Motorola H700 Bluetooth Wireless Headset
#3
4.0
based on 528 reviews
from $19.49
Ratings Distribution
5 star
267
4 star
134
3 star
35
2 star
42
1 star
50
Category Average
3.7
$19.49 at Overstock.com
Find it at Amazon
Find it at Ebay
More Images
Pros
  • Lightweight (30)
  • Easy to use (25)
  • Good performance (18)
  • Good volume control (18)
  • Great sound quality (17)
  • Nice sound (16)
  • Clear signal (15)
  • Good value (15)
  • Durable (14)
  • Comfortable (3)
See less See more
Cons
  • Spotty signal (10)
  • Uncomfortable (3)
  • Heavy / bulky (2)
  • Low volume (2)
  • Background noise (1)
  • Battery dies at 1 hour (1)
  • Battery goes low (1)
  • Disconnects (1)
  • Mic goes out after 6-8 mo (1)
Best Uses
  • Good for commuting (29)
  • Travel (17)
  • Work (4)
  • Multitasking (3)
  • Around the house (2)
  • Home (2)
  • Office (2)
  • Anywhere around the house (1)
  • Good while driving (1)
  • Muting is easy (1)
Provided by Super Warehouse
The best just got better. With proven 5th generation technology and form- the Motorola H700 Bluetooth Headset enhances the popular folding microphone design with superior audio performance- echo cancellation technology and an approximate 30% reduction in size. Discriminating consumers will welcome the Motorola H700 because it eliminates wires while delivering crisp- clear communications. With a 10-meter (30 feet) connectivity range- new levels of comfort and simple one-touch access to your most desired features- wireless has never looked so good. Designed for enhanced comfort while delivering a 30% reduction in size and weight from its predecessor- the super compact Motorola H700 delivers unbeatable comfort with an ergonomic ear hook that can be worn on either ear. With unsurpassed call quality and Motorola's exclusive PowerFlip design that lets you answer and end calls with ease- this headset optimizes on-the-go conversations- with style and simplicity. The Motorola H700 is the premium choice for those who are serious about wireless connectivity- offering up to six hours of talk time- 130 of standby time and charge time of less than one hour. Designed with your calls in mind- the headset features Bluetooth 1.2 wireless technology for better call quality- faster connections and less interference. Feature rich doesn't mean complicated. A blue light lets others know when you're on a call. The light changes colors to let you know when the headset is in pairing mode- charging or running low on battery power. The ability to connect with compatible devices up to 10 meters (30 feet) away helps you chat- sync and send- even when your mobile isn't in sight. Fashionable and functional- the Motorola H700 is the essential partner for serious mobile consumers.
  • Product Description: Motorola H700- headset
  • Product Type: Headset- wireless- Bluetooth
  • Recommended Use: Cellular phone
  • Headphones Type: Headphone- monaural
  • Headphones Form Factor: Over-the-ear
  • Connectivity Technology: Wireless- Bluetooth
  • Sound Output Mode: Mono
  • Microphone: Built-in
Specification Description
Model 89087J, 98686, 98686H, BTH700RB
UPC 723755890138
Boy Girl Both
Country Of Origin China
TRU Age Filter Big Kids
Motorola H700 Bluetooth Wireless Headset Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Oct 2, 2009
Motorola H700 Bluetooth Wireless Headset Reviews
Most helpful positive review
[1 of 1 customers found this review helpful]
Most helpful negative review
4.0
I received the H700 as a ...
"I received the H700 as a Valentine gift back in February. I have been very impressed with the range of features, size, comfortable design and battery life. I am a little disappointed in the sound quality though. In general, I use the headset daily but only for a few minutes per day. On occasion, I have worn the headset all day long and spent hours on the phone. I find that I can wear the H700 for hours and ..." Read Full Review »
Jun 07, 2006 by Jack M
See more positive Motorola H700 Bluetooth Wireless Headset reviews
3.0
Disappointed after one month trial
"I purchased this headset on Dec. 5, 2007 after reading hundreds of reviews (both positive and negative). There were more positive than negative, so I decided to give it a try (not to mention it was on sale for half off). It paired with my Samsung M510 with no problems. I did not have any physical problems with the bluetooth at all (the buttons are easily accessable, it's stylish and extraordinarily comfortabl..." Read Full Review »
Jan 05, 2008 by MNLAW
See more negative Motorola H700 Bluetooth Wireless Headset reviews
Displaying 1 - 5 of 528 Reviews
Show
Sort by
3.0
    Pros
  • Durable
  • Good Volume Control
  • Lightweight
  • Stylish
    Cons
  • Sound quality - both ends
    Best Uses
  • Commuting
  • Travel
"I purchased this headset on Dec. 5, 2007 after reading hundreds of reviews (both positive and negative). There were more positive than negative, so I decided to give it a try (not to mention it was on sale for half off). It paired with my Samsung M510 with no problems. I did not have any physical …"  Read Full Review »
Was this Bluetooth Headset review on the Motorola H700 Bluetooth Wireless Headset helpful to you?
Jan 5 2008
MNLAW
Central MN
I am:
  • Practical
  • Student
Reviewed at:
4.0
    Pros
  • Easy to use
  • Good performance
  • Good sound quality
  • Good Value
    Cons
  • None
    Best Uses
  • None
"I received the H700 as a Valentine gift back in February. I have been very impressed with the range of features, size, comfortable design and battery life. I am a little disappointed in the sound quality though. In general, I use the headset daily but only for a few minutes per day. On occasion, …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Jun 7 2006
Jack M
Jonesboro, AR
Reviewed at:
Motorola H700 is what I was looking for
5.0
    Pros
  • Clear Signal
  • Durable
  • Good Sound
  • Lightweight
  • More »
    Cons
  • Pairing can be spotty
    Best Uses
  • Commuting
  • Home
  • Office
  • Travel
"I am very picky about bluetooth headsets and have tried around 15 of them. Prior to this headset I was using a logitech mobile freedom and logitech mobile traveler which had great sound quality but both headsets had a design flaw where a 5 cent piece of rubber broke and rendered the units inoperable …"  Read Full Review »
Jan 29 2007
San Francisco, CA
Reviewed at:
I love it.
4.0
    Pros
  • Durable
  • Good Price
  • Good Sound
  • Lightweight
  • More »
    Cons
  • Signal breaks after 10 ft
    Best Uses
  • Commuting
"This is my first experience with a headset so I don't have much to compare it to. I think this headset works fine. People have complained about the person on the other end saying it is muffled or has some static. Well, if you make sure the boom is not resting against your jaw/cheek you will eliminat …"  Read Full Review »
Dec 17 2007
Bill
Kansas City,Mo.
I am:
  • Practical
Reviewed at:
As a radioshack employee ...
5.0
    Pros
  • Easy to use
  • Good performance
  • Good Value
    Cons
  • None
    Best Uses
  • None
"As a radioshack employee I have had the benefits of trying out several blue tooth headsets that we sell in store. This is by far the best one that I have gotten my hands on. I recommend it to all customers with the added warnings that it will begin to cut out at around 25 feet. If the instruction …"  Read Full Review »
Jun 29 2006
Angela L
Hammond, La
Reviewed at:
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
