Netgear RangeMax WPN311 Wireless PCI Adapter
#2
4.0
based on 67 reviews
Ratings Distribution
5 star
33
4 star
24
3 star
7
2 star
3
1 star
7
Category Average
3.7
$49.99 - $71.99
from 12 stores
More Images
Pros
  • Reliable (11)
  • Easy to use (10)
  • Fast (9)
  • Versatile (4)
  • Durable (3)
  • Easy to install (3)
  • Fast connection (2)
  • Strong signal (2)
  • Easy setup (1)
  • Fast as lightning (1)
See less See more
Cons
  • Difficult to set up (3)
  • Unreliable (2)
Best Uses
  • Desktop (2)
  • Dorm room (2)
  • Home office (2)
  • Home or business (2)
  • High-volume (1)
  • Highly secure networks (1)
  • Home (1)
  • Home networks (1)
  • Home-desk top computer (1)
  • Small offices (1)
Provided by PC Mall
RangeMax Wireless PCI Adapter NETGEAR's exclusive RangeMax technology gives you the longest range of any wireless network on the market today - up to 10 times the wireless coverage of 802.11g. Put the NETGEAR RangeMax Wireless USB Adapter to work for you, and that's all you need - leave those range extenders, repeaters, and external antennas at the store. The RangeMax Wireless USB Adapter is optimized for use with the RangeMax Wireless Router which adjusts to the interference and physical barriers in your home, and delivers up to 500,000 square feet of coverage - 1000% more than 802.11g. And the RangeMax Wireless USB Adapter is 100% compatible with your existing 802.11b/g products - so you are free to connect at home, work, or public hotspots.Power Under the Hood:RangeMax is an advanced Smart MIMO (Multi-In, Multi-Out) technology that uses seven internal antennas in the wireless router. The RangeMax Wireless Router constantly surveys your home environment for barriers and interference and adjusts the signal to compensate for these performance inhibitors. For example, if you carry your laptop from room to room, the RangeMax Wireless Router automatically senses the change and selects from over 100 possible antenna configurations to deliver you the fastest, clearest connection! The RangeMax Wireless USB 2.0 Adapter is optimized for use with the RangeMax Wireless Router so that everyone will enjoy high-speed connections, everywhere in your house - no drop-outs, and no dead spots.Simple, Safe, Secure: Think you can't set up your wireless network without an engineering degree? Think again. NETGEAR's SmartWizard makes the set-up easy and hassle-free. NETGEAR also ensures that every computer user in your home network can work and play safely - with WEP (Wired Equivalent Privacy) and WPA-PSK (Wi-Fi Protected Access-Pre-Shared Key) Security your network will have powerful safeguards against unauthorized usage.Benefits:Up to 1000% the Coverage and Range of 802.11g, when used with the WPN824 USB Adapter WPN111 can be used with a desktop or notebook PC Easy setup via Smart Wizard install assistant Works with all standard 802.11g and 802.1b wireless routers and access points Specifications: Network Speeds:- 1, 2, 5.5, 6, 9, 11, 12, 18, 24, 36, 48,- 54 &108 Mbps (auto rate capable) Drivers:-Windows 98SE, Me, 2000 and XP Interface:- 32-bit PCI bus Encryption:-Hardware-based 40/64-bit & 128-bit WEPencryption- WPA-PSK System Requirements-Desktop or notebook PC with Pentium 300 MHz -compatible processor or higher- Available PCI slot-Windows 98SE, Me, 2000 or XPPackage Contents- RangeMax Wireless PCI Adapter WPN311- Resource CD- Installation guide-Warranty/Support information card
Specification Description
Model WPN311, WPN311NA
UPC 606449039870
Accessory Indicator Yes
Benefits Experience expanded wireless coverage when used with RangeMax Wireless Router (sold separately)Fully compatible with your existing 80
Capacity UOM mAh
Cordless/Wireless Yes
Country Of Origin China
Description Header Hotspot sweet hotspot.
Display Catalog Number 25-3348
Included in the Box RangeMax Wireless PCI Adapter WPN311Resource CDInstallation guideWarranty/Support information card
Manufacturer Labor Warranty 12
Manufacturer Parts Warranty 12
MAP Price 0.0
Model WPN311NA
New Date Thu Jun 07 00:00:00 CDT 2007
Operating Temperature UOM ° F
Product Type Wireless
Supported Languages English
Netgear RangeMax WPN311 Wireless PCI Adapter Questions
Questions and Answers
Where to Buy
$69.99
$10 Off Orders Of Orders Over $85 + Free Shipping
$49.99
$49.99
Show all 12 stores
Product Reviews
Last update: Oct 17, 2009
Netgear RangeMax WPN311 Wireless PCI Adapter Reviews
Most helpful positive review
Most helpful negative review
4.0
Two years and still going
"I actually purchased this card right when it came out 2 years ago, so I paid a whooping $100 for it. I wasn't going to write a review but people have been bad-mouthing this product, so I just wanted to write to prove that even after 2 years, it still works for me and I still continue to use it. I thought the installation was pretty easy and straight-forward. However, I don't really like the smart wizard, so I us..." Read Full Review »
Aug 22, 2008 by tones
See more positive Netgear RangeMax WPN311 Wireless PCI Adapter reviews
1.0
Not for AMD users
"After installing this card in the computer I started experiencing random lockups. I did some research after the fact and found that Netgear claims the lockups are caused by AMD processors. Unfortunately there is nothing about this listed on the box. The range also leaves something to be desired. Sitting right next to my laptop, this card showed 2 bars where my laptop showed a full 5 bar connection. Considering ..." Read Full Review »
Sep 25, 2009 by JFromSD
See more negative Netgear RangeMax WPN311 Wireless PCI Adapter reviews
Displaying 1 - 5 of 67 Reviews
Show
Sort by
4.0
I th …"  Read Full Review »
Was this Wi-Fi & Bluetooth review on the Netgear RangeMax WPN311 Wireless PCI Adapter helpful to you?
Aug 22 2008
tones
MN
Reviewed at:
Price: $49.99
Great wireless PCI adapter
5.0
"If you are trying to decide between a NetGear WPN311 and a LinkSys WMP110 get the NetGear WPN311.
Initial testing combination was a LinkSys WRT110 router, which is a very good router, a built-in wireless adapters (XP notebook), and a LinkSys WMP110 (competing card) which was put into an XP desktop. …"  Read Full Review »
May 19 2009
BeefBarley
Reviewed at:
Price: $49.99
Worth a Try
4.0
"The first wireless PCI adapter for desktop I bought is the Linksys - 802.11g Wireless Desktop Card ($50) and I experienced a lengthy, painful and angry installing process. It took me half an hour to install everything according to the manual. It did recognize my wireless network but it didn't feel l …"  Read Full Review »
Dec 20 2008
Khai
Orange County, CA
Reviewed at:
Price: $49.99
Running two of these ...
4.0
"Running two of these cards on two machines running Win 7. Works like a champ, and does everything asked of it. No need for installation CDs, since the OS pulls the latest drivers available for this product after installation. Only problem, and the reason for the 4s in Features and Performance are …"  Read Full Review »
Nov 16 2009
Troy
Undisclosed
Reviewed at:
Not for AMD users
1.0
The range also leaves something to be desired. Si …"  Read Full Review »
Sep 25 2009
JFromSD
Rapid City, SD
Reviewed at:
Price: $49.99
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
