Close Login Module
Join
Nikon D700 Digital SLR Digital Camera (Body Only)
#1
4.9
based on 563 reviews
Ratings Distribution
5 star
496
4 star
61
3 star
7
2 star
0
1 star
0
Category Average
4.6
$2,499.99 - $2,999.95
from 14 stores
More Images
Pros
  • Quality construction (466)
  • Bright lcd (444)
  • Comfortable controls (439)
  • Great picture quality (358)
  • Easy to use (296)
  • Fast shutter speed (286)
  • Short lag time (105)
  • Image stabilization (71)
  • Quiet (66)
  • Great in low light (41)
See less See more
Cons
  • Heavy (86)
  • Noisy (44)
  • Pricey (13)
  • Exposed lcd (5)
  • Poor in low light (4)
  • Complicated controls (2)
  • Loud shutter (2)
  • Memory card door (2)
  • Poor battery life (2)
Best Uses
  • Travel (354)
  • Portraits (346)
  • Photojournalism (287)
  • Art (273)
  • Fun (268)
  • Landscapes (251)
  • Sports (223)
  • Documentary (77)
  • Outdoors (26)
  • Sports/action (24)
Where to Buy
$2,499.99
BizRate Rating Outstanding 9.1
$2,696.95
$2,696.95
Show all 14 stores
Product Reviews
Last update: Nov 2, 2009
Nikon D700 Digital SLR Digital Camera (Body Only) Reviews
Most helpful positive review
[14 of 14 customers found this review helpful]
Most helpful negative review
5.0
Adorama customer for life!!!
"i recieved my d700 from adorama nearly a week ago, and fell in love with it instantly. the shutter took a little while to get used to, but i dont even notice it now. i shot about 400+ pictures with it, no problems. it is truly amazing the amount of detail that you get in the shadows, and i havent had to run any noise reduction when i am processing, even at iso 800!!! I then wanted to try it out with my mb-d10 ba..." Read Full Review »
Oct 06, 2008 by lyle dickie
See more positive Nikon D700 Digital SLR Digital Camera (Body Only) reviews
3.0
A little disapointed
"Hi,I am a little disapointed with the D700, the overal picture quality is very good but all the controls are very hard to operate (specialy the on-off-light switch and the MF/S/C focus switch).It's not acceptable on a [$] camera.Also, Nikon should provide a software able to open, adjust and print RAW files.The FX format is great and the internal flash cover my 20mm, Amazing !The viewfinder is large and bright.Ve..." Read Full Review »
Oct 26, 2009 by Alex
See more negative Nikon D700 Digital SLR Digital Camera (Body Only) reviews
Displaying 1 - 5 of 563 Reviews
Show
Sort by
5.0
    Pros
  • Excellent in Low Light
  • Good Battery Life
  • Good sized screen
  • Great customer service
  • Great Resolution
  • More »
    Cons
  • None
    Best Uses
  • Outdoors
  • Portraits
  • Sports/Action
  • Travel
  • Weddings/Events
"i recieved my d700 from adorama nearly a week ago, and fell in love with it instantly. the shutter took a little while to get used to, but i dont even notice it now. i shot about 400+ pictures with it, no problems. it is truly amazing the amount of detail that you get in the shadows, and i havent ha …"  Read Full Review »
iso 400, f6.3, 1/400 sec
  • Made with Product
  • Using Product
Oct 6 2008
lyle dickie
riyadh, saudi arabia
I am:
  • Semi-Pro Photographer
Reviewed at:
Price: $2,696.95
[5 of 6 customers found this review helpful]
FX - Breaking the Digital Tunnel Vision
4.0
    Pros
  • Fast Shutter Speed
  • Full Frame Digital
  • Good sized screen
  • Great Resolution
  • More »
    Cons
  • Bad Battery Life
  • Heavy
    Best Uses
  • Outdoors
  • Portraits
  • Sports/Action
"I finally took the digital plunge when Nikon brought out this full frame digital SLR and I am glad I waited for full frame. I was able to take all my "old" pre-DX lenses and mount them on the D700 and not even feel like I left the full view of my "wet film" camera. With it I gained all the advanta …"  Read Full Review »
The boys playing
The boys playing
  • Made with Product
Color and Detail Spot On
  • Made with Product
Aug 11 2008
Tom Thumb
San Antonio, TX
I am:
  • Hobbyist/Enthusiast
[10 of 10 customers found this review helpful]
Nikon has outdone themselves this time
5.0
    Pros
  • Bright LCD
  • Comfortable Controls
  • Quiet
  • Small Lag Time
  • Strong Construction
    Cons
  • None
    Best Uses
  • Documentary
  • Fun
  • Photojournalism
  • Travel
"I bought this camera for personal use. The thing that impressed me most is that Nikon added an auto setting to their active d-Lighting feature. I had owned the D300 and thought it was great, but the D700 really surpasses the D300 performance. I am not sure what changes Nikon made in their exposure m …"  Read Full Review »
Ladybug tests lens macro focusing
  • Made with Product
Local art gallery - straight from the camera
  • Made with Product
Aug 25 2008
Pete
Fernandina Beach, Florida
I am:
[4 of 4 customers found this review helpful]
Superb image quality!
4.0
    Pros
  • Bright LCD
  • Easy To Use
  • Great Image Quality
    Cons
  • Loud
    Best Uses
  • Art
  • Fun
  • Portraits
  • Travel
"I've taken to using this camera more and more over the D300, even though I miss the lesser cameras 1.5 crop. Image quality from the D700 is better in most every way - especially at high ISO. This is saying a lot since the D300 is pretty darned good. Perfectly exposed, low ISO, sharp images from t …"  Read Full Review »
D700 Capture
D700 Capture
  • Made with Product
Feb 22 2009
weldonphoto
San Diego, CA
I am:
  • Semi-pro Photographer
[7 of 7 customers found this review helpful]
My D700 is magic!!!
5.0
    Pros
  • Bright LCD
  • Quiet
  • Small Lag Time
    Cons
  • None
    Best Uses
  • Art
  • Documentary
  • Fun
  • Photojournalism
  • Travel
"I had a canon 300d, 350D, 5D and I switched to Nikon because of the lens quality and sharpness.
I have now: a D70, a D80, a D300, but the D700 is the most accomplished camera I have ever owned.
There is a huge difference with the D300. It is way more responsive, the focusing is now perfect, the co …"  Read Full Review »
At home, indoor, no effects, just croped...
  • Using Product
Sep 22 2008
Dominique
Phoenix, AZ
I am:
  • Semi-Professional
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
$2,499.99
$2,696.95
$2,696.95
$2,696.95
$2,696.95
$2,699.00
BizRate Rating Outstanding 9.6
$2,699.95
No Tax Outside NY
$2,699.95
$2,699.99
$1.99 Shipping on Orders Over $75
$2,699.99
$1.99 Shipping On Orders Over $100 at TigerDirect
$2,999.95
$2,999.95
$2,999.95
$2,999.95
Out Of Stock
BizRate Rating Outstanding 9.0
$2,276.65
BizRate Rating Outstanding 9.4
$2,699.99
Shop CameraWorld with FREE Shipping/No Sales Tax!
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
