Netgear ProSafe 5-Port 10/100 Desktop Switch (Model #FS105NA)
4.6
based on 37 reviews
Ratings Distribution
5 star
54
4 star
15
3 star
1
2 star
2
1 star
1
Category Average
4.1
$9.99 - $32.99
from 15 stores
More Images
Pros
  • Easy setup (37)
  • Reliable (35)
  • Fast (34)
  • Small (34)
  • Easily expanded (17)
  • Easily works in any setup (1)
  • Works great (1)
See less See more
Cons
  • Unreliable (2)
  • Incompatible (1)
  • Not energy efficient (1)
  • Not if you need gb (1)
Best Uses
  • Home (27)
  • Desktop (25)
  • Small networks (25)
  • Larger networks (2)
  • Rack mounted (2)
Provided by OnSale
ProSafe 5 Port 10/100 Desktop Switch NETGEAR’s popular FS100 series desktop switches, known for its reliability and performance, provide your LAN with high-speed, 10/100 Mbps auto-sensing connectivity for as many as 5, 8, or 16 users. Solid Network Performance for Growing BusinessesNETGEAR’s popular FS100 series desktop switches, known for its reliability and performance, provide your LAN with high-speed, 10/100 Mbps auto-sensing connectivity for as many as 5, 8, or 16 users. Just plug in your Ethernet cables, connect a power cord, and you’re ready to go-there’s no software to configure. They negotiate to the fastest possible connection and with Auto Uplink technology, these switches automatically figure out if the link needs a straightthrough or cross-over connection, and makes the right choice. Existing 10BASE-T devices are easily integrated within higher bandwidth environments, with full wire speeds on all ports of either 10 Mbps or 100 Mbps. Engineered without the need for internal fans, they operate silently. And each of these very compact switches is housed in a sturdy metal case for years of dependable use.When you want solid network performance for your growing business, plus the added benefit of quiet operation, NETGEAR’s ProSafe FS105, FS108, and FS116 are your best choices for quality, convenience, and smooth — running usability — all at very affordable prices.At Your ServiceFive, eight, or sixteen ports provide LAN access for many users. Every port supports up to 200 Mbps in dedicated bandwidth and traffic is forwarded flawlessly with automatic flow control.CompactSolidly built in small sizes that are easy to position when space is at a premium. Ideal for conference rooms, class rooms, study groups or small offices. Place it on any flat surface or use the included wall mount kit to tuck it out of the way.Simple To UseOnce you connect the hardware, your switch is operating! Auto negotiation takes care of the speed and duplex, while Auto Uplink takes care of the MDI/MDI-X connection. Eliminate the need for toggle switches or special crossover cables.QuietNo fan means no noise, which helps maintain a peaceful atmosphere in your busy office.Technical Specifications:Network Ports• Five (5) auto speed-sensing UTP portsStandards Compliance• IEEE 802.3 10BASE-T Ethernet• IEEE 802.3u 100BASE-TX Fast Ethernet• IEEE 802.3x Full-duplex Flow ControlPerformance Specifications• Forwarding modes: Store-and-forward• Bandwidth: 1Gbps• Network latency: Less than 20 µs for 64-byte frames in store-and-forward mode for 100 Mbps to 100 Mbps transmission• Buffer memory: 64 KB• Address database size: 1,000• Addressing: 48-bit MAC address• Mean Time Between Failure (MTBF): 390,000 hours (~40 years)• Acoustic Noise: 0 dBEnvironmental Specifications• Operating temperature: 32 to 104°F (0 to 40° C)• Storage temperature: 14 to 158°F (-10 to 70°C)• Operating humidity: 90% maximum relative humidity, non-condensing• Storage humidity: 95% maximum relative humidity, non-condensing• Operating altitude: 10,000 ft (3,000 m) maximum• Storage altitude: 10,000 ft (3,000 m) maximumSafety Agency Approvals• UL listed (UL 1950)/cUL• IEC950/EN60950Status LEDs• Power Link, speed, and activity indicators built into each RJ-45 portElectromagnetic Emissions• CE mark, commercial• FCC part 15 Class A• EN55 022 (CISPR22), Class A• VCCI Class A• C-TickAC Power• 7.5W (7.5VDC, 1A)System Requirements• Network card for each PC (e.g. NETGEAR FA311)• Network Cables• Network card for each PC or server• Network software (e.g., Windows, Linux, Mac OS)
Specification Description
Model 10273676, FS105, FS105NA
UPC 606449006865
Device Type Ethernet Switch
Number of Ports 5
Port Type 10/100Base-TX
Netgear ProSafe 5-Port 10/100 Desktop Switch (Model #FS105NA) Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 17, 2009
Netgear ProSafe 5-Port 10/100 Desktop Switch (Model #FS105NA) Reviews
Most helpful positive review
[1 of 1 customers found this review helpful]
Most helpful negative review
[0 of 1 customers found this review helpful]
5.0
Great DSL "hub"
"The DSL box that came with service from Qwest over a year ago did not have any extra ports to plug into when I got another computer and also they do not support the Macs in person just over the phone guidance is all that's offered so I bought this great little "hub" if I'm using my terminology correct ? The "hub" is fast even when two pc's are connected to it and this is a five port device so plenty of room for ..." Read Full Review »
Jun 25, 2008 by ***Galvatron***
See more positive Netgear ProSafe 5-Port 10/100 Desktop Switch (Model #FS105NA) reviews
2.0
Did not perform as expected
"As I write, I am going back and forth with the NetGear engineers on this issue:\=================================\I have LinkSys router plugged into internet box for my ISPRan out of slots for DSLI unplugged one cable in the router at random and plugged in the NetGear Ethernet Switch 5. ISP Box <= LinkSys WiFi router with 4 DSL slots <= NetGear Ethernet Switch 5I then plugged the cable I removed into the NetGear..." Read Full Review »
Jul 07, 2009 by DonWeinshank
See more negative Netgear ProSafe 5-Port 10/100 Desktop Switch (Model #FS105NA) reviews
Displaying 1 - 5 of 37 Reviews
Show
Sort by
I was looking to set-up a ...
5.0
"I was looking to set-up a small home network but wanted to get away from the wireless router to be more secure. So I went looking for a small ethernet connection for my home. I have 2 computers on my network and when I found the product was the ideal thing for what I wanted. When I got my Netgear i …"  Read Full Review »
Was this Networking Hub & Switch review on the Netgear ProSafe 5-Port 10/100 Desktop Switch (Model #FS105NA) helpful to you?
Oct 30 2009
Patrick
Undisclosed
[4 of 6 customers found this review helpful]
Perfect
5.0
"Once again, you can't go wrong with a Netgear product. If you don't want to pay for gigabit pricing and want a simple network, this 10/100 switch is the way to go. No need to play around with software setup(s). "
 Report Abuse  (4)  (2)  0 comments
Sep 20 2007
DaCoach
Gurnee, IL
This switch works great. ...
5.0
"This switch works great. I needed some extra ports and my wireless router was filled up. I connected the switch to the router and expanded my RJ45 ports. No setup required other than plugging in the cables and power supply. I would recommend it to anyone. Sent in for my $15.00 rebate, just hope I ge …"  Read Full Review »
Oct 27 2009
smmaxxx
Undisclosed
I originally bought ...
5.0
"I originally bought another brand from a different store. After two hours of trying to configure it, I gave up, returned it to the store, and bought the Netgear 5-port switch from TigerDirect. IT WAS SO EASY! I just plugged it in, it recognized my network, and I was up and running as soon as I bo …"  Read Full Review »
Sep 10 2009
Doug T.
Undisclosed
I've bought quite a few ...
5.0
"I've bought quite a few of these, and never had a failure. For a fixed environment where running new data lines isn't possible, these switches are perfect when you need to fan out an existing drop. With the rebate, these are even better (ie cheaper). Unfortunately, only one rebate per person/address …"  Read Full Review »
Jul 18 2009
Eric
Undisclosed
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
