Nikon Leather Carrying Case for the Coolpix S Series!
4.3
based on 56 reviews
Ratings Distribution
5 star
35
4 star
10
3 star
6
2 star
2
1 star
2
Category Average
4.3
$17.08 - $29.99
from 9 stores
More Images
Pros
  • Lightweight (41)
  • Good protection (18)
  • Easily accessible equipment (16)
  • Compact (15)
  • Well padded (14)
  • Well built / quality construction (11)
  • Durable (9)
  • Comfortable (6)
  • Comfortable strap (3)
  • Stylish (2)
See less See more
Cons
  • Not enough pocket room (5)
  • Doesn't cushion camera well (2)
  • No strap (2)
  • Small (2)
  • Uncomfortable strap (2)
  • Camera comes w case (1)
  • Controls not protected (1)
  • Great (1)
  • Inadequate protection (1)
  • No extra pockets (1)
Best Uses
  • Daily transport (15)
  • Travel (14)
  • Protecting gear (11)
  • Storage (11)
  • Transporting gear (10)
  • Storing gear (7)
  • Protecting slrs (3)
  • Compact digital cameras (1)
  • Fishing trips (1)
  • For nikon coolpix s210 (1)
Provided by Beach Audio
  • Compatible with COOLPIX S Series Digital Cameras
  • Genuine deluxe leather case in Black with belt loop
  • For Coolpix S200, S50, S50C and other similar size Digital Cameras
  • 0.25 Weight
  • Specification Description
    Model 5811, 5811-, 9635
    UPC 018208058112
    Designed For Digital Point & Shoot Cameras
    Select Manufacturer Dedicated Cases
    Nikon Leather Carrying Case for the Coolpix S Series! Questions
    Questions and Answers
    Where to Buy
    $17.61
    No Tax Outside NY ends 09/09/15
    BizRate Rating Outstanding 9.7
    $17.08
    BizRate Rating Outstanding 9.4
    $17.49
    BizRate Rating Outstanding 9.1
    Show all 9 stores
    Product Reviews
    Last update: Nov 2, 2009
    Nikon Leather Carrying Case for the Coolpix S Series! Reviews
    Most helpful positive review
    Most helpful negative review
    5.0
    A GREAT LEATHER CASE!
    "I was skepticle about ordering this case for my S710 COOLPIX because it said "large" case. Thankfully it is not a large case and the camera fits perfectly. The case has a wide belt loop and fits next to my cell phone just fine. This is a great case and ordering from JR couldn't be any easier!..." Read Full Review »
    Jul 31, 2009 by johnnieblaze
    See more positive Nikon Leather Carrying Case for the Coolpix S Series! reviews
    3.0
    Basic Protection without any frills
    "I got this because it was the only one listed but I really don't like it. No zipper (so things don't fall out), no strap so your hands are free - I don't always have a belt on for the belt loop, and no place to put extra memory cards or charged batteries. I'm going to go get a Targus case instead. Until then, I will use this. It's OK for when I know I won't need a memory card or extra battery...." Read Full Review »
    Jul 08, 2009 by yolsgaard
    See more negative Nikon Leather Carrying Case for the Coolpix S Series! reviews
    Displaying 1 - 5 of 56 Reviews
    Show
    Sort by
    5.0
      Pros
    • Compact
    • Durable
    • Lightweight
    • Positive magnetic closure
    • Wide belt loop
      Cons
    • Inadequate Protection
      Best Uses
    • Daily Transport
    • Fishing trips
    • Storage
    • Travel
    "I was skepticle about ordering this case for my S710 COOLPIX because it said "large" case. Thankfully it is not a large case and the camera fits perfectly. The case has a wide belt loop and fits next to my cell phone just fine. This is a great case and ordering from JR couldn't be any easier! "
    S710 Coolpix image
    S710 Coolpix image
    • Using Product
    Was this Camera Bag & Case review on the Nikon Leather Carrying Case for the Coolpix S Series! helpful to you?
    Jul 31 2009
    johnnieblaze
    Oxford, CT
    I am:
    • Photo Enthusiast
    Reviewed at:
    Price: $19.49
    3.0
      Pros
    • Compact
    • Durable
    • Good Protection
    • Lightweight
      Cons
    • No strap
    • No zipper
    • Not Enough Pocket Room
      Best Uses
    • Daily Transport
    • Storage
    • Travel
    "I got this because it was the only one listed but I really don't like it. No zipper (so things don't fall out), no strap so your hands are free - I don't always have a belt on for the belt loop, and no place to put extra memory cards or charged batteries. I'm going to go get a Targus case instead. …"  Read Full Review »
    Jul 8 2009
    yolsgaard
    Oakland, CA
    I am:
    • Photo Enthusiast
    Reviewed at:
    Price: $17.49
    Too small for S630
    1.0
      Pros
    • Compact
      Cons
    • Too Small
      Best Uses
    • Daily Transport
    • Storage
    • Travel
    "Got this with the Adorama package including S630 and memory card. This case is waaaay too small for this camera. You have to really jam the camera into the case. You cannot get the camera far enough into the case to close the flap. To remove it you have to squeeze the bottom like a tube of tooth …"  Read Full Review »
    May 4 2009
    School Photo
    Atlanta, GA
    I am:
    • Pro Photographer
    Reviewed at:
    Price: $17.49
    Simple and classy.
    5.0
      Pros
    • Comfortable
    • Easily Accessible Equipment
    • Lightweight
    • Strong Construction
    • Well Padded
      Cons
    • None
      Best Uses
    • Protecting Gear
    • Storing Gear
    • Transporting Gear
    "Daughter says the case is a bit snug for the S52c, but no problems with camera due to the fit. In fact, she rather prefers a little tighter fit so the camera is less likely to slip out of the case and rattle around with other items in her purse. She likes the classic, simple lines of the case and t …"  Read Full Review »
    Sep 22 2008
    MDB
    lbuquerque, NM
    I am:
    • Photo Enthusiast
    Reviewed at:
    Price: $17.61
    FIVE STARS!
    5.0
      Pros
    • Compact
    • Durable
    • Good Protection
    • Lightweight
      Cons
    • No strap
      Best Uses
    • Daily Transport
    • Storage
    • Travel
    "THIS IS A PERFECT CASE! I LOVE THE MAGNETIC CLOSURE. IT NEVER POPS OPEN IN MY PURSE. THE LEATHER IS OF GREAT QUALITY AND REALLY PROTECTS MY CAMERA. IT DOES NOT HAVE A CARRYING STRAP BUT IT HAS A BELT LOOP STRAP. THIS IS THE BEST CASE I HAVE EVER PURCHASED! "
    Aug 19 2009
    spshel1
    Davenport, Iowa
    I am:
    • Photo Enthusiast
    Reviewed at:
    Price: $17.49
    pages: 1 2 3 4 5 Next »
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
