Netgear 54 Mbps Wall-plugged Wireless Range Extender Kit
#284
3.5
based on 23 reviews
Ratings Distribution
5 star
12
4 star
9
3 star
2
2 star
7
1 star
4
Category Average
3.9
$99.99 - $130.00
from 12 stores
More Images
Pros
  • Easy setup (10)
  • Compact (5)
  • Fast connection speed (4)
  • Highly compatible (4)
  • Reliable connection (4)
  • Fast (3)
  • Secure connection (3)
  • Secure (2)
  • Good concept (1)
  • Good performance (1)
See less See more
Cons
  • Difficult to set up (3)
  • Unreliable connection (3)
  • Not secure (2)
  • Slow connection speed (2)
  • Unreliable (2)
  • Hard to install (1)
  • Outlet requirement (1)
  • Poor execution (1)
  • Poor instructions (1)
  • Security setup difficult (1)
Best Uses
  • Home networks (7)
  • Home network (6)
  • Small offices (4)
  • Small networks (2)
  • Larger buildings (1)
  • Returned product (1)
Provided by Shoppers Choice
MODEL- WGXB102NA VENDOR- NETGEAR INC. FEATURES- 54 Mbps Wall-Plugged Wireless Range Extender Kit Receive Wireless Internet Access from any Power Outlet in Your Home. As home networking continues to spread and evolve at rapid speed, some users find that their wireless router does not reach all corners of their home, or that they would like to have their wireless network originate from a point of their choosing, rather than be tethered to the point where the Internet enters their home. Other users would rather have a wireless network where no product is on the floor, and no cables are visible at all. The WGXB102 allows the user to have their wireless network originate from the middle of their home, or from even the furthest extremity, with no cables visible. The kit consists of the XE102 Wall-Plugged Ethernet bridge and a WGX102 54 Mbps Wall-Plugged Wireless Range Extender. The XE102 connects to an existing wired or wireless router from any vendor, and the WGX102 can be plugged into any electrical outlet to create an area of wireless access. Includes Wall-Plugged Ethernet Bridge XE102, 54 Mbps Wall-Plugged Wireless Range Extender WGX102, XE102 Resource CD, WGX102 Resource CD, XE102 Installation guide, WGX102 Installation guide, Ethernet Cable, Warranty/Support information card, Readme Flyer. NOVEL Plug the XE102 into a wired or wireless router from any vendor, and then plug the WGX102 into any power outlet at your desired location to provide wireless access where desired. ATTRACTIVE A new wall-plugged form factor allows the user to have a full wireless network without any visible Ethernet cables, and without any floor or desk space occupied. The sleek platinum casing blends well into any home decor. -- SPECIFICATIONs -----------------------------------STANDARDS - 10 Mbps 10BASE-T; 20 Mbps full-duplex 10BASE-T; Homeplug 1. 0, 802. 11g wirelessINTERFACE - RJ-45NETWORK PORT - 10 Mbps twisted-pair RJ-45INDICATORS - XE102: 3 LEDs, Power, Homeplug, Ethernet WGX102: 3 LEDs, Power, Homeplug, WirelessREQUIREMTNS - Windows for Workgroups 3. 11 Windows 95, 98, 2000, Me, (drivers inside Windows XP), Windows NT 3. 51, 4. 0. Novell NetWare Client32 for DOS Client for Windows 95/98 Server 4. 10, 4. 11, 5. 0. RedHat Linux 5. 4, 6. 0 CO OpenServer (Unix) NDIS 2. 0 for DOS driver for operating systems that require it. A wired or wireless home routerSIZE - 3. 0 inch x 8. 6 inch x 6. 5 inch WT. - 2. 0 lbs. Www. Netgear. Com
Specification Description
Model WGXB102NA
UPC 606449036572
Network Type PowerLine
Netgear 54 Mbps Wall-plugged Wireless Range Extender Kit Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Sep 24, 2009
Netgear 54 Mbps Wall-plugged Wireless Range Extender Kit Reviews
Most helpful positive review
Most helpful negative review
[4 of 4 customers found this review helpful]
4.0
Solved my problem
"This solved my problem of not being to receive a wireless signal through my screened in deck. The screen were acting as a buffer. I just plugged into an electrical outlet on the deck and have no more connection issues. Out of the box setup was very easy. Was on internet surfing within 5 min. The trouble began when I attempted to secure the connection with a wep setting. Contacted tech support and all of thei..." Read Full Review »
Aug 22, 2008 by Eric
See more positive Netgear 54 Mbps Wall-plugged Wireless Range Extender Kit reviews
2.0
Good concept, Poor design
"[...]it will work across different circut breakers, but the outlets must come from the same panel box. This means that it SHOULD work anywhere in your average home. However, it doesn't allow for any kind of encryption on the network you're boosting and the reliability is horrible. Furthermore, the user-manual and setup guide are very poorly written with inadequate details where it counts. I would not recommend e..." Read Full Review »
Oct 02, 2007 by pontiacfiero69
See more negative Netgear 54 Mbps Wall-plugged Wireless Range Extender Kit reviews
Displaying 1 - 5 of 23 Reviews
Show
Sort by
2.0
    Pros
  • None
    Cons
  • Difficult To Setup
  • Not Secure
    Best Uses
  • Home network
Was this Wireless Networking review on the Netgear 54 Mbps Wall-plugged Wireless Range Extender Kit helpful to you?
 Report Abuse  (4)  (0)  0 comments
Oct 2 2007
pontiacfiero69
Chestertown, NY
I am:
  • High bandwidth user
Reviewed at:
Solved my problem
4.0
    Pros
  • Fast
  • Fast Connection Speed
  • Secure Connection
    Cons
    Best Uses
  • Home network
"This solved my problem of not being to receive a wireless signal through my screened in deck. The screen were acting as a buffer. I just plugged into an electrical outlet on the deck and have no more connection issues. Out of the box setup was very easy. Was on internet surfing within 5 min. The …"  Read Full Review »
Aug 22 2008
Eric
Kansas City, MO
I am:
Reviewed at:
[1 of 1 customers found this review helpful]
worked instantly and perfectly in my hou
5.0
    Pros
  • Easy To Setup
    Cons
  • None
    Best Uses
  • Home network
"I recently had to replace an old "B" router/wireless and had multiple issues with a major-brand new "G" system. I took it back and got a Powerline system. It set up in one minute. Works in power sockets all over my house, including back yard/garage, which surprised me. The "base" station is in m …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Sep 30 2007
bq
LA
I am:
Reviewed at:
Excellent results
4.0
    Pros
  • Fast
  • Secure Connection
    Cons
    Best Uses
  • Home network
"An odd-shaped apartment with plaster walls over metal lath defeated wireless repeaters, but this solution using power lines solved the problem perfectly after getting the product configured to work with a secured wireless network. The instructions were somewhat confusing, but the included software d …"  Read Full Review »
Sep 24 2009
cloudscraper
Philadelphia, PA
I am:
Reviewed at:
Price: $99.99
Did not work for me
2.0
    Pros
  • None
    Cons
    Best Uses
  • Home network
"May work for some users just fine, but if the electrical system in your home consists of multiple sub-panels or "older" wiring then this may not be your best solution to extending wireless signal. Tech support was, hmmm, not support. I am fairly familiar with networking, at least knowing enough to b …"  Read Full Review »
Oct 29 2008
Bud
Enfield, NH
I am:
  • high bandwidth user
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
