Motorola Talkabout EM1000R Two Way Radio
#54
4.1
based on 16 reviews
Ratings Distribution
5 star
9
4 star
4
3 star
0
2 star
1
1 star
2
Category Average
3.9
Low Price:
$26.99 at Amazon
 Trusted:
$42.99 at B&H Photo Video
$37.99 at ClubMac
see all stores
$26.99 - $69.99
from 16 stores
More Images
Pros
  • Clear signal (11)
  • Compact (9)
  • Accurate controls (8)
  • Easy setup (8)
  • Nice sound (8)
  • Lightweight (3)
  • Easy to use (2)
  • Good feelfit in hand (1)
  • Rugged (1)
  • Weatherproof (1)
See less See more
Cons
  • Not durable (2)
  • Poor reception (2)
  • Short range (2)
  • Chan sel needs own knob (1)
  • Less than 1 mile (1)
  • Not a business radio (1)
  • Poor battery life (1)
Best Uses
  • Families (3)
  • Basic systems (2)
  • Larger rooms (2)
  • Camping (1)
  • Comm with 2nd car on trip (1)
  • Hiking (1)
  • Hunting (1)
  • Outdoors (1)
Provided by Gander Mountain
The Motorola Talkabout® EM100 22-Channel Two-Way Radio, 2-Pack, is an ideal emergency preparedness communication tool for outdoor enthusiasts and active lifestyles. With a range of up to 20 miles, the radios feature an emergency alert button to inform others of danger and a built-in LED flashlight for evening adventures or unexpected emergencies and power outages. Tune into one of seven NOAA channels to keep in touch with changing weather conditions during your family's camping adventure. QT (Quiet Talk) interruption filter allows you to communicate with other compatible Motorola products.22 channels including seven NOAA channels for up-to-date weather informationUp to a 20-mile range under ideal conditions121 privacy codes help limit interruptioniVox hands-free communication helps keep you moving without stopping to answer a callAdvanced priority scan allows you to scan channels and privacy codesRuns for 10 hours on 2 NiMH rechargeable battery packs (included) or 31 hours on three AA alkaline batteries (not included)Battery save feature and time-out timer help extend battery lifeAudible low battery alert lets you know when to rechargeKeypad lock prevents accidental channel change and emergency alert button transmits an alert siren to warn of impending dangerMini-USB charging portIncludes two radios, two belt clips, one dual charger, one charging adapter and two NiMH rechargeable battery packsWarranty: 1 year limited
Specification Description
Model 1072880, EM1000R, TS128MCF80, TS1GSDM80
UPC 760557797623
#per pack 2
Audible Battery Alert Yes
Audible Call Alert Yes
Battery Type Product
Belt Clip Yes
Benefits Keeps you in contact and prepared for anything during emergency situationsEmergency alert feature ensures you are informed when dange
Capacity UOM mAh
Channels 22 Channels
Chemistry Ni-MH
Country Of Origin China
Description Header Emergency communication.
Display Catalog Number 21-111
Display Features Backlit display, LCD battery meter
Enclosure Color Black
End Product Indicator Yes
Included in the Box Motorola EM1000R two-way radios (2)Dual chargerBelt clips (2)Charging adapterNi-MH rechargeable battery pa
Includes NOAA Weather Channels Yes
Inputs 1 x (Mini USB)
Keypad Lock Yes
Manufacturer Labor Warranty 12
Manufacturer Parts Warranty 12
MAP Price 0.0
Max Talk Range 20 Miles
Model EM1000R
New Date Wed Nov 05 00:00:00 CST 2008
Operating Temperature UOM ° F
Outputs 1 x (Mini USB)
Power Device Power charger, Ni-MH rechargeable battery, "AA" batteries (3)
Product Depth 7.8
Product Dimensions UOM inches
Product Height 1.3
Product Type Walkie-talkies
Product Weight 0.33
Product Weight UOM pounds
Product Width 2.4
Radio System Type FRS
Rechargeable Yes
Supported Languages English
Voice Operated Transmission (VOX) iVOX
Weather Alert Yes
Motorola Talkabout EM1000R Two Way Radio Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Oct 27, 2009
Motorola Talkabout EM1000R Two Way Radio Reviews
Most helpful positive review
[6 of 6 customers found this review helpful]
Most helpful negative review
[4 of 6 customers found this review helpful]
5.0
FRS/GMRS Radio 101
"A FRS / GMRS radio frequency is mainly intended to be used by families and other non-business users. However with that being said FRS or Family Radio Service frequencies are liscensed to be used by any person or entity for legal purposes. This means that businesses can use the radio just like a family on a camping trip can use them. The radios are not normally designed for heavy duty or commercial use. If y..." Read Full Review »
Apr 21, 2009 by The One
See more positive Motorola Talkabout EM1000R Two Way Radio reviews
1.0
Units die quickly
"we bought 4 of them to use on one job of installing cctv cameras in a set of schools. they work ok outdoors, but won't go 100 feet inside a building. Plus they die al the time. bad battery connections, units go dead all of a sudden even when the battery is fully charged, and it's like there are shorts in the volume and chanel buttons. You push to talk and the unit dies. We would never buy these again. we w..." Read Full Review »
Jan 25, 2009 by skbarcht
See more negative Motorola Talkabout EM1000R Two Way Radio reviews
Displaying 1 - 5 of 16 Reviews
Show
Sort by
FRS/GMRS Radio 101
5.0
    Pros
  • Accurate Controls
  • Clear Signal
  • Compact
  • Easy To Set Up
  • Good Sound
    Cons
  • None
    Best Uses
  • None
"A FRS / GMRS radio frequency is mainly intended to be used by families and other non-business users. However with that being said FRS or Family Radio Service frequencies are liscensed to be used by any person or entity for legal purposes. This means that businesses can use the radio just like a fa …"  Read Full Review »
Was this Radio review on the Motorola Talkabout EM1000R Two Way Radio helpful to you?
 Report Abuse  (6)  (0)  0 comments
Apr 21 2009
The One
Wild Colorado
I am:
  • Tech Savvy
Reviewed at:
Price: $59.99
[5 of 5 customers found this review helpful]
Great radios
5.0
    Pros
  • Clear Signal
  • Easy To Use
  • Lightweight
  • Rugged
  • Weatherproof
    Cons
  • None
    Best Uses
  • None
"We use radios to communicate instruction between the director and band bus chaperones. It's hard to find a good radio that will work with all the metal in a bus body but these are the best we've found. I bought two just to try and now we have 6 more ordered. The flashlight and usb plug in are all pl …"  Read Full Review »
 Report Abuse  (5)  (0)  0 comments
Oct 25 2008
Stan the Director
Ardmore, AL
I am:
  • Outdoor Professional
Reviewed at:
Price: $59.99
Best buy for the money
5.0
    Pros
  • Accurate Controls
  • Clear Signal
  • Compact
  • Easy To Set Up
  • Good Sound
    Cons
  • None
    Best Uses
  • Basic Systems
"MY Band boosters bought 8 of these to use for communications during our recent marching band competition that we hosted.
They performed beyond expectations. Communications were certain, the batteries lasted for the entire competition and our established range was at least 1/2 mile without any glit …"  Read Full Review »
Oct 27 2009
Rebel Band
Lincolnton, NC
Units die quickly
1.0
    Pros
  • Lightweight
    Cons
  • Drains Battery
  • Poor Reception
  • Short Range
    Best Uses
  • Families
"we bought 4 of them to use on one job of installing cctv cameras in a set of schools. they work ok outdoors, but won't go 100 feet inside a building. Plus they die al the time. bad battery connections, units go dead all of a sudden even when the battery is fully charged, and it's like there are s …"  Read Full Review »
 Report Abuse  (4)  (2)  0 comments
Jan 25 2009
skbarcht
Charlottesville, VA
I am:
Reviewed at:
Price: $59.99
[2 of 4 customers found this review helpful]
EM1000R MODEL IS JUNK
1.0
    Pros
  • None
    Cons
  • LESS THAN 1 MILE
  • Short Range
    Best Uses
  • Families
"PURCHASED UNIT TWO DAYS AGO. AS YET UNABLE TO COMMUNICATE MORE THAT 100 YARDS OR SO. FULLY CHARGED BATTERIES ALL TECH REQUIREMENTS COMPLIED WITH. SPOKE WITH CUSTOMER SUPPORT AND ONLY GOT POLITICALLY CORRECT INFORMATION SUCH AS YOU NEED TO BE IN PERFERCT IDEAL CONDITIONS TO BE ABLE TO COMMUNICATE. OF …"  Read Full Review »
 Report Abuse  (2)  (2)  0 comments
Jan 6 2009
JIM WEST
DALE CITY
I am:
  • Casual Adventurer
Reviewed at:
Price: $59.99
pages: 1 2 3 4 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
