Netgear ProSafe 24-Port Gigabit Rackmount Switch (Model #JGS524NA)
#46
4.5
based on 12 reviews
from $209.99 - $289.99
Ratings Distribution
5 star
5
4 star
6
3 star
0
2 star
0
1 star
0
Category Average
4.1
More Images
Provided by ClubMac
ProSafe 24-Port Gigabit Rackmount Switch The JGS500 series are perfect for graphics, multimedia, and other applications that have to move large files across the network quickly. Take Gigabit to the DesktopNETGEAR’s JGS500 Gigabit Switch Series gives your office network a megaboost of speed and capacity that is within your budget. With up to 48 Gbps of bandwidth, this 24-port switch can blast 2000 Mbps per port while its affordable prices enable you to put them everywhere. Use it to take Gigabit Ethernet directly to the desktop!Standards-based for easy integration of 10, 100, and 1000 Mbps devices, these unmanaged, rack-mountable switch feature 10/100/1000 automatic speed and full/half-duplex sensing plus Auto Uplink on every port. Users can take advantage of the their ability to deliver large amounts of multimedia, image, and video information in no time at all, Ideal for workgroups, labs, departments, or growing offices looking for oustanding performance at a low price.High Capacity1000 Mbps speeds and a switching capacity of up to 48 Gbps meet the performance needs for even the most bandwidth-hungry applications. The JGS500 series are perfect for graphics, multimedia, and other applications that have to move large files across the network quickly.AffordableAggressive prices enable your workgroup, department or small network to ramp up to Gigabitspeeds, even all the way to the desktop.FlexibleEach port is equipped with automatic speed and duplex sensing, plus Auto Uplink to adjust forstraight-through or crossover cables to make the right link. Standards-based design makes it easy to combine 10, 100, and 1000 Mbps devices on your network.ConvenientEasy to set up and easy to use, these unmanaged switches have per port LED's for effortless network monitoring. Compact enough for desktop but comes with a rack mount kit. Compatible with PC, Macintosh, Linux, and Unix operating systems.Product Details:Network Ports:• JGS524: 24 10/100/1000 Mbps twisted-pair RJ-45 portsPerformance:• Switching bandwidth: 48 gigabit per sec• Forward rate (1000 Mbps port): 1,480,000 packets per sec• Forward rate (100 Mbps port): 148,000 packets per sec• Forward rate (10 Mbps port): 14,800 packets per sec• Latency (1000 to 1000 Mbps): 20 ìs max• Packet Buffer Memory: 2 Mb• MAC address database: 8,000• Mean Time Between Failure (MTBF): 87,600 hours
Specification Description
Model JGS524NA
UPC 606449036459
Device Type Ethernet Switch
Number of Ports 24
Port Type 10/100/1000Base-T
Netgear ProSafe 24-Port Gigabit Rackmount Switch (Model #JGS524NA) Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Oct 8, 2009
Netgear ProSafe 24-Port Gigabit Rackmount Switch (Model #JGS524NA) Reviews
Displaying 1 - 5 of 12 Reviews
Show
Sort by
[2 of 2 customers found this review helpful]
Wonderful unit
5.0
"I upgraded to this unit after I outgrew the 8-port gigabit switch I had. This unit runs great, and has lots of room for me to grow. I would recommend this to anyone that needs more than 8 ports for their home/office and need them to be GigaBit. One thing to keep in mind though, because it is gigabit …"  Read Full Review »
Was this Networking Hub & Switch review on the Netgear ProSafe 24-Port Gigabit Rackmount Switch (Model #JGS524NA) helpful to you?
 Report Abuse  (2)  (0)  0 comments
Sep 7 2007
Cjaiceman
Englewood, CO
Reviewed at:
Price: $289.99
Great switch, ...
5.0
"Great switch, unbelievable price. At first I thought 24 ports would be overkill for the house, but I have slowly been chipping away an now have 6 or 7 ports filled with tons of expansion space. I did have some problems hooking my VoIP telephone to the switch it seems to want to connect directly to …"  Read Full Review »
Jul 19 2009
John S.
Undisclosed
I ordered this switch ...
4.0
"I ordered this switch about a month ago. It doesnt look or act like any other refurb I have ever used. The product worked out of the box, and I have not had any true problems with it. Others have noted that there is packet loss going from giga-bit to 100Mb connections, which I have noticed, however …"  Read Full Review »
Jul 18 2009
Undisclosed
Everything works ...
4.0
"Everything works flawlessly with the exception of going between a gigabit connection and a 100 megabit connection. As others have reported there is packet loss in Version 1, which just so happens to be the version I ended up with. This doesn't bother me that much, because it does not change my avera …"  Read Full Review »
Jun 30 2009
Undisclosed
Plug and play, 24-ports ...
4.0
"Plug and play, 24-ports of GB LAN, great price... buy this switch. I've had one for about 12 months, all ports used, heavy internal network traffic, and have never had a problem with any connections, not even so much as a hiccup. It would be ideal to see it priced around $189-200 without a rebate, a …"  Read Full Review »
Sep 26 2008
Swarty210
Undisclosed
pages: 1 2 3 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
