Monster PowerCenter HT 800, 8 Outlet Surge Suppressor
#315
4.1
based on 13 reviews
Ratings Distribution
5 star
7
4 star
3
3 star
1
2 star
1
1 star
1
Category Average
4.3
$44.08 - $79.99
from 14 stores
More Images
Pros
  • Good cord length (5)
  • Great protection (5)
  • Compact size (3)
  • Durable (3)
  • Warranty (3)
  • Good protection (2)
  • Long cord (2)
  • Nice size (2)
  • Easy to use (1)
  • Good performance (1)
See less See more
Cons
  • Bulky size (1)
  • Cord is too short (1)
  • Poor protection (1)
Best Uses
  • Audio equipment (5)
  • High-end equipment (5)
  • Tv's (5)
  • Computers (4)
  • Entertainment center (1)
  • High-end electronics (1)
  • Sat/ phon / lcd tv / dvd (1)
Provided by MAGo Enterprise
MODEL- MC109302 VENDOR- MONSTER LLC FEATURES- Home Theatre PowerCenter HT 800Home Theatre PowerCenter HT 800 with Clean Power Stage 1 v2.0. Monster Clean Power Stage 1 v2.0 filter to provide noise-free power to your sensitive electronic components. Color-coded labeled outlets and matching cord labels for easy hookup. 8 foot Monster AC power cable with FlatProfile right angle plug provides flexibility for installations. Eight outlets total including three spaced for use with AC adapter transformers. Maximum conductivity 24k gold contact grounded right angle plug lets furniture hug walls. Audible and visual indicators for damage protection and ground status monitoring. Protects cable TV coax lines from surge pulses. Includes one Monster Video F-Pin cable for fast and easy satellite connections. $150 000 connected equipment warranty and lifetime PowerCenter product warranty. 1850 Joule rating provides higher level of surge absorption. * Harmful power surges and voltage spikes can travel up the AC power lineand damage connected equipment. Lightning automatic garage doors powertools refrigerators and fluorescent lights all cause power surges andvoltage spikes that affect phone lines and coax cables. Monster's Surge- Guard detects harmful power surges and voltage spikes before they reachcomponents. This HT800 features special surge protection for coax cablesused for satellite and cable TV connections. Other surge protectors Coaxsurge protection can result in as much as 20 to 30 dB of signal loss which ultimately affects the output performance of coax connections.Monster's ultra-low loss RF circuitry provides virtually no signal lossto maintain peak performance. * Best of all an audible surge alarm and visual surge indicator warn youof harmful surges and let you know you are getting the most advancedprotection available. Polluted AC power can degrade the performance youexpect from your home theatre components. * Unless you live directly behind Hoover Dam your AC power is most likelypolluted by appliances sharing the same power line with your hometheatre components. Electrical power tools refrigerators airconditioners radio transmitters cellular phones microwave ovens - evenyour neighbor's freezer - all can generate electromagnetic interferenceand radio frequency noise which pollutes the AC power and degrades bothaudio and video performance. Plus even your home theatre components cangenerate noise interference adding more pollution to your AC power. As a result you will hear a loss of dynamic range and resolution with acompressed soundstage and imprecise imaging. You will see a lack ofsharpness and color detail lessening the home theatre experience. Andyou will never know how much of the essential drama is gone in the highperformance picture and sound your system was originally designed todeliver. Monster's Clean Power Circuitry filters out power pollution for morenatural sound and better TV picture. Designed by world renown AC powerexpert Richard March Monster's Clean Power Circuitry uses specialfilters to dramatically reduce electronic noise on your AC power line togive you the best possible sound and picture from your components. Youwill see a more vivid picture and hear more natural sound with increaseddynamic range and less noise - especially if your AC power is sever
Specification Description
Model 109302, 109302-, MP HT 800, MP HT800 109302
UPC 050644214271
Accessory Indicator Yes
Benefits 8 color-coded, labeled outlets with 3 widely spaced outlets for larger adaptersClean Power™ Stage 1 filters out noise, surges an
Body Material Plastic
Built-in Devices Noise Filter
Cables Included 1 x power cable - 8 ft ยช 1 x video cable, 1 x coaxial cable - 3.3-foot
Capacity UOM mAh
Country Of Origin United States
Description Header Protect your sound system from power surges.
Display Catalog Number 61-2450
Enclosure Color OFF White
Features Protects cable TV coax lines from surge pulsesSurge energy rating: 1850 joules8-foot AC power cable with FlatProfile™ r
Included in the Box Monster 8-outlet home theater powercenterMonster 3.3-foot (1-meter) Coax Video CableCable labels
Inputs 1 x "F" Plug(Coax In)
Manufacturer Labor Warranty 1
Manufacturer Parts Warranty 1
MAP Price 0.0
Model MP HT 800
Operating Temperature UOM ° F
Outputs 1 x "F" Plug(Coax Out)
Product Height 1.5
Product Length 4
Product Type 1501-2000 Joules
Product Width 10
Supported Languages English
Monster PowerCenter HT 800, 8 Outlet Surge Suppressor Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Sep 18, 2009
Monster PowerCenter HT 800, 8 Outlet Surge Suppressor Reviews
Most helpful positive review
Most helpful negative review
5.0
Well Designed Unit
"Good design. I like the flat outlet plug that fits easily behind furniture. Plenty of outlets to connect all my gadgets and a nice long cord. Clever design with label on the outlets so you know what you're unplugging when you're reaching behind furniture to move things around...." Read Full Review »
Jan 01, 2009 by Andy
See more positive Monster PowerCenter HT 800, 8 Outlet Surge Suppressor reviews
2.0
not terrific
"1st. I use the product as intended. 2nd. Surge protection---how can i know if it is effective? 3rd. the cables are too short to reach from the TV stand (which i also bought from you), to the surge protector. Not too pleased...." Read Full Review »
Sep 23, 2008 by i dont have a nickname
See more negative Monster PowerCenter HT 800, 8 Outlet Surge Suppressor reviews
Displaying 1 - 5 of 13 Reviews
Show
Sort by
Well Designed Unit
5.0
    Pros
  • Durable Construction
  • Good Cord Length
  • Good Warranty
  • Great Protection
    Cons
  • None
    Best Uses
  • Audio Equipment
  • Computers
  • TV's
"Good design. I like the flat outlet plug that fits easily behind furniture. Plenty of outlets to connect all my gadgets and a nice long cord. Clever design with label on the outlets so you know what you're unplugging when you're reaching behind furniture to move things around. "
Was this Surge Protector review on the Monster PowerCenter HT 800, 8 Outlet Surge Suppressor helpful to you?
Jan 1 2009
Andy
Hackensack, NJ
I am:
  • Tech Savvy
Reviewed at:
Price: $49.95
Monster does it again
4.0
    Pros
  • Compact Size
  • Good Cord Length
  • Great Protection
    Cons
  • None
    Best Uses
  • High-End Equipment
  • TV's
"Picked this up after my original surge protector died on me. You can tell the difference when you hook it up. When I hooked up the coaxial cord, the sound and picture became instantly clearer. Please get this product. You won't be sorry. "
Dec 11 2008
djgreg
Baltimore, MD
I am:
  • Tech Savvy
our 2nd one
5.0
    Pros
  • Compact Size
  • Good Cord Length
  • Good Warranty
  • Great Protection
    Cons
  • None
    Best Uses
  • Audio Equipment
  • Computers
  • TV's
"We live in Southern California - with its all-too-frequent power "brown outs" a reliable surge protector is a must "
Sep 18 2009
bb
orange county, CA
I am:
  • Technically Challenged
Reviewed at:
Price: $49.99
Monster Cable #1
5.0
    Pros
  • Good Protection
  • Long Cord
  • Nice Extras
  • Nice Size
  • Rugged
    Cons
  • None
    Best Uses
  • High-End Electronics
"I have this surge protector too. It's also a excellent product and great for your LCD TV..I was having power surges and this surge protector keeps the surges from harming my electronics...would highly recommend... "
Apr 28 2007
Deerman13
Many, LA
I am:
  • Practical
not terrific
2.0
    Pros
  • None
    Cons
  • Bulky Size
  • Cord Is Too Short
    Best Uses
  • None
2nd. Surge protection---how can i know if it is effective? 3rd. the cables are too short to reach from the TV stand (which i also bought from you), to the surge protector. Not too pleased. "
Sep 23 2008
Greenwick Village, NYC
I am:
  • Professionally installed
pages: 1 2 3 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
