Motorola TN20 GPS Receiver
3.4
based on 14 reviews
from
Ratings Distribution
5 star
5
4 star
2
3 star
3
2 star
2
1 star
2
Category Average
4.1
Pros
  • Compact (10)
  • Easy setup (10)
  • Acquires satellites quickly (9)
  • Simple controls (9)
  • Easy to read (7)
  • Easy menus (6)
  • Reliable (5)
  • Large clear lcd (4)
  • Durable (1)
  • Good value (1)
See less See more
Cons
  • Short battery life (4)
  • Acquires satellites slowly (2)
  • Inaccurate (2)
  • Complicated controls (1)
  • Couldn't find typed-in rd (1)
  • Difficult menus (1)
  • Flimsy mounting (1)
  • Lack of pois (1)
  • Not compatible with mac's (1)
  • Slow changing states (1)
Best Uses
  • Planning trips (5)
  • Finding specific address (4)
  • Rural navigation (4)
  • Urban navigation (3)
  • Faster routes (1)
Provided by RadioShack
Make just getting there fun with the TN20 from Motorola.
Specification Description
Model TN20
2D/3D view Yes
Anti-glare Yes
Battery Average Run Time 2.5
Battery Average Run Time UOM HOURS
Battery Type Product
Benefits Dynamic text-to-speech guidance conveniently informs you of upcoming street namesFind more than one million points of interest quickl
Capacity UOM mAh
Color support Yes
Country Of Origin China
Customizable screens Yes
Description Header Makes getting there fun.
Display Catalog Number 20-320
Display size (diagonal) 3.5 inches
End Product Indicator Yes
Manufacturer Labor Warranty 12
Manufacturer Parts Warranty 12
MAP Price 0.0
Maps Continental U.S.
Menu navigation Touchscreen
Model TN20
New Date Sun Jan 11 00:00:00 CST 2009
Operating Temperature UOM ° F
Other features Zoom and move maps, lane guidance, 2D and 3D maps
Points of interest 1 million
Product Type Car
Rechargeable Yes
Subtitle
Supported Languages English
Touchscreen Yes
Type Touchscreen
Voice Guidance Yes
Motorola TN20 GPS Receiver Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: TN20 GPS Receiver
See all eBay results
  at eBay.com
Product Reviews
Last update: Jun 26, 2009
Motorola TN20 GPS Receiver Reviews
Most helpful positive review
[2 of 2 customers found this review helpful]
Most helpful negative review
[0 of 1 customers found this review helpful]
5.0
BEST GPS OUT THERE!!!
"I live in a city where I have only been for 5 years. Going downtown on those busy streets and not knowing which ones where one way or both ways was scary, stressful, and confusing to me. Since I bought this unit the day after Thanksgiving I use it ALL the time, so much more than I even thought. It is SO great on recalculating your trip very fast if you make the wrong turn, which is great for me when driving d..." Read Full Review »
Dec 13, 2008 by Kandi
See more positive Motorola TN20 GPS Receiver reviews
1.0
Not Good
"I was eager to use as this was a gift. The very first address was a familiar one. It was to my daughters school address. It wanted to take me down an avenue which was going the opposite way. But I took it anyway just to see. Bad mistake as it took me in circles. Also even though it has street speech and all that stuff it wont tell you the name of the street to turn. It will say turn left or turn right. You h..." Read Full Review »
Jun 26, 2009 by Dissappointed
See more negative Motorola TN20 GPS Receiver reviews
Displaying 1 - 5 of 14 Reviews
Show
Sort by
5.0
    Pros
  • Acquires Satellites Quickly
  • Compact
  • Easy Menus
  • Easy To Read
  • Easy To Set Up
  • More »
    Cons
  • None
    Best Uses
  • Finding Specific Address
  • Planning Trips
  • Rural Navigation
  • Urban Navigation
…"  Read Full Review »
Was this Car GPS review on the Motorola TN20 GPS Receiver helpful to you?
 Report Abuse  (2)  (0)  0 comments
Dec 13 2008
Kandi
Louisville, KY
I am:
  • Power User
Reviewed at:
Great GPS--Absolutely LOUSY documentatn
4.0
    Pros
  • Compact
  • Easy Menus
  • Easy To Read
  • Easy To Set Up
  • More »
    Cons
  • None
    Best Uses
"It was only by playing with this GPS that I discovered how I could touch the screen and drag the map around--very, very usefull, especially zoomed out a degree or two. Also the navigation of the POI's and use of saving destinations in case of changing to a short detour--like pointing it to a restau …"  Read Full Review »
Apr 10 2009
Greg
Saginaw, MI
I am:
  • Casual User
Reviewed at:
Good product with a few UI issues
4.0
    Pros
  • Compact
  • Easy To Read
  • Easy To Set Up
  • Large Screen
  • More »
    Cons
  • Short Battery Life
    Best Uses
  • Planning Trips
  • Rural Navigation
  • Urban Navigation
"Generally been good. I did have one failure that locked up the screen with a (Windows?) error dialogue box. Unfortunately, there is no way to say OK and reboot. I had to hold the power button down for 5-7 seconds, and then it finally rebooted. Occasionally, the interface is not completely intui …"  Read Full Review »
Feb 13 2009
traveling man
cary, nc
I am:
  • Enthusiast
Reviewed at:
Not Good
1.0
    Pros
  • Compact
  • Easy Menus
  • Easy To Set Up
  • Simple Controls
    Cons
  • Flimsy Mounting
  • Inaccurate
    Best Uses
  • None
"I was eager to use as this was a gift. The very first address was a familiar one. It was to my daughters school address. It wanted to take me down an avenue which was going the opposite way. But I took it anyway just to see. Bad mistake as it took me in circles. Also even though it has street sp …"  Read Full Review »
 Report Abuse  (0)  (1)  0 comments
Jun 26 2009
Dissappointed
Brooklyn, NY
I am:
  • Casual User
Reviewed at:
TN 20 is more like 19 and a half
2.0
    Pros
  • Compact
    Cons
  • Acquires Satellites Slowly
  • Tactile feedback
    Best Uses
"I would give this product a two of five and that's only because of low cost for text to voice. This product takes a long time to figure out where it is when you change states. I flew to Kansas and this thing 15 minutes to finally get going. Very annoying. Also, when driving across state borders …"  Read Full Review »
Apr 5 2009
Jake
Monmouth County New Jersey
I am:
  • Power User
Reviewed at:
pages: 1 2 3 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
