#3
based on 38 reviews
Ratings Distribution
| 5 star |
58 |
| 4 star |
17 |
| 3 star |
6 |
| 2 star |
3 |
| 1 star |
6 |
Category Average
$16.49 - $34.99
from 14 storesPros
Cons
Best Uses
Where to Buy
| $1.99 Shipping On Orders Over $100 at TigerDirect ends 12/31/09 |
BizRate Rating
Outstanding 9.1
BizRate Rating
Good 8.9
BizRate Rating
Good 8.7
Product Reviews
[0 of 1 customers found this review helpful]
[2 of 2 customers found this review helpful]
"When I'm working on a computer if there is a problem with the Network Card. Everytime I replace with this card and load the drivers I'm up and running. My main machine the onboard LAN Card kept kicking me off the Internet. Updated the drivers and flashed the bios plue re-imaged my machine. Still same prob. Installed this Netgear Card and problem solved. Very Simple, Less Stress... Also can't say enough good thi..." Read Full Review »
Sep 28, 2007 by Technical Level II and Beyond
See more positive Netgear Gigabit Ethernet PCI Adapter (Part #GA311NA) reviews
"Bought two; first failed to install XP Pro SP3 - defect in install process for v 6.1 Download and hand installed 6.2, finally worked after 3 hours of frustraion to get GIG performance. Second unit no success at all negotiating GIG with Netgear switch - no connection at all. Have spent > 8 hours getting no where and I work in IT - 30 yrs experience. It does work 100 bps with another switch, but I bought GA311..." Read Full Review »
Nov 30, 2008 by Bob
See more negative Netgear Gigabit Ethernet PCI Adapter (Part #GA311NA) reviews
Displaying 1 - 5 of 38 Reviews
Netgear Gigabit Ethernet PCI Adapter (Part #GA311NA) Review
"I purchased the card to replace a marginal motherboard ethernet connection. Card and drivers installed easily and have been working for 2 months without issue. I plan on purchasing a second NIC so my PC can connect to a second network. Note: installations steps are different for XP vs. Vista. Read t …" Read Full Review »
[2 of 3 customers found this review helpful]
"Netgear says this will work in linux 2.6 kernel. That is not quite correct. It will recognize and load default driver, but it will only transfer speed at 10 mbs. Card info shows 1000 mbs, but you can't get it to work that way. This card uses the Realtek 8169 chip. There is a work around on the forum …" Read Full Review »
"I also had driver problems on Win XP pro using the cd. I followed the instructions exactly but my system would first not see it and then simply not work if I installed them manually. One of the issues seemed to be that XP found the files to be corrupted.
I downloaded new driver and utility softwa
Read Full Review »
"I have bought just two Netgear GA311, 10-100-1000Mbs; along with brand new Data Link NIC 10-100-1000Mbs just to try, because I haven't any used any Negear in the past and turn out it was great. Eventhough, It was a refurbished and sale for $9.95/NIC. After, I received from Tiger. I downloaded the …" Read Full Review »
"I bought two of the Netgear cards to setup a gigabit network between a media server (running Windows Server 2008), home PC (running Vista Enterprise), and eventually a PS3 for playback on my TV. Installation was simple, I downloaded the latest drivers for the card before I installed. I have experi …" Read Full Review »
Email Address: (required)
Comments:
or Cancel
Where to Buy
BizRate Rating
Outstanding 9.1
BizRate Rating
Good 8.9
BizRate Rating
Good 8.7
BizRate Rating
Good 8.9
BizRate Rating
Good 8.8
| $1.99 Shipping on Orders Over $75 ends 12/31/09 | ||||
| Free Shipping on Orders Over $299 ends 07/03/14 | ||||
BizRate Rating
Good 8.8
| $10 Off Orders Of Orders Over $85 + Free Shipping |
BizRate Rating
Good 8.7
BizRate Rating
Good 8.5
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.comPrices, inventory, and product information are provided by the merchants and may include any promotional discounts that are not available to all customers. We assume no responsibility for accuracy of price information provided by merchants, but please price_alerts|snabela|powerreviews.com to any pricing discrepancies so we can notify the merchant. Additionally, sales taxes and shipping costs are not included in listed prices, so please check with the merchant for total costs.
Powered by PowerReviews, Inc. ©2009 All Rights Reserved
