Netgear DGN2000 Wireless-N Router
#271
3.6
based on 34 reviews
from $98.99 - $119.99
Ratings Distribution
5 star
43
4 star
30
3 star
8
2 star
9
1 star
19
Category Average
3.9
$98.99 at B&H Photo Video
Find it at Amazon
Find it at Ebay
More Images
Pros
  • Reliable connection (57)
  • Easy setup (55)
  • Fast (53)
  • Fast connection speed (50)
  • Secure connection (46)
  • Compact (3)
  • Easy to use (1)
  • Good signal strength (1)
See less See more
Cons
  • Difficult to set up (13)
  • Unreliable connection (8)
  • Slow connection speed (4)
  • Not secure (3)
  • 2 pc stand (1)
  • Clueless tech support (1)
  • Difficult to program (1)
  • Need better directions (1)
  • Not a frigging thing (1)
Best Uses
  • Home network (64)
  • Small networks (17)
  • Home or business (2)
  • Large networks (1)
Provided by Overstock.com
The DGN2000 Wireless-N Router is fully compatible with Verizon, AT&T, Qwest, EarthLink and other DSL Internet Service Providers. You surf, make Internet phone calls, play online games and stream HD video simultaneously. Replace your old DSL equipment with new Wireless-N. Its Push 'N' Connect securely connects at the touch of a button. *Manufacturer: Netgear, Inc *Manufacturer Part Number: DGN2000-100NAS *Manufacturer Website Address: www.netgear.com *Product Name: DGN2000 Wireless-N Router *Product Type: Wireless Router *Frequency Band/Bandwidth: 2.4 GHz IEEE 802.11b/g ISM Band *Channels: 3 *Transmission Speed: 300Mbps *Transmission Speed Details: 6Mbps IEEE 802.11g, 11Mbps Auto-fallback IEEE 802.11b, 54Mbps Auto-fallback IEEE 802.11g, 300Mbps IEEE 802.11n (draft), 1Mbps IEEE 802.11b *Interfaces/Ports: 1 x RJ-11 ADSL WAN *Dimensions: 7" x 5.1" x 1.22", 7" x 5.1" x 1.22" *Weight: 0.58 lb, 0.58 lb
Specification Description
Model DGN2000-100NAS, DGN2000100NAS
UPC 606449058727
Interface 4 x RJ-45 10/100Base-TX LAN
Transmission Speed 300Mbps
Wireless Technology Wi-Fi IEEE 802.11n (draft)
Netgear DGN2000 Wireless-N Router Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 17, 2009
Netgear DGN2000 Wireless-N Router Reviews
Most helpful positive review
[2 of 2 customers found this review helpful]
Most helpful negative review
5.0
Don't listen to these doomsayers!!
"Despite all the warnings here, I took the risk and purchased the DGN2000. I have no idea what all these "techno wizards" are babbling about. It took exactly 13 minutes to set up and get running. NOT ONE SINGLE PROBLEM as described by all those techno [*]. In no time flat I had all 5 of our computers (3 desktop and 2 laptops) initialized and connected. The router is FAST and have not had a single drop, loss ..." Read Full Review »
Jun 03, 2009 by Kestrel
See more positive Netgear DGN2000 Wireless-N Router reviews
3.0
First unit took phone my line off hook
"Set up was smooth but the first one I got took my phone line off hook. The second one was fine. I had a feeling phone support would be a waste of time, and I was right. All were clueless and when I asked to be transferred to a supervisor I got disconnected. Email support also useless. Also even though I enabled uPnP on this thing, my Buffalo LinkStation said there was no upnp gateway or router even though i..." Read Full Review »
Nov 10, 2009 by Jeff
See more negative Netgear DGN2000 Wireless-N Router reviews
Displaying 1 - 5 of 34 Reviews
Show
Sort by
STAY FAR, FAR AWAY!!
1.0
"Purchased this unit mostly for the greater range; it replaced the 802.11b modem with built-in router provided by my isp when I got dsl.
Got it home, took it out of the box, and the problems began. Did not install properly from the installation cd; ended up calling tech. support. Almost 5 hours late …"  Read Full Review »
Was this Wireless Networking review on the Netgear DGN2000 Wireless-N Router helpful to you?
Mar 22 2009
memjay
Guyton, GA
Reviewed at:
Price: $119.99
Easy setup and works well with DSL ISP
5.0
    Pros
  • Easy To Setup
  • Fast
  • Fast Connection Speed
  • Secure Connection
    Cons
  • None
    Best Uses
  • Home network
  • Large Networks
  • Small Networks
"My provider for DSL is currently AT&T. I use this for business and personal use and I am a medium bandwith user. Speeds are faster than my old wireless G and DSL modem setup. Works great with VOIP service as well.
Setup was as easy as plugging in the phone line then running the setup applicati …"  Read Full Review »
 Report Abuse  (2)  (0)  0 comments
Sep 29 2009
subzero
Elburn, IL
I am:
  • High bandwidth user
Reviewed at:
Price: $98.99
I bought this product ...
3.0
"I bought this product after my ATT provided DSL modem started to fudge out on me, you can't expect it to run after 2 years like it did when you first got it. Kept D/C me. I got this cause I thought having your router and modem in one would be a good idea. The installation CD was horrible, took forev …"  Read Full Review »
Aug 14 2009
dr2real
California
Reviewed at:
Price: $119.99
What took me so long?
5.0
"I'm not sure what problems people are having installing this but my installation went with barely a hitch. I am using Verizon DSL as my ISP. The first time through it didn't configure properly and failed. I simply turned it off and on again and went through the setup once more. This time, it sailed …"  Read Full Review »
Sep 19 2009
DerekJ
Ballston Lake, NY
Reviewed at:
Price: $119.99
Worste experience in a long time
1.0
"I gave value on this 2 stars becuase it is a Wirles N router and modem together, but doesn't do you much good if it won't connect. Maybe this one was just a lemon based on other reviews but I am not willing to try another one. I have AT&T; dsl which a lot of the reviewers have as well but no matter …"  Read Full Review »
Jan 15 2009
BadWayne
Wichita Falls, TX
Reviewed at:
Price: $119.99
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
