Netgear 8-Port Gigabit Ethernet Switch - GS108NA
#274
4.3
based on 19 reviews
from $59.99 - $85.52
Ratings Distribution
5 star
11
4 star
4
3 star
1
2 star
1
1 star
1
Category Average
4.1
More Images
Pros
  • Easy setup (5)
  • Reliable (5)
  • Easily expanded (4)
  • Fast (4)
  • Small (4)
See less See more
Cons
  • Unreliable (1)
Best Uses
  • Small networks (6)
  • Desktop (5)
  • Home (5)
Provided by Shoppers Choice
MODEL- GS108NA VENDOR- NETGEAR FEATURES- 8-Port Copper Gigabit Switch Now you can have a powerful, high-speed network on a small scale. NETGEAR s GS108 Gigabit Ethernet Switch lets you build a system that provides a full, dedicated 1000, 100, or 10 Mbps connection so you can move very large files across your network instantly. The GS108 also lets you painlessly integrate 10, 100, and 1000 Mbps devices. This potent switch is packed with ease-of-use features to simplify your workday experience. It s compact design fits neatly into small work spaces and, since it s self-cooling without a fan, it runs silently and unobtrusively. Moves huge files fast! Features a high-speed, auto-switching 10/100/1000 Mbps Ethernet connection. And because Copper Gigabit Ethernet is a full duplex standard, you can get up to 2000 Mbps on each port. Integrates 10, 100, and 1000 Mbps devices on the same network. Every port automatically senses the right speed and full/half duplex mode, while Auto Uplink technology automatically adjusts for straight-through or crossover cables. LEDs embedded in each of the 8 RJ-45 jacks make for easy monitoring. Space-saving dimensions are ideal for desktop or wall mounting in home and small office environments. And it runs quietly, self- cooling without an internal fan. Strong, durable metal case securely protects the switch s working parts. The GS108 is made to last and NETGEAR backs it with a solid warranty: switch - 5 years, power supply - 2 years. Includes Gigabit Ethernet Switch, Wall-mount kit, AC adapter, Installation guide, Warranty card, Support information card. -- SPECIFICATIONs ---------------------------------------STANDARDs - IEEE 802. 3i 10BASE-T Ethernet IEEE 802. 3u 100BASE-T Fast Ethernet IEEE 802. 3ab 1000BASE-T Gigabit Ethernet Windows, MacOS, Netware, TCP/IPCONNECTORs - (8) 10BaseT/100BaseTX/1000BaseT/RJ45 ports (auto-sensing)FORWARD MODE- Store-and-Forward INDICATORs - Status LEDs for Power, Collision/Rx/Tx, and duplex indicators for each port. Status LEDs for Link an speed indicators built into each vista RJ-45 port. PERFORMANCE - Bandwidth: 16 Gbps (non-blocking) Forward Rate (10 Mbps port): 14,800 packets/sec Forward Rate (100 Mbps port): 148,000 packets/sec Forward Rate (1000 Mbps): 1,480,000 packets/sec Latency (10 to 100 Mbps): 40 usec (max) Latency (1000 Mbps port): 10 usec (max) Queue Buffer Memory: 32 Kbytes per port MAC address database: 8000 Acousitc Noise: 0 dB Heat Dissipation: 38. 8 Btu/hrREQUIRES - UTP Category 5 or better cables, Network card for each PC or server (e. G. GA302T), Network software (e. G. Windows, Linux, Mac OS). APPROVALS- UL (UL 1950), CUL, C-tick, CE mark, commercial FCC B, EN55 022 (CISPR 22), Class B VCCI, Class B C-Tick. POWER- 5V and 5A, Power Adapter included; Consumption 17. 5WSIZE - 11. 3 inchw x 0. 98 inchh x 3. 93 inchd WT. - 1. 98 lbs. Www. Netgear. Com
Specification Description
Model 10273676, GS108, GS108NA
UPC 606449025163
Device Type Ethernet Switch
Network Type Wired Ethernet
Number of Ports 8
Port Type 10/100/1000Base-T
Select Switches
Netgear 8-Port Gigabit Ethernet Switch - GS108NA Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Sep 17, 2009
Netgear 8-Port Gigabit Ethernet Switch - GS108NA Reviews
Most helpful positive review
[2 of 2 customers found this review helpful]
Most helpful negative review
4.0
Gotta Love GigaBit
"This is an inexpensive way to boost your local area network speed at home or in a small office!..." Read Full Review »
Jul 23, 2008 by M.Malerba
See more positive Netgear 8-Port Gigabit Ethernet Switch - GS108NA reviews
3.0
ProSafe 8-Port Gigabit Desktop Switch
"A switch was needed at the center of my star-topology Cat 5e network, which was located in the basement of my residence. In addition to the basic features of the ProSafe 8-Port Gigabit Switch, I was attracted to two features: built-in wall mounting and ports on the FRONT of the switch, which facilitates changing patch cables from a patch panel. The product met all my expectations. The wall mounting took only..." Read Full Review »
Dec 03, 2008 by Bill - retired systems manager
See more negative Netgear 8-Port Gigabit Ethernet Switch - GS108NA reviews
Displaying 1 - 5 of 19 Reviews
Show
Sort by
3.0
    Pros
  • Easily Expanded
  • Easy To Set Up
  • Fast
  • Reliable
  • Small
    Cons
  • None
    Best Uses
  • Desktop
  • Home
  • Small Networks
"A switch was needed at the center of my star-topology Cat 5e network, which was located in the basement of my residence. In addition to the basic features of the ProSafe 8-Port Gigabit Switch, I was attracted to two features: built-in wall mounting and ports on the FRONT of the switch, which facil …"  Read Full Review »
Was this Networking Hub & Switch review on the Netgear 8-Port Gigabit Ethernet Switch - GS108NA helpful to you?
Dec 3 2008
Herriman, UT
I am:
  • High bandwidth user
Gotta Love GigaBit
4.0
    Pros
  • Easily Expanded
  • Easy To Set Up
  • Fast
  • Reliable
  • Small
    Cons
  • None
    Best Uses
  • Desktop
  • Home
  • Small Networks
"This is an inexpensive way to boost your local area network speed at home or in a small office! "
 Report Abuse  (2)  (0)  0 comments
Jul 23 2008
M.Malerba
Benicia, CA
I am:
Reviewed at:
Price: $67.95
[1 of 1 customers found this review helpful]
Item Failed
2.0
"This switch was fantastic until it bit the dust. I used it in a software testing lab environment without any problems until one day all the lights were blinking (one second on and one second off). Others are having the same problem with this model, read the review from Jim Beveredge (http://qualapps …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Nov 8 2007
KeyRat
Virginia Beach
Reviewed at:
Price: $84.99
Works well and lifetime warranty
4.0
"I have two GS108's. One failed after maybe two years of constant use. It was a strange failure, but after describing to Netgear support what the problem was (packet loss) and also getting them to realize that the ProSafe series has a Lifetime warranty I got a replacement unit two days later. Other t …"  Read Full Review »
Nov 20 2008
BenGeekn
San Jose, California
Reviewed at:
Price: $84.99
I love it
5.0
    Pros
  • Easily Expanded
  • Easy To Set Up
  • Fast
  • Reliable
  • Small
    Cons
  • None
    Best Uses
  • Desktop
  • Home
  • Small Networks
"This is the second one I have purchase for work, and they both work great and very easy to use. "
Sep 17 2009
John C.
Nashville, TN
I am:
Reviewed at:
Price: $67.95
pages: 1 2 3 4 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
