (9)  (0)  0 comments
Aug 19 2008
K. J. Doyle
Andover, MA
I am:
  • Professional
Reviewed at:
Price: $259.95
[7 of 7 customers found this review helpful]
accessory that you should have
5.0
    Pros
  • Easy to Install
  • Long-Lasting
  • Reliable
    Cons
  • None
    Best Uses
  • Mobility
  • Photography
  • Power Equipment
  • Travel
"Nikon MB-D10 comes with:
1. MB-D10 Multi-Power Battery Grip
2. Battery Holder for AAs Batteries
3. Battery Holder for EN-EL3e
(Make sure that you don't buy any extra of them)
The camera will use the power source either from MB-D10 or from the camera (EN-EL3e) first - depends on your setting …"  Read Full Review »
 Report Abuse  (7)  (0)  0 comments
Aug 7 2008
Tommi Piano
Chicago
I am:
  • Professional
Reviewed at:
Price: $259.95
[4 of 4 customers found this review helpful]
MB-D10 Multi-Power Battery Pack for D300
4.0
    Pros
  • Easy to Install
  • Good ergonomics
  • Good Versatility
    Cons
  • No BL-3 Battery Cover
    Best Uses
  • Mobility
  • Travel
"Very good back up power source for travel to go along with my D-300. Includes a storage provision for the camera’s terminal cap however it does not include the same for the MB-D10’s terminal cap. The biggest con would be that it DOES NOT include the BL-3 battery chamber cover for use with the EN-EL4 …"  Read Full Review »
 Report Abuse  (4)  (0)  0 comments
Jun 27 2008
Mike
LSA Anaconda, Balad, Iraq
I am:
  • Hobbyist/Enthusiast
Reviewed at:
[2 of 2 customers found this review helpful]
A Must Have D300 Option
5.0
    Pros
  • Better balance
  • Easy to Install
  • Imcreased fps rate
  • More professional look
  • More robust feel
    Cons
  • Moderately expensive
    Best Uses
"You'll immediately understand all the rave reviews from the moment that you first pick up your D300 with the attached MB-D10...the D300 feels so much more robust and better balanced as if the battery attachment was meant to be there in the first place...the MB-D10 is extremely well made of the same …"  Read Full Review »
 Report Abuse  (2)  (0)  0 comments
Jan 9 2009
divots
Noank, CT
I am:
  • Photo Enthusiast
Reviewed at:
Price: $254.95
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
