Netgear RangeMax™ WPN824 Wireless Router
#8
4.0
based on 358 reviews
Ratings Distribution
5 star
269
4 star
97
3 star
26
2 star
27
1 star
58
Category Average
3.8
$19.99 - $69.63
from 16 stores
More Images
Pros
  • Easy setup (98)
  • Fast (92)
  • Reliable connection (41)
  • Fast connection speed (40)
  • Highly compatible (40)
  • Secure (39)
  • Secure connection (38)
  • Small (26)
  • Easy to use (19)
  • Reliable (18)
See less See more
Cons
  • Difficult to set up (11)
  • Unreliable (10)
  • Unreliable connection (8)
  • Slow (3)
  • Slow connection speed (3)
  • Not secure (2)
  • Better documentation (1)
  • Bright (1)
  • Bulky (1)
Best Uses
  • Home (57)
  • Home network (50)
  • Small office (22)
  • Small networks (14)
  • Secure networks (7)
  • Home or business (2)
  • Also the wireless laptop (1)
  • Also x-box live (1)
  • Connect two computers (1)
  • Do not use (1)
Provided by NothingButSoftware
General Information
As a 21st-century consumer, computers are an integral part of your life. But does your home computing environment work for you? Even if you already have a wireless network, you've probably found "dead spots" in your home where your Internet connection fades in and out, or drops off completely.
Now, say good-bye to those dead spots ... and say hello to the freedom to work (and play) absolutely anywhere in your home!
With the RangeMax Wireless Router, your whole house becomes a "hot spot". NETGEAR's exclusive RangeMax technology gives you the longest range of any wireless device on the market today - up to 10 times the wireless coverage of 802.11g. So you'll have a sizzling-fast, consistent connection in every room of your house ... and beyond.
Wireless Specifications
Wireless Technology:IEEE 802.11b/g
Antenna:7 x Internal
Frequency Band/Bandwidth:2.4 GHz IEEE 802.11b/g
Transmission Speed:108Mbps
Transmission Speed Details:54Mbps Auto-fallback IEEE 802.11g
Transmission Speed Details:108Mbps 2x Mode
Transmission Speed Details:48Mbps Auto-fallback IEEE 802.11g
Transmission Speed Details:36Mbps Auto-fallback IEEE 802.11g
Transmission Speed Details:24Mbps Auto-fallback IEEE 802.11g
Transmission Speed Details:18Mbps Auto-fallback IEEE 802.11g
Transmission Speed Details:12Mbps Auto-fallback IEEE 802.11g
Transmission Speed Details:9Mbps Auto-fallback IEEE 802.11g
Transmission Speed Details:6Mbps IEEE 802.11g
Transmission Speed Details:11Mbps Auto-fallback IEEE 802.11b
Transmission Speed Details:5.5Mbps Auto-fallback IEEE 802.11b
Transmission Speed Details:2Mbps Auto-fallback IEEE 802.11b
Transmission Speed Details:1Mbps IEEE 802.11b
Wireless Security:
Double Firewall:
  • Network Address Translation (NAT) to hide PCs & files from outside users
  • Stateful Packet Inspection (SPI) firewall to deny outside requests for personal information
  • Denial of Service (DoS) attack prevention
  • Intrusion Detection and Prevention (IDS)
  • Wired Equivalent Privacy (WEP) 64-bit,128-bit encryption
  • Wi-Fi Protected Access (WPA, Pre-Shared Key)
  • Wireless Access Control (SSID) to identify authorized wireless network devices
  • Two VPN end-to-end tunnels (IPSec) supported
  • Exposed Host (DMZ) for secure gaming
  • MAC address authentication
  • Privacy & Parental Control:
  • "Trusted user" controls
  • Time-based usage controls
  • Web site logging
  • URL content filtering
  • Interfaces/Ports
    Interfaces/Ports:4 x RJ-45 Auto-sensing LAN
    Interfaces/Ports:1 x RJ-45 Auto-sensing WAN
    Media & Performance
    Connectivity Media:10/100Base-TX Twisted Pair
    Data Transfer Rate:10Mbps Ethernet
    Data Transfer Rate:100Mbps Fast Ethernet
    Management & Protocols
    Management:
  • SmartWizard simplifies setup by automatically detecting and configuring your router for virtually all ISP connections
  • Remote management
  • Protocols:TCP/IP
    Protocols:IPSec
    Power Description
    Input Voltage:12 V Power Adapter
    Input Current:1 A
    Physical Characteristics
    Dimensions:8.8" x 6" x 1.2"
    Weight:1.2 lb
    Miscellaneous
    Package Contents:
  • RangeMax WPN824 Wireless Router
  • 12V, 1.0 A power adapter, localized to country of sale
  • Ethernet cable
  • Vertical stand
  • Setup Guide
  • Resource CD
  • Warranty/Support information card
  • Additional Information:
  • RangeMax is an advanced Smart MIMO (Multi-In, Multi-Out) technology
  • When used with RangeMax client adapters, delivers the longest range of any wireless technology on the market up to 500,000 square feet of uninterrupted coverage
  • System Requirements:
  • Broadband (cable, DSL) Internet service and modem with Ethernet connection
  • 2.4 GHz 802.11 b/g wireless adapter
  • Alternatively, an Ethernet adapter and cable for each computer
  • Windows 98, Me, NT, 2000, XP; Mac OS; NetWare; UNIX or Linux
  • Internet Explorer 5.0 or Netscape 4.7 or higher
  • Compatibility:
    RangeMax Wireless Adapters:
  • WPN111
  • WPN311
  • WPN511
  • Certifications & Standards:
  • FCC
  • IEEE:
  • IEEE 802.3: 10BASE-T
  • IEEE 802.3u: 100BASE-TX
  • IEEE 802.11b
  • IEEE 802.11g
  • Warranty
    Standard Warranty:1 Year
    Specification Description
    Model 1042975, WPN824, WPN824NA
    UPC 606449039641
    Interface 4 x RJ-45 10/100Base-TX Auto-sensing LAN
    Network Type Wireless 802.11b / 802.11g
    Select Routers
    Transmission Speed 108Mbps
    Wireless Technology IEEE 802.11b/g
    Netgear RangeMax™ WPN824 Wireless Router Questions
    Questions and Answers
    Where to Buy
    Product Reviews
    Last update: Nov 10, 2009
    Netgear RangeMax™ WPN824 Wireless Router Reviews
    Most helpful positive review
    [3 of 3 customers found this review helpful]
    Most helpful negative review
    [2 of 2 customers found this review helpful]
    5.0
    Great Value + Great Quality = Great Buy!
    "This is replaceing an older Netgear G model router that finally stopped working after 3 years of 24/7 service! The new router has no problem getting a strong signal through 5 walls to reach my TV rooom(my laptop used to have trouble getting a signal with the old router). To save time and install headache,I would suggest reseting/defaulting the router straight out of the package.I Had to reset/default the new r..." Read Full Review »
    Dec 06, 2008 by Rudy
    See more positive Netgear RangeMax™ WPN824 Wireless Router reviews
    1.0
    Inferior product
    "This router has many problems: - managing it via the browser interface has EXTREMELY slow response time - time based client filtering (e.g. disable certain IP address(s) from accessing the internet) is EXTREMELY weak. You can only set ONE schedule. - client filtering did not prevent XBOX360 (which uses UDP) from accessing the internet (i.e. connect to XBOX Live) - could not figure out how to set DHCP lease time ..." Read Full Review »
    May 01, 2008 by Dean
    See more negative Netgear RangeMax™ WPN824 Wireless Router reviews
    Displaying 1 - 5 of 358 Reviews
    Show
    Sort by
    [5 of 5 customers found this review helpful]
    Awesome Product!
    5.0
    "Pros
    Not only does the Router have a nice range and allow us to even set out on our porch and surf the net if we want... it's also very pretty, I love the white & pretty blue lights! Very attractive.
    Additional Thoughts
    This was my first time going Wireless so I had no idea it was this great or I …"  Read Full Review »
    Was this Network Router & Bridge review on the Netgear RangeMax™ WPN824 Wireless Router helpful to you?
     Report Abuse  (5)  (0)  0 comments
    Jul 17 2007
    Faithw
    Phelps, Ky
    Reviewed at:
    Price: $65.99
    Feature packe but not well documented installation
    4.0
    "Product Technology: The 802.11n technology is still nascent and there is lot of confusion in its standard and it might be few years before we get there among all manufacturers. Which means we need a technology thats widely accepted and downward compatible with the old ones.
    The WPN824 is that gatewa …"  Read Full Review »
    Sep 12 2007
    Fishie
    Stamford, CT
    Netgear's Vista Drivers Mostly Useless
    1.0
      Pros
    • Easy To Set Up
      Cons
    • None
      Best Uses
    • Home
    "If you try to use a Netgear notebook adapter on a laptop that is running Windows Vista 99% of the time it will not work. To get the high speed you have to use a Netgear RangeMax adapter with the router, and you will get the high speed if the wireless RangeMax adapter is not on a compter using Vista. …"  Read Full Review »
     Report Abuse  (2)  (0)  0 comments
    Aug 28 2007
    Frank
    Clovis, CA
    I am:
    • High bandwidth user
    Works wonderfully .. when it works.
    2.0
    "My Netgear is 3 weeks old. I purchased it for two main reasons. The SPI (stateful packet inspection) feature and the logging feature... where it automatically logs all web sites visited by the computers on the network (my kids) . It also sends logs to a designated email address. This allows me to re …"  Read Full Review »
    Oct 2 2008
    GreatAchilles
    Undisclosed
    [2 of 5 customers found this review helpful]
    Disappointed
    1.0
      Pros
    • Small
      Cons
    • Unreliable
      Best Uses
    • Home
    "We got this router to have a wireless network since we have a PC and a Laptop. Once the router was set up we routinely had issues with it talking to the laptop but not the PC and had to keep redoing the IP address, but it was manageable after the umpteenth time because we knew how to fix it. We hav …"  Read Full Review »
     Report Abuse  (2)  (3)  0 comments
    Jan 18 2008
    MN Gal
    Richmond, VA
    I am:
    pages: 1 2 3 4 5 Next »
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
