#288
based on 78 reviews
Ratings Distribution
| 5 star |
46 |
| 4 star |
37 |
| 3 star |
18 |
| 2 star |
14 |
| 1 star |
26 |
Category Average
$22.00 - $59.99
from 14 storesPros
Cons
Best Uses
Where to Buy
BizRate Rating
Good 8.9
BizRate Rating
Good 8.9
BizRate Rating
Good 8.8
Product Reviews
[2 of 2 customers found this review helpful]
[3 of 3 customers found this review helpful]
"I was using a Belkin adapter and it was frustrating to say the least! I was constantly dropping the connection even though I was only 10 feet away from my access point. Had to continually re-connect. I had to have better connectivity to connect to work from home (VPN), etc. so went out and bought this. I know NETGEAR is great equipment since I use a NETGEAR PCMCIA wireless adapter on my laptop when home and it w..." Read Full Review »
Sep 26, 2008 by Mark D
See more positive Netgear WG311 PCI Wireless Network Adapter reviews
"If you have Windows Vista, DO NOT buy this product! I'm sure some people will have some luck with it, but I wouldn't take the chance. I spent hours on the phone with technical support, but they couldn't help. They made me unplug the adapter and plug it back in three times. It took me all night. Then they told me to go to Netgear.com to download the latest Vista Drivers. ...How can I go to Netgear.com if I have ..." Read Full Review »
Feb 18, 2008 by CMartucci
See more negative Netgear WG311 PCI Wireless Network Adapter reviews
Displaying 1 - 5 of 78 Reviews
Netgear WG311 PCI Wireless Network Adapter Review
Pros
Cons
Best Uses
"Netgear Wireless WG311v3 PCI wireless adapter does not install properly under (32bit) Windows Vista even though Netgear claims it is compatible and supplies drivers. WG311 driver fails with the error "code 10" - device could not be started. This appears to be a very common problem.
Note that this
Read Full Review »
"Cards software works great on Vista systems.
Tip learned after messing with it for 1 hour.
After downloading the drive software .exe from the Netgear site.
After install if you can not get the system to connect to your router using Netgear software do the next step.
1.) Go to uninstall and unins
Read Full Review »
"I went in the store at my local Best Buy for linksys WMP54G but I asked a geek squad person who I know is good from personal experience and he recommend me this one and its also is what they all recommend labeled as "Best Buy." It's just like as I was told very easy and quick install. Took me no mor …" Read Full Review »
"Well, if you have a 64 bit system, specifically Vista or Windows 7 RC (Apparently in earlier versions of 7, the windows update driver works, but they changed something to mess it up, fun!), good luck getting this thing to work, you'll either get a code 10, or the drivers you find won't be digitally …" Read Full Review »
[1 of 1 customers found this review helpful]
Pros
Cons
Best Uses
"installation seems ok but continually wants to connect to lower signals. My signal was 89% and it would continually connect and disconnect every 2 seconds and start scanning. I replaced with a [$] card from another manufacturer and it connected right away. After spending endless hours troubleshooti …" Read Full Review »
Email Address: (required)
Comments:
or Cancel
Where to Buy
BizRate Rating
Good 8.9
BizRate Rating
Good 8.9
BizRate Rating
Good 8.8
BizRate Rating
Good 8.5
BizRate Rating
Outstanding 9.0
BizRate Rating
Good 8.7
BizRate Rating
Good 8.1
| Free Shipping on Orders Over $299 ends 07/03/14 | ||||
| $10 Off Orders Of Orders Over $85 + Free Shipping |
BizRate Rating
Good 8.7
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.comPrices, inventory, and product information are provided by the merchants and may include any promotional discounts that are not available to all customers. We assume no responsibility for accuracy of price information provided by merchants, but please price_alerts|snabela|powerreviews.com to any pricing discrepancies so we can notify the merchant. Additionally, sales taxes and shipping costs are not included in listed prices, so please check with the merchant for total costs.
Powered by PowerReviews, Inc. ©2009 All Rights Reserved
